So I finally have one of my fleet of junk cars working, and i'm sure the coolant is way too many years past when it "should" have been changed because stuff got parked when it broke and that was at least 5 years ago, which was a few years after I inherited it and I wasn't sure when it was done before that. (even if it was immediately before, that's pushing the 7 year limit I thought extended life coolant was good for)
I'm not doing this trying to be cheap right now - I am physically so crippled up I cannot get under the vehicle and don't want to mess around with anything until it's less of a struggle.
I just want everything to run through the winter, so that I can mess with it in the spring. The coolant still tests fine for temperatures, it's just... old. Probably not even too many miles, just old.
Is there something I can stick in the cooling system to maintain corrosion protection and similar so I don't feel I have to instantly change it or is that a bad enough practice to not limp it another 4 months but to pay a shop to do it?
