Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
paolo9fla, SunnyB, Mullady76, Axia2, Johan1
71847 Registered Users
82 registered members (4WD, 555, BAJA_05, Astro14, 77GrandPrix, 55hambone, 14 invisible), 1,484 guests, and 24 spiders.
Topics307,433
Posts5,310,907
Members71,847
Page 1 of 5 1 2 5
Frantz Oil Refiner installed on 4Runner #4908215 10/28/18 10:49 AM
F
FlyNavyP3 Offline OP
F
My fittings arrived to finish the plumbing and install of my Frantz Oil Refiner bypass system on my 22RE powered 4Runner.
Oil supply comes from the block via a 1/8 BSP to -4AN fitting to a -4AN line to a tee fitting on the inlet of the filter. One side of the tee feeds pressure to the filter and the other side continues on to an Autometer and OEM pressure sender. Outlet of the filter is also plumbed in -4AN to a return on the cylinder head in the fuel pump block off plate that I drilled and tapped for 1/8 NPT and fitted with a -4AN to 1/8" NPT fitting.
I drew a sample after adding the required makeup oil to the system to have a baseline prior to running the system. I will run this until the filter stops flowing and draw a sample prior to changing the filter and diluting with fresh top up oil.
Haven't driven the system much yet but idle pressure is down about 2 psi and in town cruise oil pressure is down 5-8 psi according to my Autometer gauge. It still has plenty of oil pressure to be safe and I haven't been on the highway yet to evaluate. I don't expect highway oil pressure to be affected since it previously went down the highway on the oil pump bypass at 75-80 psi.
Current filter media is Scott 1000 at 74 cents per element.
20181027_142533.jpg20181027_140934.jpg20181027_140927.jpg20181027_140915.jpg20181027_140819.jpg20181027_140813.jpg20181027_134725.jpg20181027_134041.jpg
Luke
Re: Frantz Oil Refiner installed on 4Runner [Re: FlyNavyP3] #4908219 10/28/18 10:53 AM
F
F
More pictures of the return setup. Duplicate picture of the return installed for reference. The return enters the very front of the cylinder head above the timing cover and has a unobstructed return path th the front of the oil pan clear of the crankshaft throw.
Luke
Re: Frantz Oil Refiner installed on 4Runner [Re: FlyNavyP3] #4908223 10/28/18 11:01 AM
Zee09 Offline
Great pictures- thanks.
I remember similar units from the 70's
I always wondered about them since tp is very dusty.
"If I walked on water, they'd say I couldn't swim."
Re: Frantz Oil Refiner installed on 4Runner [Re: FlyNavyP3] #4908250 10/28/18 11:39 AM
53' Stude Offline
Nice pics and very good, detailed install. Thanks! smile
Re: Frantz Oil Refiner installed on 4Runner [Re: FlyNavyP3] #4908371 10/28/18 01:43 PM
U
UncleDave Online Content
Online Content
U
Thanks for serving.
Frantz are very cool units and this looks like a well-done install.
Whats your reasoning behind doing this?
Always curious as to hearing why people install external bypasses.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Frantz Oil Refiner installed on 4Runner [Re: FlyNavyP3] #4908396 10/28/18 02:11 PM
P
PiperOne Offline
P
Does Frantz offer suggestions for what TP to use? As mentioned above, there is so much dust and lint in most TP I would be a tad worried about it.
HDEO in Diesel Engines. No spark plugs here.
Re: Frantz Oil Refiner installed on 4Runner [Re: PiperOne] #4908402 10/28/18 02:17 PM
U
Online Content
U
Yeah - they recommend and sell their media.
Like Trasko.
Uncle Dave
Re: Frantz Oil Refiner installed on 4Runner [Re: UncleDave] #4908424 10/28/18 02:40 PM
F
F
Like Trasko.
The company who sells the older design Frantz sells media. This is the newer design sold by Ed Greany and is the update to the traditional Frantz. Ed recommends single ply TP sourced from your local store. The Scott 1000 is a densely wrapped roll and can be used in the new Oil Refiner without unwrapping any material and no need to shove it into the canister. Install the roll on the base tucking in around the edges and push the canister over it, done.
Luke
Re: Frantz Oil Refiner installed on 4Runner [Re: UncleDave] #4908437 10/28/18 02:51 PM
F
F
Thanks for serving.
UD
My grandfather used to run these for decades on his vehicles and I was always intrigued. My 4Runner has always struggled with high insolubles even with excellent rated full flow filters at reasonable intervals. So I decided to try out an inexpensive bypass system to see if it would resolve the issue or at least help with the smaller particles in the oil. If it works out I'll extend the oil changes using UOA as a guide.
I will be installing a restricted feed to the filter down to 0.035" to help reduce the flow through the filter as it's a little down on oil pressure with the current setup. The indicated pressure might be a little down because of the way I have it plumbed but without a ton of work in changing the plumbing it's easier to just install a restricted fitting and see if the oil pressure comes up. The pressure isn't way down but I'd like to tweak the setup just a little bit to see if I can bring the pressure back up closer to what it previously was.
Luke
Re: Frantz Oil Refiner installed on 4Runner [Re: FlyNavyP3] #4908445 10/28/18 03:10 PM
L
Linctex Offline
L
Originally Posted by FlyNavyP3
I will run this until the filter stops flowing......
You are going to be waiting for a very long time, I believe.
Re: Frantz Oil Refiner installed on 4Runner [Re: Linctex] #4908458 10/28/18 03:27 PM
F
F
It will be interesting to see, member A310 has only been getting 2000-3000 miles on his Motor-Guard before it stops flowing for him, so I'll be interested to see how fast it plugs up.
Luke
Re: Frantz Oil Refiner installed on 4Runner [Re: PiperOne] #4908499 10/28/18 04:17 PM
L
Linctex Offline
L
That stuff is huge, though - like 100 microns. The full flow filter will catch it easily.
Re: Frantz Oil Refiner installed on 4Runner [Re: UncleDave] #4908501 10/28/18 04:19 PM
L
Linctex Offline
L
Because I want to try to catch the stuff that the full-flow filters cant.
I do notice my oil stays cleaner, longer - though.
Re: Frantz Oil Refiner installed on 4Runner [Re: FlyNavyP3] #4908510 10/28/18 04:30 PM
B
beanoil Offline
B
Excellent!
One ?
Are you only supporting on one side? It looks like the other ear is not bolted to anything?
Re: Frantz Oil Refiner installed on 4Runner [Re: beanoil] #4908513 10/28/18 04:35 PM
F
F
Originally Posted by beanoil
Excellent!
One ?
Zoom in on the first picture the side closer to the engine also has a bracket that goes down to the inner fender but is hard to see because it's painted white.
Luke
Page 1 of 5 1 2 5
