I just bought a 2018 Polaris Scrambler 1000 and just recently made it through the break-in period... So went ahead and did the oil change.
Upon inspection of the oil filter, I noticed a couple small metal shavings sticking out of it! The biggest was maybe an inch long.
Should I be concerned? I've heard of shavings being left behind from the machining process. I'm hoping that might be the case here. The engine itself seems to be running fine.
