'd like to use them but concerned about their low psi rating. I email them and here is the response, I'd like to believe it.
Hello
I drive a 2018 Subaru Crosstrek and would like to use K&N filter. The model you spec is K&N HP-1004, it has a PSI Relief Valve 11-17 while the OEM filter specs at 26 PSI for this engine.
Will you make a filter that is in compliance with OEM spec. and how do you recommend this one with such a different psi rating?
Thanks
Hello,
Thank you for contacting K&N. The K&N oil filters are designed to meet or surpass the OEM flow and filtration. The bypass valve is designed to work when there is back pressure and the PSI will vary from filter to filter and vehicle to vehicle. The OEM specification you listed below is based of the OEM oil filter which has a different filter media in comparison to a K&N. Our media and the media that the OEM are not the same so that is why the PSI is different. Our media is Resin impregnated cellulose. I am not sure what type of media the OEM would use. If you are concerned about the PSI then we suggest to use the OEM.
Thank you,
K&N Customer Service & Tech Support
Hello
Thanks
Hello,
Thank you,
