Originally Posted by BigShug681
Originally Posted by burla
Originally Posted by Cipriano
I recently started a thread asking about Redline or Amsoil in my move up to 5w30. But the more I read about these Ravenol PAO's the more intrigued I got. And then I happened to go to Ebay today and saw the 10% coupon. So, long story short, 5 liters of Ravenol dxg 5w30 is on its way for $41.19 after shipping!
awesome stuff, I may move the wife's car over at some point. My only negative on Ravenol in general is availability. On a personal level I prefer high moly oils and this aint one unless that has changed, dunno I haven't looked it up. But my take is for guys not wanting the super hearty pao oils that dominate the market, this is an easy choice. Lower additives more compliant with zinc phos levels and such. But it seams better suited for modern engines with those low additives.
I feel I read on here that only so much moly actually does stuff and the rest just sorta sits around? Is that correct I can't remember, I'm more of a fan of the big slugs of ZDDP but do enjoy a small dabble of moly?
Well of course it is oil soluble in PCMO, so it aint sitting nowhere. And with all of the lowering of additives thanks to uncle sam, and the research that proves that moly helps avoid lspi, and the movement to thin oils, I do prefer moly as my security blanket. Consider this, FCA set out to spec an oil specifically for my application the hemi, what did they create with the help of Pennzoil? 0w40 PUP, a thick oil with high moly and high detergency. Amsoil as well, both I believe well over 200ppm moly.
