Hello people, new member here! I would like to know your opinion, and maybe some important differences, on these two oils:
> Motul Power 4100 SL 15W50 Technosynthese (https://www.motul.com/us/en-US/products/4100-power-15w50)
> Total Quartz 7000 SL 15W50 Semi Synthetic (http://www.lubs-products-database.total.com/gallery/ORIGINALS/visuels/14000/14200)
I live in Brazil where the temperature never goes below 50°F, and has a lot of humidity.
I drive (since May) a 1994 Chevrolet Kadett 1.8 EFi, the car is a neat ethanol car, so running on E100 since factory. I use it 90% of the time on fast roads doing around 60 to 90mph, and sometimes i have to do short trips (10 miles).
The owner's manual asks to use 15W40 or 20W50. When i bought the car i did the first change with a conventional Mobil 20W50 just to change it, after some research i decide to use the Total last week, but the Motul is still in my head.
The Total is a little bit cheaper and the specs says is good for ethanol, although i think every gas oil should be good for ethanol.
What do you think is better?
