So im suddenly getting compressor surge. I installed a forge bypass valve with the weakest spring it came with. I did get one surge with its first opening after install then it went away. I also installed a adjustable wastegate actuator. My tuner said to start at 1 turn in. Did that and now i constantly get surge/stall when i shift it stalls the turbo and i can feel it fall on its face. I have to rebuild boost after shifts. It used to be insta spool but now its like a 1.5 sec lag. Also sometimes under 1.5 lbs of boost the bpv wont open and i can hear the blades chop the air. I also tried half a turn on the wastegate arm with no change. I havent tried no turns on the arm yet. But what do u guys think bad tune? Bad part? Also i didnt have the surge stall issue with just the bpv installed. Also no boost leaks. Everything is installed correctly.
