Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Personal finance book in Spanish
by czbrian - 01/23/20 01:03 PM
SQL Basics?
by tom slick - 01/23/20 11:08 AM
Unused PRO-TEC 101 oil filter cut open / Wix 51515
by rollinpete - 01/23/20 10:32 AM
1997 Civic Ignition Module & Coil Replacement?
by njohnson - 01/23/20 09:38 AM
Sirius radio Issues
by Boomer - 01/23/20 09:09 AM
Mailman1995, DougCFL, Sayafi, SeanSkiVT, 02COBRA
70512 Registered Users
125 registered members (4WD, 2002 Maxima SE, 2010Civic, 53' Stude, 55hambone, 2003f7, 14 invisible), 1,871 guests, and 19 spiders.
Topics300,474
Posts5,176,716
Members70,512
Need turbo help #4904489 10/23/18 10:06 PM
Dylan1303 Offline OP
So im suddenly getting compressor surge. I installed a forge bypass valve with the weakest spring it came with. I did get one surge with its first opening after install then it went away. I also installed a adjustable wastegate actuator. My tuner said to start at 1 turn in. Did that and now i constantly get surge/stall when i shift it stalls the turbo and i can feel it fall on its face. I have to rebuild boost after shifts. It used to be insta spool but now its like a 1.5 sec lag. Also sometimes under 1.5 lbs of boost the bpv wont open and i can hear the blades chop the air. I also tried half a turn on the wastegate arm with no change. I havent tried no turns on the arm yet. But what do u guys think bad tune? Bad part? Also i didnt have the surge stall issue with just the bpv installed. Also no boost leaks. Everything is installed correctly.
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
19 cruze auto 1.4t amsoil oe 5w20 tuned on 24psi
Re: Need turbo help [Re: Dylan1303] #4904498 10/23/18 10:41 PM
N
nthach Online Content
Online Content
N
Before blaming the tune, the turbo/wastegate/BOV need to be setup properly. I have little experience with this, but I know of a mechanic who also tunes and he wants to make sure the baseline is there before tweaking.
Check for leaks on all the piping, the turbo is sized, and that the wastegate and BOV/BPV are in working shape.
Re: Need turbo help [Re: Dylan1303] #4904523 10/24/18 12:41 AM
V
VeryNoisyPoet Offline
V
I suspect the BPV could be failing to open when you let off the throttle. BPV relies on vacuum/pressure differential between charge pipe and manifold. Valve stays shut with a small differential while throttle is open; large differential when throttle is closed causes valve to bypass. Get a hand vacuum pump and test the valve by applying vacuum to the signal port to see if it moves properly.
Wastegate actuator alone should not be causing those symptoms, but if you could revert to previous wastegate actuator setup that might help troubleshooting.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Need turbo help [Re: Dylan1303] #4904588 10/24/18 05:53 AM
SHOZ Offline
I use a Forge BOV. You need the springs and maybe shims so it is open at idle.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Need turbo help [Re: Dylan1303] #4904625 10/24/18 07:24 AM
A
A_Harman Offline
A
Sounds like the Forge bypass valve is at fault. Put it back to stock and see if drivability improves.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Need turbo help [Re: Dylan1303] #4904631 10/24/18 07:32 AM
SHOZ Offline
Make sure the orings are good and it is lubed too. The Forge requires at least annual service. They have service kits for them for around $25 which includes the orings and a new piston plus some grease. I use the yellow spring and a shim and see 22 psi boost max.
Valve Spring color coding:
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
*The above figures are estimates only and should only be considered as a guideline*
Re: Need turbo help [Re: Dylan1303] #4904753 10/24/18 09:51 AM
CT8 Offline
Suddenly? You made serious modifications. I gave up on modifying anything I own 40 years ago.
2015 F150 2.7
2018 F350 6.2
Re: Need turbo help [Re: Dylan1303] #4904754 10/24/18 09:51 AM
gathermewool Offline
As has been recommended, I'd return individual items back to stock or stock-like and see where the fault lies. If you return fully to stock and the issues is not resolved, then it's likely the tune.
Some Questions:
Why are you using a manually-adjustable waste gate actuator? Why can't your tuner simply adjust your waste-gate duty cycle tables in the tune itself? I'm only familiar with turbo Subies, and I'm not aware of these things ever being used - sounds janky.
Why did you install a new BPV? Did you have issues with the stock valve leaking or does the new one just make more cool-sounding noise?
Also, is your new valve really a bypass valve or does it vent some/all air to atmosphere.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Need turbo help [Re: CT8] #4904760 10/24/18 09:56 AM
M
maxdustington Offline
M
Even your house? Modded cars are the things dreams are made of.
99 Toyota Tercel CE 5EFE/C151
Re: Need turbo help [Re: Dylan1303] #4904768 10/24/18 10:05 AM
StevieC Offline
It sounds like it's either not setup properly or there is a component not working properly. Best to take it somewhere they can test / setup.
'18 Caravan - 48k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Need turbo help [Re: Dylan1303] #4904807 10/24/18 10:50 AM
R
Rand Online Content
Online Content
R
Quote
I put a new engine in my car and suddenly it acts different.
ok maybe it wasnt that much of a mod but that is a serious difference.
if it worked before and doesnt now.. you need to either put the old back on or adjust it properly.
Also is the tune designed for this type of BOV?
Re: Need turbo help [Re: Dylan1303] #4904832 10/24/18 11:05 AM
SHOZ Offline
Did the problem start immediately with the new BOV? Are you using a factory BOV solenoid or just intake vacuum to run the Forge?
Re: Need turbo help [Re: Dylan1303] #4904968 10/24/18 01:54 PM
Intake vacuum to the forge. My tune can do the receculcting or atmospheric bypass valve. Stock is recec and the forge is atmo. Yes the stock bpv wont hold past 18 pounds and leaks. Also the stock wastegate rod has corrison issues and has a weak spring too. Both r needed to run 20+ psi. I was over boosting with the stock parts leaking and it was commending more boost due to leaks. Im set for 22.5 psi. Overboost is set for 23 and will put it in limp mode.
Re: Need turbo help [Re: Dylan1303] #4904972 10/24/18 01:56 PM
SHOZ Offline
Is the crescent opening on the mating surface line up with the turbo housing correctly?
Re: Need turbo help [Re: Dylan1303] #4905147 10/24/18 05:02 PM
Stock is always recirc. It is called a bypass valve (BPV), because it recircs back to upstream of the turbo, so that no metered air is lost (doesn't mess with your MAF-measured amount of air being sucked/blown to the motor.
Your Forge is a blow-off valve (BOV), because it does not recirc this metered air back to the intake.
How does your tune account for both? That does not make any sense to me. If your tuner says it does and can't explain how to you in layman's terms, then he's full of it.
