Originally Posted by diyjake
Originally Posted by StevieC
I like the metal crush washers whether it is aluminum or copper. If you only tighten down to 20ft-lbs they can generally be used over and over again for a long time. It's only when you really reef on them that they are spent every 1-2 oil changes.
I used to do this all the time before I started using a Fumoto valve instead.
How do you like the Fumoto valve? I thought about using one but i'm afraid something would tap it and cause to lose oil or it is very secure?
I have been using them for over a decade now and have 9 of them in use in the family and have had only an issue with one 10 years ago that dripped occasionally and they warrantied it no questions asked. I'm a big fan of them for how easy it is to drain the oil without worrying about dropping the drain plug into the catch pan and not having to worry about crush washers ever again.
