The trans has been worked hard in brutal heat - and been solid as a rock. Remember I have like 80% towing duty on mine
A guy using it for driving around duty or loading up the bed - probably couldn't kill it.
That said I maintain it I did ATF drain and fills at (something like) 30/60, and a pan drop/ full fluid, and pan filter change at like 90,
Those DF's were easy to do and only took a few minutes alongside the oil change at the time.
Mags had very light fuzz and remaining open area - one had some buildup on the top - but well contained. You can see the fingerprint dimple on it.
the guy whose lift I used is basically a private shop and he knew the story on the truck and has been impressed with how well its held up.
I've had chassis related parts go and wear with regularity - but in terms of engine and drivetrain, this thing has been great.
UD
UD
