At 70000 miles the serpentine belt started making noise. I replaced the belt but not the tensioner. At 75000 miles started making noise again. "Chirping" noise. Replaced the belt and tensioner with a Nissan one. The tensioner pulley looks worn. Almost like the belt "cut a grove" in it. You can look at the belt and tensioner and the wear lines match each other.
My question is can the tensioner wear out after only 75000 miles? And it looks at the main fan pulley its getting shiny now. But no "groves" in it. Looks to be a bear to change. Do you think there is a chance the main fan pulley is worn? Thanks
