Originally Posted by bbhero
Originally Posted by Wolf359
Originally Posted by 1JZ_E46
Thanks all. Decided to go with the AAP Autocraft Platinum. Comes out to $143 with a 3 year warranty. Just checked and the current battery in my X5 is an Autocraft Gold that's 5.5 years old. If I can make it another 5-6 years on a $143 battery I'll be more than satisfied... if the rest of the car lasts that long.
I have a Carly adapter for programming the battery and will thoroughly clean all the connections before reinstalling.
I would suggest fully charging it before installing it. I think the reason batteries are dying early now is that they've changed the charging algorithm so that it doesn't get charged enough so they can get some tiny improvement in CAFE. I noticed in my older generation Mercedes W211, lots of people got 8-12 years out of their AGM battery, but in the newer generation W212, they were lucky if they lasted more than 5-6.
Great post here... If a battery sits uncharged for long periods of time.. it naturally loses charge. And the parts stores are not likely charging the batteries routinely every month. Even AGM batteries lose 1-3% capacity per month sitting uncharged. Flooded is obviously worse at 12-15% loss per month. So if one gets a AGM battery that has sat around uncharged for say 6-7 months.... It may well be down up 18-21 % charge from the start. And like Wolf said so correctly... Never trust your alternator to charge it up from a low percentage. And don't even trust your automatic charger has well... It will cut off way too soon all too often. Unplug and plug it back in... And do that a good number of times... My automatic smart charger will say 100% and go into float mode... Unplug it.. and literally plug it right back in... And it says 95%. Strange... It was just "100" percent right?? No. It wasn't. So.. use the plug and unplug trick... Be prepared to do it a fair amount.. I don't have any gadgets to test it for truly be 100 percent charged.. My way of estimating closest to 100 percent charge is timing how long it takes for the battery to go from that 95% to when it goes into full charge float mode... Eventually it gets to where it's less than 10 minutes. While the first interval was around 60 minutes... At 10 minutes or less... Then I'm ok with it.. Again... Wolf's post was a great post.
Thanks. Just some additional data points, just replaced the alternator in my car, I guess it was dying a slow death, but didn't notice it til I got a low voltage warning. Mine lets you display the voltage on the dash and after charging it up with an 8 amp charger, it was at 12.7 volts. Dropped down to about 12.5 volts after a little while. There's a chart around that tells you the state of charge for a battery with no load on it, 100% is about 12.7 volts. Anyway, once I hooked it back up to car, voltage dropped again to 12.1. So I guess I'm going to keep mine for a little bit longer, 10 years and only capable of holding an 80% charge, I guess that's not too bad, it was at 11.3 volts when I got a battery low warning, but that could be because when I started it, it dropped as low as 10.3 volts and I think once it drops below 11 it triggers a warning. Drove it fine all winter at 11.5 volts as the voltage drops in cold weather.
