I'm thinking about making a homemade leak down tester. My question is if I feed a constant 50 psi from the compressor to the spark plug hole,then splice a gauge into the air line the gauge should read 50 psi if there was zero leakage on that cylinder, or 40 psi if there was 20 % air escaping from that cylinder? I admit I'm not real knowledgeable on all things gauge/pressure related.LOL
