Originally Posted by brages
Maybe the PVC just fell off somewhere else and is stuck in some tiny crevice in or around the engine.
This seems rather likely.
Inanimate objects in or around an engine enter a field of evil, and become possessed of infinite cunning.
Its sort of like the Mordor of little things.
I thought about that when originally looking around for hours with light everywhere, and did again with the battery tray off, but I can't see how. It was sticky and covered in trans fluid, there's only so many things it could fall on right next to the dipstick tube, and i'm working over a white cement driveway so it's not hidden in the grass or anything.
YOU got yourself into this mess, YOU are going to have to get yourself out. Let's cut out the drama and focus on the problem.
1. Do you think the PVC is loose enough to fall through the dipstick tube, or was the fit tight enough to get stuck in the dipstick tube?
2. What tools do you have?
3. What tool stores do you have access to?
4. Can you post some pictures?
IMO, you have to get the dipstick tube out. I'm guessing that requires removing the air box, maybe battery. It helps to have a set of extensions (imo, the best special tool for all diyers).
I don't like the drive as is approach. My mind pictures pieces of PVC clogging screens and tiny passages. If the alternative requires removing the transmission, then I guess it's all you can do.
I'm aware, I was trying to avoid the topic drifting to unrelated things to just focus on solutions as it was. I'm also sorry to people who thought I was being ungrateful but some suggestions didn't even sound to me like real suggestions, at least not based on a bit more analysis or commentary.
#1 was verified, the diameter and such was just thin enough and verified by the camera its not stuck in there at least.
#2 is a bit disorganized, i'd brought alot of tools to a friends place 250 miles away for work on a timing belt I was hoping to originally do this last weekend but obviously went nowhere. I thought this would be the quickest job in the universe (ha ha), I have various backup tools but theyre a bit scattered. I don't have whats needed to pull a subframe or transmission though.
#3 the common autozone, oriellys and such, i'm not deep in a rural area but i'm not within range of bus routes or walking either and due to physical injuries i'm dependant on getting a ride. I'm trying to fix a different vehicle for limping around town but that's having it's own problems so give it a few days to see if I can.
#4 I posted borehole videos down the dipstick tube. I didn't post a borehole video from the transmission drain hole (it cant record, I have to use a cell to re-record it. I'm hoping to pull starter next, and then the dipstick tube, hopefully getting some better angles and looking around in there maybe by late today.
