Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
BMW caliper pins, no lube?
by ledslinger - 01/22/20 08:58 AM
Glock 44
by bradepb - 01/22/20 08:04 AM
Open up area in basement
by redhat - 01/22/20 07:42 AM
Briggs Intek Leaking Crankshaft Oil Seal
by UncleNorby - 01/22/20 06:26 AM
1ZZ-FE MR-2 (weekends and trackdays)
by geetar - 01/22/20 04:58 AM
Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Phildrum, 335xiE92FBO, oldrover, sarojasaruu, someoldguy
70503 Registered Users
106 registered members (bdcardinal, 4WD, bluesubie, A_User55555, 53' Stude, Blkstanger, 9 invisible), 2,653 guests, and 23 spiders.
Topics300,432
Posts5,175,624
Members70,503
Bad steering #4899307 10/18/18 07:48 AM
R
ridgerunner Offline OP
R
2010 Ram 2500. Noticed the steering was getting a bit....chunky. Like chunks of dirt going through a hose feeling on the steering wheel. Thought it might be the steering stabilizer on the front solid axle going bad. Checked the fluid level and it was fine and clear looking. A week later I checked it again and the cap to the fluid res. was gone. I know I tightened it. Could it have blown off from pressure? Could the pump be bad? It has a steering box that was replaced due to leaking a few yrs ago. Any thoughts?
Re: Bad steering [Re: ridgerunner] #4899325 10/18/18 08:06 AM
CT8 Offline
Have you looked for oil?
2015 F150 2.7
2018 F350 6.2
Re: Bad steering [Re: ridgerunner] #4899338 10/18/18 08:19 AM
dadto2 Offline
I have this problem in my Volvo, I'm almost certain that it's the U joint between the upper and lower steering columns. I can feel it sort of bind as I turn the wheel. When I get the motivation, I'm going to remove the boot and soak with penetrating oil to see it that helps.
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: Bad steering [Re: ridgerunner] #4899724 10/18/18 05:40 PM
V
VeryNoisyPoet Offline
V
^^^ THIS ^^^
Clean and lube the u-joints before suspecting the expensive components.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Bad steering [Re: CT8] #4900029 10/19/18 04:43 AM
R
R
Yes. There is some around the fluid res. from sloshing when the cap blew off is all. All hoses etc are clean.
