Originally Posted By: A_Harman
Hi miami993,
How did the Redline 10w40 hold up?
{Wow, my 3000th post!}
Hi A_Harman,
In page #2 of this thread I was writing:
-The Vacuum value at idle is steady as ever with or without AC.
-Engine noise is drastically disminished.
-Oil pressure is 4 PSI higher in any condition.
-For the first time ever, I can start the AC at iddle in any condition without entering the Stall Saver mode...
What I have as a fact today is a impressive noise reduction, from the valve-train and from the piston rocking.
Check the video above, as if it is a video and is no scientific demonstration there, the idle noise is quite exceptional for this type of engine.
To tell you more about engine wear, tear down will tell the day it will happen (I try to make that day the latest possible)
Another subject that is showing an improvement in term of "sealing" in this engine is shown in the video below.
This is a start from the car after a full month (August) inside the Florida garage (really warm) without any rotation from the crankshaft for 30 days.
I was very impressed on the Oil Pressure building up...faster than all other lubricants I used in this engine during the last 2 years:
Christian
