ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
97 registered members (5AcresAndAFool, 53' Stude, 4WD, 97prizm, 55hambone, ABCarr, 10 invisible), 2,593 guests, and 64 spiders.
Topics306,063
Posts5,286,666
Members71,593
Page 1 of 3 1 2 3
Fumoto drain valve-a few concerns #4898035 10/16/18 03:56 PM
J
Joeescape63 Offline OP
J
I'm sure this has come up in the past.I am leasing a 2018 Subaru with the 2.5L engine and I would like to add a Fumoto oil drain valve to make the job of changing my oil cleaner and maybe a little quicker.My concerns with the valve are leaking and construction.I know there must of been a few that got past quality control but for the most part most leave the factory the way they should.Do you get most if not all of the oil when draining?The Valve is made of brass.With hot/cold temperatures can the valve crack/split to allow leaks to happen?Alot of people like them.thanks Joe
2018 Subaru Forester Touring
2.5L engine/CVT
Subaru Filters/Castrol Edge 0W20
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898041 10/16/18 03:59 PM
gathermewool Offline
I've had one on each of my vehicles for the past decade. The only leak was the first one, when I only snugged it up. Tightened it properly at the next oil change and not a single issue from then on!
Fumoto runs special pricing near Black Friday. For Amazon, keep an eye on the price using camelcamelcamel.com
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898047 10/16/18 04:07 PM
StevieC Offline
I have 9 of them in use in our families vehicles and have only had issue with 1 shortly after installation that would drip every so often and the company warrantied it. This was over 10 years ago and I haven't had any issues since. The valves are made of high quality brass and have stainless steel parts inside. They stand up well to all the salt on our roads in the winter.
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898050 10/16/18 04:11 PM
J
JustN89 Offline
J
I have one on my Elantra and have no issues with it. It's been on for nearly 20k miles now.
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898056 10/16/18 04:28 PM
K
Kira Online Content
Online Content
K
Way back ('70's?) they were taboo because they leaked occasionally. Today they're made of "today's materials".
The consideration is vulnerability. I put one on my neighbor's 2010 Accord 4 cyl. and it is in the shadow of many parts thus protected.
The configuration of my car would leave it sticking down unprotected so I will never have one as much as i want one.
Oh well....
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898079 10/16/18 05:28 PM
T
Tornado Red Offline
T
I installed a Fumoto valve on one of my cars. Even with the engine and oil hot, it was taking so long to drain that I closed it off and went back to using a topside extractor.
'03 Golf TDI, 801k miles: Bosio DLC764, GT1749VB, Malone Tuning, G60/VR6 clutch/flywheel, Bilstein HD, Recaros, Akebonos, Brembos, Pirellis, DG Panzer & FMJ, Delvac 1 5W40
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898093 10/16/18 05:50 PM
svhanc Offline
I have never had an issue with one leaking.
I would recommend only using one if the location is well protected from road debris.
I have had one on my Tacoma since new (almost 150k) and on our XJ Cherokee for about 40k
They do take a little longer to drain, but I just walk away and come back later or sit down and drink a beer. No hurry.
2010 Toyota Tacoma 4x4 2.7 5spd ([email protected]&Fram [email protected])
2001 Jeep Cherokee XJ 4.0 Auto ([email protected]&Fram [email protected])
2007 Suzuki SV650N
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898102 10/16/18 06:00 PM
T
TheLawnRanger Offline
T
The Hindenburg had a Fumoto.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Fumoto drain valve-a few concerns [Re: TheLawnRanger] #4898121 10/16/18 06:21 PM
M
MONKEYMAN Offline
M
Along those lines I had one on my Saturn and burned valve #3 and replaced the motor. Had no relationship to the Fumoto valve that worked flawlessly. One SaturnFans member used one over 500k on his Saturn and 500k on a Volvo with no issues. One reason I started using one.
I use something similar now called EZ Oil Drain Valve. It was a little cheaper and works just as good as Fumoto. My Fumoto did leak on the second Saturn motor but a new gasket fixed that.
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Fumoto drain valve-a few concerns [Re: MONKEYMAN] #4898129 10/16/18 06:32 PM
T
T
Just razzing the Fumoto fanatics. They seem to work well.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Re: Fumoto drain valve-a few concerns [Re: TheLawnRanger] #4898142 10/16/18 06:54 PM
K
Kage860 Offline
K
I heard the Hindenberg was also using a Purolator filter, and they were extending their oci without using uoa.
2007 Jeep Liberty PP 0w-20 / Carquest Blue, 6k oci
2015 Nissan Rogue PP 0w-20 / Pronto, 5k oci
2019 Audi Q7 - Castrol 5w-40 / OEM Filter
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898198 10/16/18 08:09 PM
G
gman2304 Offline
G
You’re leasing this vehicle, and considering installing a Fumoto valve?
Re: Fumoto drain valve-a few concerns [Re: TheLawnRanger] #4898221 10/16/18 08:40 PM
M
MONKEYMAN Offline
M
They do have downside like oil draining slow.
The last oil change I opened my EZ Valve with engine warm and took a nap. On my car I can just reach under and open it even though it is protected by a plastic cover.
2017 Elantra SE
Re: Fumoto drain valve-a few concerns [Re: Joeescape63] #4898222 10/16/18 08:40 PM
StevieC Offline
He can take it with him and re use it.
Re: Fumoto drain valve-a few concerns [Re: StevieC] #4901230 10/20/18 03:03 PM
Agreed.
I typically slide the pan in, reach under to open the valve (without having to remove any plastic under-trays), and then walk away to take care of other chores for an hour or two. Works nicely and minimizes the time I'm wasting, watching that stupid thing drizzle....then lightly drizzle...then rapidly drip...then slowly drip...you get the point.
And it's not like this is a vehicle with 10k OCI's. Depending on the lease length, he could be changing the oil 5 times or more by the time he turns it in. $2X.XX for something like this seems totally worth it, considering all of the other crap I buy that provides less benefit...
Page 1 of 3 1 2 3
