Originally Posted by jhellwig
Originally Posted by Nyogtha
It would typically be anhydrous 99% purity monimum before adding debaturant, which is typically natural gasoline (condensate, "drip", white lightning of the gasoline world) for ethanol destined for gasoline blending. However I'm unaware of snt ethanol tank, barge, railcar, truck trailer, etc. gas blanketing for ethanol used in gasoline nlending, same as for gasoline itself whether blended with ethanol or not.
There have been papets on using ethanol purified simply by distillayion used in gasoline blending, but they miss the main negative issues such as phase seperation from what I saw.
https://www.google.com/amp/s/fieldt...ydrous-ethanol-in-gasoline-blending/amp/
The ethers used in gasoline blending are not anhydrous but aren't subject to phase seperation, such as MTBE, ETBE, & TAME.
It is more pure than 99%. I don't remember the numbers from when I worked on instrumentation in an ethanol plant but I think before the mol sieves it was over 95% and after was way higher than 99%. The final product proof meter I think only had a .3% span on it. It is stored in tanks with floating roof in plants and larger terminals so there is almost no air contact on it.
There is a spec out there on what percentage the denatureant has to be but I think it might be below 1%
Did you read the either my post or the linked paper in my prior post? Minimum 99% is just that, the minimum.
RIN's are a HUGE driver in ethanol blending, well eclipsing replacement for MTBE in air quality non-attainment areas. This is what drives some refiners to stop blending conventional 87 (R+M)/2 regular unleaded gasolime, and drives a LOT of the differential price between conventional 87 (R+M)/2 gasoline.
It's been 6 years since I retired and the RIN drivers only increase under the RFS. I live in the 7th largest city in the US and the only such major metropolitan area not yet declared an air quality non-attainment area. No vapor collection systems on retail gas pumos here yet. But E10 is everywhere, conventional regular unleaded gasoline is difficult to find and pricey relative to E10 regular due to RINs, not refinery blending capability.
