First generator
by daves87rs - 05/31/20 01:50 AM
New junk tool
by P10crew - 05/31/20 01:07 AM
tetraethyl lead additive
by painfx - 05/31/20 12:40 AM
Best handheld cordless vacuum?
by montero1 - 05/31/20 12:15 AM
2005ToyotaSolara3MZ-
FE coolant leak
by juca - 05/30/20 11:22 PM
I made a dually today. Carftsman LT1000
by ls1mike - 05/30/20 10:39 PM
New Prestone Products
by Snagglefoot - 05/30/20 09:17 PM
BEST OBD2 scanner for UNDER $100
by flinter - 05/30/20 08:44 PM
Oil Drain vs Extraction
by js1956 - 05/30/20 08:08 PM
Toro SR Won't Stop Running
by jkasch - 05/30/20 08:05 PM
Lexus RX350 Oil Filter Housing Question (with pic)
by CrackyWainwright - 05/30/20 07:57 PM
Oil Filter and Coolant Question
by maverickfhs - 05/30/20 07:33 PM
Second change on rebuilt LS
by KirklanC - 05/30/20 07:05 PM
Certified Used Toyota; 8 miles.
by simple_gifts - 05/30/20 05:47 PM
Motul Specific LL01-FE 5w-30 for BMW S55
by sharpmoney - 05/30/20 04:36 PM
Thinking of Buying Compressor
by Mr_Luke - 05/30/20 04:16 PM
juca, jrow96, Kotsos, sharpmoney, Dermented
71581 Registered Users
21 registered members (Anduril, carlprop, bachman, blufeb95, ctechbob, 92saturnsl2, 1 invisible), 1,305 guests, and 32 spiders.
Topics306,071
Posts5,285,874
Members71,581
2019 Honda CB300R Factory Fill #4884912 10/01/18 07:48 PM
J
Jay Offline OP
J
Lab: Western States Caterpillar
Date: 19 Sept. 2018
Miles on Oil: 760
Miles on Bike: 760
Cu 10
Fe 22
Cr 1
Al 20
Pb 0
Sn 0
Si 32
Na 9
K 5
Mo 2
Ni 2
Ag 0
Ti 0
V 1
Mn 4
Cd 0
Ca 1952
P 1003
Zn 972
Mg 17
Ba 59
B 171
V @100C 8.2
ST 0
Oxi 8
Sul 19
Nit 6
W N
A N
This is factory fill which was presumably 10W-30 Honda GN4 oil which is Honda's recommended oil for this engine. Honda recommends changing the oil/filter initially at 600 miles. Thereafter, 8kmi intervals. The only thing noteworthy that I spot is that it has sheared out of grade.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4885105 10/01/18 11:42 PM
R
Reddy45 Offline
R
The additive numbers make me think it's basically a newer oil with slightly elevated ZDDP and detergents.. nothing special. Your wear numbers look about average for most factory fill analyses.
As for the grade -- I'm starting to think that the engineers spec a thicker weight on purpose with the knowledge that it'll shear down by the time you change the oil. Seems like Honda has no concerns about engineering their bikes around thinner oils.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4885357 10/02/18 10:43 AM
B
bulwnkl Offline
B
Honda’s GN4 oil is reasonably low quality is all. ;-)
OP, I expect that your CBR will run well and last a long time. I don’t personally care for Honda GN4 oil, at least for the price they want, but lots of bikes run on it and seem to be okay.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4886313 10/03/18 10:15 AM
J
Jay Offline OP
J
Honda is fairly generous in its oil recommendations. They say pretty much any SN oil will do as long as it's 10w-30 and non energy-conserving or resource-conserving. I'm using Chevron Delo 400 10w-30 XLE in it now. This is a multi-fleet oil that meets SN and a number of diesel designations also. I noticed a distinct improvement in shifting after the switch.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4887094 10/04/18 10:31 AM
sunruh Offline
vanadium ??? really?
barium?
that much manganese?
ummmmm, where is the unobtanium?
and a CsT of 8.2 is....well close to water its 20wt
motorcycle oil myth buster
Re: 2019 Honda CB300R Factory Fill [Re: bulwnkl] #4887332 10/04/18 02:22 PM
E
eddy21 Offline
E
They didn't test well years ago .
15 Fiesta ST
Re: 2019 Honda CB300R Factory Fill [Re: sunruh] #4887352 10/04/18 02:38 PM
Brian553 Offline
barium?
Has anything that shows up less than 10 every been significant enough to confidently say it's real foreign substance in the crankcase? (apart from silicon)
I always assumed it was just noise
Re: 2019 Honda CB300R Factory Fill [Re: Brian553] #4887975 10/05/18 08:18 AM
sunruh Offline
barium?
in my own personal testing, the 1st time that Ti showed up, i pulled the head to find the Ti valves tuliping. the value was 2
now, usually, yes its just scatter noise. which means its not been calibrated very well. or is just a poor unit to begin with.
which means only 1 thing: are your test results worth a darn?
so does the value mean anything? it all depends on if you want to believe your results.
if you do believe them, then you need to investigate it.
if you do not believe them, why do the test?
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4890147 10/07/18 03:10 PM
Dyusik Offline
Interesting to see ZN/P levels inverse of what you normally would find. Who knows what other phosphorous additive might be used?
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 21K RT6 15w40, XG7317
18 RAM 3500 15k Delvac 15w40, DBL7349
96 Cherokee
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4896719 10/15/18 03:31 AM
Z
ZeeOSix Offline
Z
Sheared out of grade in 760 miles ... Wow. Wonder if it was some special factory oil and not actually a 10W-30.
Re: 2019 Honda CB300R Factory Fill [Re: Jay] #4897426 10/15/18 09:20 PM
B
bulwnkl Offline
B
Not likely. Honda's GN-4 oil is not a particularly shear-stable fluid. IMO it's not really a particularly good quality fluid at all.
