Originally Posted by Mr Nice
Originally Posted by rooflessVW
Originally Posted by SeaJay
What does it take to install a set of tires, 20 minutes or so? If that is correct, $25 translates to $75 an hour. Enough for a shop owner to make a living, not enough to get rich.
Have you ever installed tires before? Guessing not.
If you're knocking out 4 tires mounted and balanced in 20 minutes, you'd make plenty of money - you might even be worth $75/hr!
Yeah. 20 minutes if NASCAR crew did the M & B of 4 tires.
I can't even imagine how difficult it would be to mount race tires with inner safety liners, even though they are 15 inch steel wheels. And balanced to run over 200mph.
The worst tires I've ever worked on were 15 in Goodyear cantilever sidewall road racing slicks. A 10 inch wide race tire built to fit on a 7 inch wide wheel. Easy mounting apparently wasn't part of their design parameters.
