Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
VIDEO: Degreasing cast aluminum engine parts!
by dwcopple - 03/28/20 01:37 PM
Was I charged a fair price for welding exhaust?
by atikovi - 03/28/20 01:24 PM
McKee’s 37
by buster - 03/28/20 01:21 PM
1990 Toyota 4x4 transmission fluid type
by R1jake - 03/28/20 01:08 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
43 registered members (blufeb95, BlueOvalFitter, carlprop, c502cid, 2010Civic, 6 invisible), 953 guests, and 18 spiders.
Topics303,300
Posts5,233,491
Members71,038
Page 5 of 6 1 4 5 6
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4894602 10/12/18 10:35 AM
E
Eddie Offline
E
I wouldn't purchase a "Hobby" vehicle where I need to be concerned about extra oil changes, special valve cleaning regiments and the like. I would wait until HONDA gets their act together. Meanwhile, I'll enjoy my CX5 DI engine that has shown no fuel dilution over a few tenths over three UOAs. Ed
2014 CX5 Touring 2.5L :-)
Re: 1.5L Honda turbo oil dilution [Re: Eddie] #4894972 10/12/18 06:44 PM
O
oil_film_movies Offline
O
Its not that bad. Really all these fuel diluting 1.5T owners need to do is keep the oil near the half-way point, between Add & Full, then in about 4,000 miles into the oil change interval, put in a cup of either STP Oil Treatment (200 cSt KV100) or Schaeffer #132 Moly EP Engine Oil Treatment (238 cSt KV100) thick goop, both very mixable and not harmful, meant to be compatible. Put in another cup at the 8,000 mile point if going the full 10k miles on the oil change. Keeps the visc up where it should be.
Also, this lets you document the use of Honda-spec 0w20 in case they want to get nutty about engine failure warranty claims, if it happens.
If Highkm the OP (with 5.6 cSt KV100) would have done this, he would have ended up with about ~7.5 cSt at the end, enough to keep the Stribeck curve contented.
Re: 1.5L Honda turbo oil dilution [Re: oil_film_movies] #4895157 10/12/18 10:19 PM
Danh Offline
Even if viscosity were the only measure of lubricant effectiveness (it isn’t: my grandmother’s pea soup had a cSt of probably 20-something), what are the odds of the average Honda owner doing as you suggest?
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4895471 10/13/18 12:50 PM
O
O
Danh, granted there is a possibility all that extra fuel (up to 20:1 we've seen) might create blacker pistons, no doubt. That's probably about it. Oil has dispersants and cleaning chemicals that do their job. I wouldn't worry too much about fuel dilution as long as one is nudging viscosity upward a bit, using one of the thick liquids I listed above.
As for the "odds of the average Honda owner" putting in a thick liquid to prop viscosity up, according to wear results we've seen on UOAs, Fe ppms, these engines still basically do OK with thin oil if they don't top off. ... Topping up with occasional thick liquids is just more insurance I think.
And, when you read what bitog poster MolaKule revealed on old posts about Schaeffer Moly EP #132 oil treatment, its ester, antimony EP/AW, and a little moly, with dispersants to fight fuel gremlins, preferable over the STP cheaper stuff.
Re: 1.5L Honda turbo oil dilution [Re: Eddie] #4895763 10/13/18 08:56 PM
A
Artem Offline
A
I think Eddie said it best, below. No way will I buy a vehicle that is 100% a nightmare to maintain past the warranty period and all this activity costs me a kidney or two to fund. <— Forget that nonsense. I’ll let your average Joe play the test rat game with these manufacturers and their new technology that nobody asked for.
The days of producing a simple, clean running durable engine was done in the 90s. Honda’s D and B series engines come to mind.
I hesitated buying my 2014 Mazda 3 due to the Di fuel delivery but since Mazda’s Skyactiv engine design showed no problems since it was introduced in 2012, I felt confident enough to take my chances on it with the 2014 model. It’s been an excellent car thus far @ 72,000 miles. Just oil changes.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 1.5L Honda turbo oil dilution [Re: Artem] #4896104 10/14/18 09:13 AM
W
webfors Offline
W
Fuel dilution is only one variable. Mazda is not immune to intake valve deposits. All of us can ignore the issues and pretend they aren't there, and I'm sure we'll all get 100k+ miles of relatively trouble-free service from our engines.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: 1.5L Honda turbo oil dilution [Re: webfors] #4896118 10/14/18 09:28 AM
A
Artem Offline
A
Hey, if after 100k miles of use, these engines now require an intake manifold removal and walnut blasting the intake valves in order to get another 100k of use, and this is now consisted “normal” and the direction the auto industry is going, then this should be stated loudly and proudly in the service manual, so potential buyers can anticipate the cost and down time into the overall cost of ownership.
If this new tech give an extra 1mpg gain but costs $1,500 in maintenance some 60,000 miles later, how does that make ANY sense at all? I’d settle for 0.5mpg gain and save the walnuts for something else. Lol
Re: 1.5L Honda turbo oil dilution [Re: Artem] #4896204 10/14/18 11:57 AM
W
webfors Offline
W
Agreed.
Or run a $10 bottle of CRC Intake Valve cleaner every 10k. I was anti-DI until I drove a few... more power/torque/responsiveness and more mpg. It's worth a little extra maintenance IMO. You're going to run out of options to avoid DI unless you keep buying progressively older cars grin
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4896603 10/14/18 09:17 PM
Smokescreen Offline
...^^ and that is my plan until more cars come out that have addressed the problem...after which I may then obtain one.
13 Civic Si 2.4L-105Kkms(66Kmi)-QSUD,Wix
05 LeSabre 3.8L-294Kkms(184Kmi)-QSUD,Wix
03 Sierra 2500 6.0L-209Kkms(130Kmi)-QSUD,Wix
All with mpg > EPA
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4896749 10/15/18 06:34 AM
E
Eddie Offline
E
I would add that many engines don't have fuel dilution issues to the extent that HONDA does. Back to the drawing board HONDA. Ed
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4896874 10/15/18 09:37 AM
Schmoe Offline
I disagree. The only news you read on social media is the bad news. You know how many 100' of thousands of folks with the CRV are totally happy with it???
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: 1.5L Honda turbo oil dilution [Re: Schmoe] #4896882 10/15/18 09:51 AM
Danh Offline
Maybe, but considering most owners never open hoods or check their oil these days, fuel dilution typically doesn’t result in a car that doesn’t work and 98% of owners have no idea what fuel dilution is I’m not sure that’s a good gauge either.
Here’s what you can do: look through the UOAs for Honda 1.5Ts that are posted here. See how many you can find with fuel dilution less than 5% if measured by gas chromotography (e.g. Oil Analyzers) or have viscosity trashed (Blackstone). I’ll save you the trouble and provide the answer: 1.
Fuel dilution is common with DI/TGDI engines but Honda seems to be about the worst offender. Mazda and Ford had early issues but made changes pretty quickly. Honda hasn’t.
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4916099 11/05/18 11:03 PM
K
kr_bitog Offline
K
I think Honda has admitted the fuel dilution mostly happen during winter time where the engine does not heat up the oil pan enough to evaporate all the fuel diluted in the oil. So if you are not short tripper then the problem should not be severe
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4936713 11/27/18 12:41 PM
dbier Offline
Wow! I just bought a 2018 CRV after reading about the great safety ratings - now I just stumbled across this issue.
My son noticed right away this past weekend (28 degrees out) that it took a very long for the CRV temp gauge to rise - and it would drop while sitting at a stoplight. I've read that Honda is going to do some recall tweaking to try to get the engines to warm up faster and higher (starting to roll out in 5 states this December) - but in the meanwhile I plan to change my oil every 3,000 miles in winter and 5,000 miles in summer. Also, I noticed that if I use S (SPORT) instead of D (DRIVE) the increased revs warms the engine up much faster - so I plan to use S at least in during initial winter warm-ups.
Hopefully these precautions will help (let me know your thoughts) - but it really sucks that I have to think about this on a car bought 4 days ago!
Re: 1.5L Honda turbo oil dilution [Re: parshisa] #4937871 11/28/18 03:15 PM
J
john_pifer Offline
J
Originally Posted by parshisa
How did the level look like on the dipstick? How much have you drained? I bet it was over 4qts. Just run premium gasoline and real synthetic oil and fuel dilution will be almost gone.
What's your point in saying to use premium? Are you implying that there will be less pinging/knocking on premium, and, therefore, the ECU won't run the mixture as rich, resulting in less fuel contamination?
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 225K
18 Civic HB 1.5T 6MT (Fiancee's) - VME 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Page 5 of 6 1 4 5 6
