2.7 Ecoboost Reliable in F150 ?
by LoneRanger. 06/20/19 08:14 AM
Extension cords.
by Chris142. 06/20/19 08:01 AM
Bridge Loan - Mortgage Loan Need Advice
by Dwight_Frye. 06/20/19 07:36 AM
15 Tacoma 4.0L 1GR-FE 7.5k OCI 5w-30
by Danimal1q2w3. 06/20/19 07:35 AM
Powerstop drilled/slotted + Wagner OEx
by DriveHard. 06/20/19 06:51 AM
Oil flow and Vehicle start with oil cap off.
by BMWTurboDzl. 06/20/19 06:49 AM
2012 chevy equinox with 121,xxxx
by Robw. 06/20/19 06:31 AM
F1 - 2019 French Grand Prix
by gofast182. 06/20/19 06:17 AM
Yard rollers
by dlundblad. 06/20/19 05:20 AM
EP Auto?
by HowAboutThis. 06/19/19 11:13 PM
Rear Wheel Bearing Replacement?
by Gebo. 06/19/19 10:37 PM
Coolant in Oil?
by Score294. 06/19/19 10:34 PM
The cool people of Bitog
by Marco620. 06/19/19 08:52 PM
How do Adjust Your Seat and Mirrors
by buster. 06/19/19 08:37 PM
AC for hybrid and electric vehicles
by JimPghPA. 06/19/19 08:06 PM
Mobil 1 sold at Walmart vs Summit Racing
by kosoku. 06/19/19 08:02 PM
HiqhWoltage, StiffUpperLens, hotmojo, DesertTech, Jamie_E_M
68441 Registered Users
92 registered members (ARCOgraphite, Alfred_B, 77GrandPrix, 53' Stude, Anduril, 2004tdigls, 9 invisible), 1,859 guests, and 27 spiders.
Topics290,698
Posts4,991,117
Members68,441
Most Online2,967
Mar 10th, 2019
Centric C-TEK 121 Economy Rotors #4893331
10/10/18 07:38 PM
10/10/18 07:38 PM
CA
The Critic Offline OP
CA
I posted about this in the humor section for a different reason, but the Centric 121 C-TEK economy rotors are Centric's equivalent to the infamous "whitebox" economy rotors that are sold by many parts stores.
Normally I do not use whitebox economy rotors, however, this brake job was for a lease return and the driver wanted to minimize their costs. The driver did not mind the rusty appearance from unpainted rotors.
This was the first set of economy rotors that I had used in over two years. After properly cleaning the hub flanges, washing the rotors and installing them with conical washers, I measured the lateral runout values and found the following:
L/F = .001"
R/F = .0015" (after indexing, first try yielded .0025")
L/R = .0005"
R/R = .002"
This particular vehicle (2016 Outback 3.6R) allows a max of .002" so all of the values were within spec. From my past experience, economy rotors typically have .003"-.004" of runout and this was simply too much for most modern vehicles. Resurfacing rotors on a bench lathe usually results in .004"-.007" of runout.
Either I got lucky, or I guess economy rotors have gotten a lot better in the last few years. I was a bit blown away. If economy rotors are consistently this good and the driver is on a budget (can't afford or does not want to pay for premium rotors), then economy rotors have truly become a viable low-cost alternative to resurfacing your old brake rotors. The finish felt reasonably smooth as well, and the pads bedded in fairly quickly. I paired these rotors with Akebono ProACT pads on the front axle and Centric 105 PosiQuiet Ceramic pads on the rear axle.
Also, nthach came by and watched me do this brake job. He's cool.
2011 Toyota Prius 1.8L - 190K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893345
10/10/18 08:02 PM
10/10/18 08:02 PM
Hawaii, USA
anndel Offline
anndel  Offline
Hawaii, USA
Good enough!
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil XL 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893365
10/10/18 08:27 PM
10/10/18 08:27 PM
Arkansastan
Propflux01 Offline
Propflux01  Offline
Arkansastan
And I think you will like those Akebono pads. I am impressed withe 40K I have on mine so far.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893375
10/10/18 08:33 PM
10/10/18 08:33 PM
Jacksonville, FL
FlyNavyP3 Online content
FlyNavyP3  Online Content
Jacksonville, FL
On a lease return I would've been tempted to put the cheapest pads known to man on that Subaru. You're a better man than me. Nice work and excellent run out numbers for budget parts!
Luke
Re: Centric C-TEK 121 Economy Rotors [Re: FlyNavyP3] #4893396
10/10/18 09:02 PM
10/10/18 09:02 PM
CA
CA
The car is getting returned in Dec.
Thanks.
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893405
10/10/18 09:15 PM
10/10/18 09:15 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Very nice!!!
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893561
10/11/18 04:00 AM
10/11/18 04:00 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
I have used C-TEK rotors(and pads) with good success. I have also use DURAGO rotors as well with the same success. But, this success is also based on the vehicle that they're being installed on. In other words, I had good success with them on a lower end MAZDA and mid level NISSAN. However, I've had even better success with them on a LEXUS. So, it depends on the car & rotor manufacturers spec of the rotors, is how well you'll do with them.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Centric C-TEK 121 Economy Rotors [Re: FlyNavyP3] #4893666
10/11/18 08:15 AM
10/11/18 08:15 AM
Ohio
hallstevenson Online content
hallstevenson  Online Content
Ohio
I was thinking the same thing. It's not to be cheap or a sh***y person either, it's just not necessary for someone returning a leased vehicle to do at the end of a lease.
Re: Centric C-TEK 121 Economy Rotors [Re: hallstevenson] #4894377
10/12/18 01:35 AM
10/12/18 01:35 AM
CA
CA
Sure, I understand where you are coming from. But I also will not put my name on a substandard brake job. The owner would have preferred to not do the brakes at all, but the rears were grinding and the fronts were at 1mm.
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4894507
10/12/18 08:55 AM
10/12/18 08:55 AM
Ohio
Ohio
How did you get involved ? Was this a friend's car that you did in your garage or driveway or do you have a repair shop ? If you use parts specified by the customer and do a proper, quality brake job, I wouldn't consider it "substandard" in any way.
Re: Centric C-TEK 121 Economy Rotors [Re: Char Baby] #4896654
10/14/18 10:40 PM
10/14/18 10:40 PM
out there
spasm3 Offline
spasm3  Offline
out there
Originally Posted by Char Baby
I I have also use DURAGO rotors as well with the same success.
Glad to hear that! I just ordered some DURAGO coated rotors from RA for the hyundai. Going with the centric stoptech street pads 308.15430.
Will see how they do.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4896659
10/14/18 10:59 PM
10/14/18 10:59 PM
USA
slacktide_bitog Offline
USA
Basically the same as Centric Premium but without the coating.
The C-Tek will probably be ok for awhile since you're lucky enough to not have rust (on the east coast, non-coated rotors rust overnight), but they are NOT usable anywhere up north where you get rust.
Re: Centric C-TEK 121 Economy Rotors [Re: slacktide_bitog] #4901208
10/20/18 02:30 PM
10/20/18 02:30 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Ouch. There is a local race-oriented machine shop that does much better than that. But your average brake and muffler shop, yeah, I can believe that.
I'm sure I've opined on here before, that if new rotors pass parallelism (usually) and runout (sometimes) tests, then good enough is good enough. Rust is another issue. C-Tek is usually within the spec that you can find on the RockAuto site. I have a set of Centric C-Tek's on my Corolla, that are at 4 years 2 months and 76K miles and doing fine. The pads are about done, though, I just bought their replacements, and plan to put them on this coming week.
Surface rust on the friction surfaces happens on coated rotors overnight as well, because the coating is toast on break-in, and it's just as harmless on coated as it is on uncoated rotors.
It's the rust from the edges and ventilated back side eating its way through that is the hazard. My experience in heavily salted Maryland (we may not have all of the snow, but due to Winter-long freeze/thaw cycles, we have all of the salt) is that coated rotors give you one more year before this happens, but it still takes 4-6 years. If you are putting 20K+ a year (as we do) on your vehicle, you'll get your money's worth out of an uncoated rotor (60-80K miles). If you drive 10K or less a year, or just prefer a nicer appearance, a coated rotor is a worthy upgrade.
Various musings: http://hangfire.net
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4902106
10/21/18 03:22 PM
10/21/18 03:22 PM
CA
CA
Apparently, the owner decided to return the car early and the car is now being marketed as a CPO unit on the dealer’s lot.
I am curious if the dealer had to re-do the brakes before sale since they were not OEM Subaru.
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4902151
10/21/18 04:09 PM
10/21/18 04:09 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
If the dealer links a Carfax report to the car it may show whether they did a new brake job to it or not. My guess would be they left it as-is.
