Pecan Pie Cheesecake Recipe
by GumbyJarvis - 04/06/20 05:03 AM
Dewalt DXCM251 25-Gal Oiled Air Compressor
by The Critic - 04/06/20 03:40 AM
Windows File & Folder Fix Tool
by ZeeOSix - 04/06/20 01:53 AM
$.25 washer fluid at WM
by joel95ex - 04/06/20 12:13 AM
`16 Suburban OLM never tripped due to time
by zfasts03 - 04/05/20 11:26 PM
Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
KebabDad69, KMoJo, F7daved, khouan, daniell
71108 Registered Users
98 registered members (alarmguy, 4WD, AndyB, Amkeer, 2015_PSD, alchargo, 9 invisible), 1,795 guests, and 19 spiders.
Topics303,661
Posts5,239,389
Members71,108
Page 2 of 2 1 2
Re: 2017 Altima extended oci [Re: cals400ex] #4895303 10/13/18 07:03 AM
demarpaint Offline
Originally Posted by cals400ex
Since I’ll be under warranty for ~6 more months, I’ll follow the manufactures recommended oci. After that, I may try an uoa and try to extend the oci, if possible....I’m just trying to avoid getting an oil change ever two months if I can.
Speaking of brake fluid, why does it need changed so frequently?
Good idea to wait until the warranty is up, then go for whatever you like. Regarding brake fluid changes, I do it every two years. Me I'm not a fan of 10K OCI's or longer, in fact I wouldn't buy a car from a person who ran oil that long in this neck of the woods. But as the saying goes, "to each his own."
God Bless Our Troops
Re: 2017 Altima extended oci [Re: cals400ex] #4895408 10/13/18 10:47 AM
sir1900 Offline
Does the longer filter provide any benefit? Maybe if one were wanting to extend their oil change interval?
The longer filter provides a small amount of additional filtration media. There are no benefits nor are there any downsides to using one.
2015 Infiniti Q50
Mobil1 5W-30 + FRAM PH6607
2015 Nissan Murano
Mobil1 AFE 0W-20 + Mobil 1 M1-108A
Re: 2017 Altima extended oci [Re: cals400ex] #4895441 10/13/18 11:38 AM
Spector Offline
Interesting discussion on tiny Nissan filters. . I do oil changes on sons 2006 Altima 2.5 and it has a tiny filter. I change the oil twice a year, basically when I see the vehicle, June or so and December using primarily Mobil 1 EP 5W30 or Pennzoil PP. The OCI is anywhere from 6,000-8,000 miles and he now has 190,000 on it and not really using any oil (not using a HM oil) and either Mobil 1 or Nissan filters. The transmission has had multiple drains and fills with Amsoil ATF, never have dropped the pan.
Only issue now is a head gasket that when engine gets cold (primarily winter months) tiny cracks in head gasket that open overnight permit coolant to seep into cylinders and burn coolant at start up. No other coolant leaks, tests negative so head gasket. Going to try a sealer this winter to stop the overnight consumption of coolant but otherwise still runs fine. Had a similar problem in Camry and sealer did the trick with an old head gasket.
Also, have reams of paper on UOA from eyars ago I concur with above comment that UOA are basically useless, you need a lot of them to establish a trend and in the end, really nothing you can do about the wear except change oil more often and that is not really a cure, just less wear metals showing up.
Re: 2017 Altima extended oci [Re: cals400ex] #4895449 10/13/18 11:58 AM
J
JTK Offline
J
How many miles per year do you drive? What type of driving? With our 2016 Nissan Quest with the QV35DE engine, I change oil/filter at 6-7K miles. We do ~20K miles/year with basically no short trips or excessive stop/go.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2017 Altima extended oci [Re: cals400ex] #4901770 10/21/18 08:52 AM
cals400ex Offline OP
My driving is ~20% in town and ~80% highway. I’m generally easy, meaning, minimal rapid accelerations, etc. I’m not in dusty or harsh conditions. But, the temperature here in the Midwest can be well below freezing to approaching 100 degrees depending on the season. I generally drive around 30k miles per year.
Page 2 of 2 1 2
