15w40 in my automatic trans.
by Ursatdx - 09/17/19 03:16 PM
Update on my Stihl BG 86
by 1978elcamino - 09/17/19 03:11 PM
Offset print oil
by Matt_Pill - 09/17/19 03:06 PM
Which 508.00 oil would you choose?
by Vigg - 09/17/19 02:55 PM
Any BMW LL04 recommendations?
by M3m3x5 - 09/17/19 02:18 PM
5W30 Suggestions/Subaru
by Motoretro - 09/17/19 02:18 PM
Recommend Costco tires
by henni - 09/17/19 01:58 PM
Castrol SRF Shortage
by kyoo - 09/17/19 01:26 PM
All aftermarket drums and shoes = junk?
by nthach - 09/17/19 12:38 PM
Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX
by 05UFCaptain - 09/17/19 11:51 AM
TPS only seeing 3.7v at WOT
by joegreen - 09/17/19 11:39 AM
Granite Countertops Are Magnetic. Who Knew ?
by Dwight_Frye - 09/17/19 09:44 AM
2019 J.D. Power VDS
by buster - 09/17/19 09:05 AM
Possible to add catch can?
by cwilliamsws6 - 09/17/19 09:02 AM
Update on GF-6
by buster - 09/17/19 08:40 AM
motul eco-lite 5w30
by avi1777 - 09/17/19 07:47 AM
Hyundai sonata 2.4l burning oil
by Grambo - 09/17/19 07:22 AM
Mazda CX5 2.5 oil question
by Tallman - 09/17/19 06:54 AM
Can I use 10W40 gtx HM in cold winter like -5F?
by Cheburashka - 09/17/19 06:43 AM
BMW Longlife-04: Evolving Performance Requirements
by Bjornviken - 09/17/19 06:40 AM
thetransman, SamBilbrey, williamfoster060, kappa8, jayrod65
69308 Registered Users
99 registered members (4WD, 1978elcamino, 03s, 2004tdigls, 007, 72sub, 16 invisible), 2,365 guests, and 33 spiders.
Topics294,693
Posts5,064,706
Members69,308
Most Online3,532
Jul 30th, 2019
2017 Altima extended oci #4894343 10/11/18 10:59 PM
cals400ex Offline OP
I have a 2017 Altima 2.5. I’m looking to go as long as reasonably possible using an “off the shelf” synthetic oil (Mobil 1, Pennzoil, etc.). What is generally considered the longest you should on an oil change with these oils? 7.5k miles? 10k miles?
Re: 2017 Altima extended oci [Re: cals400ex] #4894346 10/11/18 11:12 PM
M
madeej11 Offline
M
10k is good normally but you'd first want to do a UOA to see if it can be stretched that long. So do UOA at say 6k and take it from there. Seems like you are under warranty so play it safe and follow OLM.
Re: 2017 Altima extended oci [Re: cals400ex] #4894393 10/12/18 02:13 AM
FowVay Offline
Your owners manual states to change the oil and filter at 5,000 mile intervals under normal use conditions using 0W-20 oil. I have a Frontier pickup with the QR25DE engine and it also states to change the oil and filter at 5,000 miles except to use 5W-30 oil. No manufacturer specific specifications are called for, just the normal API SN and ILSAC GF-5. These engines seem to shear oil rather quickly and have a very small filter. For longevity I chose not to try to extend my drain interval past Nissan's recommendations.
Don't forget to follow the other maintenance requirements in the manual which include brake fluid at 20,000 mile intervals, cabin air filter at 15,000 mile intervals and engine air fiilter at 30,000 miles. The cabin air filter isn't going to increase vehicle life but the oil and brake fluid changes and engine air filter replacement certainly will.
Re: 2017 Altima extended oci [Re: FowVay] #4894443 10/12/18 06:00 AM
B
bbhero Offline
B
Very good post here. My Nissan Altima VQ has 245k miles on it and is kicking rear end still : )
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: 2017 Altima extended oci [Re: cals400ex] #4894459 10/12/18 06:53 AM
A
aquariuscsm Online Content
Online Content
A
Stick with Nissan's oem recommendation. Don'y buy into the oil makers' silly extended oci stuff.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: 2017 Altima extended oci [Re: cals400ex] #4894496 10/12/18 08:36 AM
Since I’ll be under warranty for ~6 more months, I’ll follow the manufactures recommended oci. After that, I may try an uoa and try to extend the oci, if possible....I’m just trying to avoid getting an oil change ever two months if I can.
Speaking of brake fluid, why does it need changed so frequently?
Re: 2017 Altima extended oci [Re: cals400ex] #4894644 10/12/18 11:44 AM
J
JeffKeryk Online Content
Online Content
J
Brake fluid is hygroscopic - it absorbs water. Water lowers the boiling point of the fluid.
Regular brake fluid service is probably the most neglected service.
On a vehicle that is neglected, a brake fluid flush will give you a better pedal.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2017 Altima extended oci [Re: cals400ex] #4894648 10/12/18 11:46 AM
A
Audios Offline
A
I wouldnt push it with these cars and their tiny filters. 5-6k max on good syn.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: 2017 Altima extended oci [Re: cals400ex] #4894660 10/12/18 12:03 PM
StevieC Offline
I would't go past what the manual calls for on the filter unless you want to change the filter and keep going on the same oil because they are such small filters usually on Nissan vehicles. I would also use at least one oil analysis to determine safe OCI for the oil.
'18 Caravan - 42k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: 2017 Altima extended oci [Re: cals400ex] #4894866 10/12/18 04:12 PM
J
Online Content
J
Plus, the (bigger) Honda filter fits. That's what I use.
2018 Lexus RX450h
2006 Acura TSX
Re: 2017 Altima extended oci [Re: JeffKeryk] #4895022 10/12/18 07:33 PM
StevieC Offline
Just for my own info, does the technical specs match on both filters? Eg: the flow rate, maximum PSI, bypass etc. ?
Re: 2017 Altima extended oci [Re: cals400ex] #4895048 10/12/18 08:01 PM
T
tig1 Offline
T
I have been doing 10K OCIs for 40 years with various M1 oils in several different types of engines. Never a problem, and I don't waste money on UOAs.
2007 Ford Fusion 247,000 miles
M1 5-20HM
2017 Ford Fusion 75K
M1 0-20EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 2017 Altima extended oci [Re: StevieC] #4895177 10/12/18 10:42 PM
J
Online Content
J
Dunno that much about it; sorry StevieC.
Did a quick look on Fram website, compared XG6607 AND XG7317.
By Pass Valve is both 13.
The gasket size is slightly different.
The 7317 was used on earlier Nissans, both 4 and 6 cylinder.
2018 Lexus RX450h
2006 Acura TSX
Re: 2017 Altima extended oci [Re: StevieC] #4895215 10/12/18 11:51 PM
G
Garak Offline
G
No, because one is oversize, so it's a bit longer. Just ribbing you, Stevie. wink Yes, they're pretty much the same, at least for the Wix filters, and probably across the board. Nissan actually specs the longer filter for a few of their applications, notably the V8s and some of the 3.5 varieties, depending upon the install, and a bunch of other seemingly random applications.
I use the oversize on occasion, since it gives me a silicone ADBV with the Wix and is actually cheaper. The quick lubes give everyone the shorty because they want to consolidate inventory (I've never seen where the long one wouldn't fit) and only dealers and shops are allowed to go out of spec, not us lowly mortals. As I mentioned in the filter subforum, on these engines, Wix actually has four that will fit it, and I've tried them all with no problems. Wix changed the base plate, with the 51358 being the short one, 56356 being the long one, 51365 being the original short and 51356 being the original long.
Plain, simple Garak.
Re: 2017 Altima extended oci [Re: cals400ex] #4895300 10/13/18 06:56 AM
Does the longer filter provide any benefit? Maybe if one were wanting to extend their oil change interval?
