"The Battery Thread Of 2019"
by NDL - 12/09/19 03:34 PM
This will bring some of you back....
by simple_gifts - 12/09/19 03:22 PM
Rear wiper squeaking from the wiper arm pivot point
by slacktide_bitog - 12/09/19 02:28 PM
Valvoline launches "hybrid specific motor oil"
by wemay - 12/09/19 01:58 PM
Amazon Basics 0W20 SN+
by LoneRanger - 12/09/19 01:36 PM
Oil cleaner?
by Dbow - 12/09/19 01:32 PM
My 1965 Bolens.
by TriMoto - 12/09/19 12:55 PM
Owners Manual Recommendations 2019 Ram
by Snagglefoot - 12/09/19 12:22 PM
What engine RPM = maximum alternator output?
by Ed_Flecko - 12/09/19 11:41 AM
Supertech 3260
by Bettez88 - 12/09/19 10:06 AM
When the repair bill is 3.5 times what was estimated.
by motor_oil_madman - 12/09/19 09:59 AM
I See Better @ Night w/ Halogen Beams than HID/LED
by LoneRanger - 12/09/19 09:15 AM
Castrol GTX MAGNATEC Walmart
by MarkM66 - 12/09/19 08:03 AM
BITOG Standard of Conduct
by dnewton3 - 12/09/19 07:23 AM
Current Honda Factory Fill
by asiancivicmaniac - 12/09/19 04:16 AM
Gulf Western - Premium Gold 15W40
by SR5 - 12/09/19 03:43 AM
scarecrowdjinnn, Dbow, NoahE, EddieO, streky
70076 Registered Users
123 registered members (Anduril, apollo18, Aero540T, Alfred_B, Astro14, aquariuscsm, 8 invisible), 2,272 guests, and 55 spiders.
Topics298,494
Posts5,136,610
Members70,076
Most Online3,589
Nov 2nd, 2019
Battery Charger Pulsing? #4892229 10/09/18 07:11 PM
A
Auae85 Online Content OP
OP Online Content
A
Drove my truck last Saturday night with no problems. Didn't drive the truck at all on Sunday or Monday. Went to crank it this morning and the battery was dead. I recently installed an AFM delete module on it, but I've let it sit for 3 or 4 days and had no issues, even with the AFM module plugged in the whole time.
Okay, so I unplugged the AFM module and put the truck on my battery charger, 2 Amp charge rate setting. Went out about 2 hours later, and the ammeter gauge was pulsing between 4 Amps and 6 Amps, and the battery wasn't accepting charging. I checked the connections to be sure they were good, even repositioning them, and the battery charger still pulsates. The battery is a Carquest Gold with a manufacturing date of 07/18.
Thoughts?
Re: Battery Charger Pulsing? [Re: Auae85] #4892234 10/09/18 07:16 PM
dogememe Offline
take the battery to get tested? just because it's new doesn't mean it's good.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~289K Miles: Unknown Oil, Filter.
Re: Battery Charger Pulsing? [Re: Auae85] #4892247 10/09/18 07:22 PM
W
Warstud Offline
W
Is it a smart charger ? Maybe the voltage of the battery is to low for the charger to detect.
Re: Battery Charger Pulsing? [Re: Auae85] #4892273 10/09/18 07:38 PM
A
OP Online Content
A
Battery charger is an old Schumacher SE-82-6 12V dual rate charger. I inherited it from from my step-granddad over 20 years ago, and no telling how long he had it. I have charged a lot of batteries with it, and never seen this behavior before.
Re: Battery Charger Pulsing? [Re: Auae85] #4892286 10/09/18 07:49 PM
Chris142 Online Content
Online Content
Mine does that when the battery is bad.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Battery Charger Pulsing? [Re: Auae85] #4892307 10/09/18 08:01 PM
E
eljefino Offline
E
It could be a car computer/ relay trying to boot up now that the battery shows some voltage.
If your battery is flat it would take a 10 amp charge, easily. They're around 80 amp-hours so if you want to drive it this week, use the faster mode.
Next time you have your charger on a full battery, turn on your headlights. You'll see the current draw on the charger's ammeter.
The mode switch on buzz-box style chargers is pretty crude, as they like to say, YMMV.
The bad battery is certainly a possibility as well.
Re: Battery Charger Pulsing? [Re: Auae85] #4892310 10/09/18 08:02 PM
M
mk378 Online Content
Online Content
M
Disconnect the battery from the truck electrical system. Charge for a couple of hours then measure the battery voltage. If it is stuck at less than 12 while charging, the battery has an internal short and needs to be replaced.
Re: Battery Charger Pulsing? [Re: Auae85] #4892364 10/09/18 08:57 PM
Donald Offline
Try charger on a known good battery. I say charger is shot. Get a smart charger.
2015 Ford F250 w/Powerstroke
Re: Battery Charger Pulsing? [Re: Auae85] #4892587 10/10/18 06:52 AM
M
Online Content
M
On a basic manual charger, the amp meter going up is good proof that it is working. The amp meter going higher than the nominal rated current means that something connected to the output is holding down the output voltage-- totally run down battery (which should resolve with charging for a time), defective battery, or load from the vehicle system.
The amp meter will normally fluctuate slightly with changes in the input line voltage, since there is no voltage or current regulator in the charger.
Re: Battery Charger Pulsing? [Re: Auae85] #4892636 10/10/18 07:53 AM
A
OP Online Content
A
Thanks for the replies. I will check the battery charger on a known good battery to observe the ammeter, and I will try to charge the battery when it is disconnected from the truck. May have to wait a day or two due to work commitments and since we're starting to get some outer rain bands from the hurricane.
Re: Battery Charger Pulsing? [Re: Auae85] #4893439 10/10/18 09:00 PM
H
HorseThief Offline
H
The vehicle is trying to wake up and the charger can't supply enough current - this is very bad for electronics. Disconnect the battery before connecting the charger.
I saw a brown dog
Re: Battery Charger Pulsing? [Re: Auae85] #4894620 10/12/18 10:06 AM
A
OP Online Content
A
Well, thankfully all we got was slight winds and about 1-1/2 inches of rain from the hurricane since we were northwest of the main force. Anyway, yesterday afternoon I removed the battery from the truck and put in on the battery charger. No pulsing of the ammeter. I checked the voltage just prior to this, and it was approximately 4.61 volts. I left it on the charger for several hours and took it off last night before bed. Battery was now at 12.22 volts. Before leaving for work this morning, I checked it again, and it had dropped to 11.88 volts. I will check it when i get home to see if it has dropped any further.
Re: Battery Charger Pulsing? [Re: Auae85] #4894621 10/12/18 10:06 AM
A
OP Online Content
A
BW, battery chager seemd to be working fine with no noises or odd smells.
Re: Battery Charger Pulsing? [Re: Auae85] #4895125 10/12/18 08:24 PM
B
bbhero Offline
B
What the voltage at now??? Seems a bit odd it dropped down after going up to 12.22.
Nissan Altima 3.5 Coupe
Napa full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Battery Charger Pulsing? [Re: Auae85] #4895162 10/12/18 09:23 PM
A
OP Online Content
A
Checked when I got home and it was approximately 11.5 volts. Had it on the charger since then; I'll disconnect the charger and check the voltage before going to bed, and then check it again in the morning.
