KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
95 registered members (ammolab, 2015_PSD, aquariuscsm, 4WD, ardee, 12 invisible), 2,016 guests, and 17 spiders.
Topics306,012
Posts5,284,801
Members71,558
Battery Charger Pulsing? #4892229 10/09/18 08:11 PM
A
Auae85 Offline OP
A
Drove my truck last Saturday night with no problems. Didn't drive the truck at all on Sunday or Monday. Went to crank it this morning and the battery was dead. I recently installed an AFM delete module on it, but I've let it sit for 3 or 4 days and had no issues, even with the AFM module plugged in the whole time.
Okay, so I unplugged the AFM module and put the truck on my battery charger, 2 Amp charge rate setting. Went out about 2 hours later, and the ammeter gauge was pulsing between 4 Amps and 6 Amps, and the battery wasn't accepting charging. I checked the connections to be sure they were good, even repositioning them, and the battery charger still pulsates. The battery is a Carquest Gold with a manufacturing date of 07/18.
Thoughts?
Re: Battery Charger Pulsing? [Re: Auae85] #4892234 10/09/18 08:16 PM
dogememe Offline
take the battery to get tested? just because it's new doesn't mean it's good.
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~292K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Battery Charger Pulsing? [Re: Auae85] #4892247 10/09/18 08:22 PM
W
Warstud Offline
W
Is it a smart charger ? Maybe the voltage of the battery is to low for the charger to detect.
Re: Battery Charger Pulsing? [Re: Auae85] #4892273 10/09/18 08:38 PM
A
Auae85 Offline OP
A
Battery charger is an old Schumacher SE-82-6 12V dual rate charger. I inherited it from from my step-granddad over 20 years ago, and no telling how long he had it. I have charged a lot of batteries with it, and never seen this behavior before.
Re: Battery Charger Pulsing? [Re: Auae85] #4892286 10/09/18 08:49 PM
Chris142 Offline
Mine does that when the battery is bad.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Battery Charger Pulsing? [Re: Auae85] #4892307 10/09/18 09:01 PM
E
eljefino Offline
E
It could be a car computer/ relay trying to boot up now that the battery shows some voltage.
If your battery is flat it would take a 10 amp charge, easily. They're around 80 amp-hours so if you want to drive it this week, use the faster mode.
Next time you have your charger on a full battery, turn on your headlights. You'll see the current draw on the charger's ammeter.
The mode switch on buzz-box style chargers is pretty crude, as they like to say, YMMV.
The bad battery is certainly a possibility as well.
Re: Battery Charger Pulsing? [Re: Auae85] #4892310 10/09/18 09:02 PM
M
mk378 Offline
M
Disconnect the battery from the truck electrical system. Charge for a couple of hours then measure the battery voltage. If it is stuck at less than 12 while charging, the battery has an internal short and needs to be replaced.
Re: Battery Charger Pulsing? [Re: Auae85] #4892364 10/09/18 09:57 PM
Donald Online Content
Online Content
Try charger on a known good battery. I say charger is shot. Get a smart charger.
2015 Ford F-250 w/Powerstroke
Re: Battery Charger Pulsing? [Re: Auae85] #4892587 10/10/18 07:52 AM
M
mk378 Offline
M
On a basic manual charger, the amp meter going up is good proof that it is working. The amp meter going higher than the nominal rated current means that something connected to the output is holding down the output voltage-- totally run down battery (which should resolve with charging for a time), defective battery, or load from the vehicle system.
The amp meter will normally fluctuate slightly with changes in the input line voltage, since there is no voltage or current regulator in the charger.
Re: Battery Charger Pulsing? [Re: Auae85] #4892636 10/10/18 08:53 AM
A
Auae85 Offline OP
A
Thanks for the replies. I will check the battery charger on a known good battery to observe the ammeter, and I will try to charge the battery when it is disconnected from the truck. May have to wait a day or two due to work commitments and since we're starting to get some outer rain bands from the hurricane.
Re: Battery Charger Pulsing? [Re: Auae85] #4893439 10/10/18 10:00 PM
H
HorseThief Offline
H
The vehicle is trying to wake up and the charger can't supply enough current - this is very bad for electronics. Disconnect the battery before connecting the charger.
I saw a brown dog
Re: Battery Charger Pulsing? [Re: Auae85] #4894620 10/12/18 11:06 AM
A
Auae85 Offline OP
A
Well, thankfully all we got was slight winds and about 1-1/2 inches of rain from the hurricane since we were northwest of the main force. Anyway, yesterday afternoon I removed the battery from the truck and put in on the battery charger. No pulsing of the ammeter. I checked the voltage just prior to this, and it was approximately 4.61 volts. I left it on the charger for several hours and took it off last night before bed. Battery was now at 12.22 volts. Before leaving for work this morning, I checked it again, and it had dropped to 11.88 volts. I will check it when i get home to see if it has dropped any further.
Re: Battery Charger Pulsing? [Re: Auae85] #4894621 10/12/18 11:06 AM
A
Auae85 Offline OP
A
BW, battery chager seemd to be working fine with no noises or odd smells.
Re: Battery Charger Pulsing? [Re: Auae85] #4895125 10/12/18 09:24 PM
B
bbhero Offline
B
What the voltage at now??? Seems a bit odd it dropped down after going up to 12.22.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Battery Charger Pulsing? [Re: Auae85] #4895162 10/12/18 10:23 PM
A
Auae85 Offline OP
A
Checked when I got home and it was approximately 11.5 volts. Had it on the charger since then; I'll disconnect the charger and check the voltage before going to bed, and then check it again in the morning.
