Royal Purple 75W90 vs. Store Brand Synthetic
by WondrousBread. 06/24/19 12:50 PM
Jeep Renegade MTF Alternatives?
by Sunnyinhollister. 06/24/19 12:28 PM
Havoline 0W20 VI higher than 5w30 and 10w30?
by Whammo. 06/24/19 12:10 PM
New toy...19 Jetta GLI Autobahn
by CincyDavid. 06/24/19 12:00 PM
PCV Valve Cleaning Replacement ?
by ChrisD46. 06/24/19 11:54 AM
Honda cvt fluid change frequency?
by axxel6307. 06/24/19 11:09 AM
Lease - Gap Coverage
by coopns. 06/24/19 10:37 AM
Corner lot cutters
by BJD78. 06/24/19 09:44 AM
Think I killed my Briggs 190CC Free Mower
by Miller88. 06/24/19 09:14 AM
Service Pro oil any good?
by MileHigh18. 06/24/19 09:09 AM
Volvo S80.
by D1dad. 06/24/19 08:23 AM
Chain saw stopped oiling
by Chris142. 06/24/19 08:19 AM
List of oil filter that use coil spring
by MetalSlug. 06/24/19 07:50 AM
303 annoyance
by Gasbuggy. 06/24/19 04:39 AM
my K&N...
by dirtydannyd. 06/24/19 03:44 AM
What weight of oil 20 or 30? Rrrrrrr
by chubbie. 06/24/19 01:06 AM
1st use of Griots garage de-ionizer
by double vanos. 06/23/19 10:52 PM
Castrol 0w40 as E36 track day oil
by levesqu6. 06/23/19 10:09 PM
shelf life
by Don_B. 06/23/19 09:49 PM
tahoe_hybrid, rosemann07, Jedyboyrokr, KiwiAz, MontePrix28
68469 Registered Users
95 registered members (928, 1WildPig, AandPDan, ad_infinitum, 2015_PSD, 1978elcamino, 7 invisible), 2,484 guests, and 29 spiders.
Topics290,901
Posts4,994,883
Members68,469
Most Online2,967
Mar 10th, 2019
Page 68 of 79 1 67 68 69 79
Re: post your latest transmission lubricant change. [Re: ledslinger] #4889513
10/06/18 07:55 PM
10/06/18 07:55 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
2006 Acura TSX, 180K miles, 26K trans service OCI
Out: 3 qts Honda DW-1
In: 3 qts Idmitsu Type H
This is good stuff. Car has steady diet of Honda AT fluids.
This Idemitsu fluid pulls better.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: post your latest transmission lubricant change. [Re: ledslinger] #4890900
10/08/18 11:45 AM
10/08/18 11:45 AM
Ohio
hallstevenson Online content
hallstevenson  Online Content
Ohio
Replaced the rear differential fluid on my '08 G35X with 115k miles. My sister owned this car before me and I have all of the service records up to ~65k miles as they took it to the Infiniti dealer for all work up until then. After that, they took it to an independent shop for most work (some still done at Infiniti) but didn't keep all of the records. My BIL doesn't recall them having the differential fluid changed....
Anyway, when it came out, it looked dark but I later poured a couple hundred mL into a jar and it actually looks like ATF since it's read in color. It's thicker though, for sure, and smells more like heavy oil or grease. I put in Lucas Heavy Duty 80W-90 (GL5) which was amber color (much like motor oil).
Anyway, is that typical for gear oil to look red like ATF ?
Re: post your latest transmission lubricant change. [Re: ledslinger] #4891354
10/08/18 07:32 PM
10/08/18 07:32 PM
Sauk Valley, IL
EricBeau Offline
EricBeau  Offline
Sauk Valley, IL
2010 Honda Odyssey in signature
108,436 miles on vehicle
8,893 miles on fluid, in service since 10/06/2017.
Out: Approximately 3.3 qts Valvoline MaxLife ATF
In: Same
I like to do a simple drain and fill annually. Makes me feel warm and fuzzy and it’s cheap ($18.00) and easy (same amount of work as an oil change).
2001 Toyota Camry LE 4cyl.
Super Tech High Mileage 5W-30 and Super Tech ST4967
2010 Honda Odyssey LX
Mobil 1 High Mileage 5W-20 and FRAM TG7317
Ford Service Advisor
Re: post your latest transmission lubricant change. [Re: ledslinger] #4891940
10/09/18 01:49 PM
10/09/18 01:49 PM
g
lucky3 Offline
lucky3  Offline
g
Just changed the trans fluid and filter in my 2013 silverado. Just did a dump and fill. Used acdelco dexron 6. Had 104000miles. I bought it with 96000.
Re: post your latest transmission lubricant change. [Re: ledslinger] #4892053
10/09/18 04:55 PM
10/09/18 04:55 PM
Rochester Hills, MI
harbor Offline
harbor  Offline
Rochester Hills, MI
Changed out the Spider tranny & diff fluid with Motorcraft XT-M5-QS (the Miata guys rave about this) and M1 in the diff. Noticeable improvement!
2019 Dodge Challenger AWD GT
2018 Jeep Grand Cherokee
2018 Fiat 124 Spider
2017 Jeep Renegade
Re: post your latest transmission lubricant change. [Re: ledslinger] #4893483
10/10/18 11:07 PM
10/10/18 11:07 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
2005 Honda Civic LX 55K miles
Out: less than 3 quarts factory fill.
In: 1 quart DW-1 plus almost 2 quarts MaxLife
Original fluid was a little low and brown; not too bad.
She shifts better; no clunk.
Will do it again soon with Idemitsu Type H Plus.
2018 Lexus RX450h
2006 Acura TSX
Re: post your latest transmission lubricant change. [Re: ledslinger] #4894641
10/12/18 11:36 AM
10/12/18 11:36 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Since M1 does not have an ATF with the Mercon LV rating I decided to do the next best thing and used Valvoline Max Life LV for my usual 30K ATF change.
Out: MC Mercon LV
In: 3.5 QTS. of Valvo Max Life LV.
2007 Ford Fusion 244,000 miles
M1 0-20 EP
2017 Ford Fusion 72K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: post your latest transmission lubricant change. [Re: ledslinger] #4895065
10/12/18 08:14 PM
10/12/18 08:14 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Changed out the ATF in my grandsons 2012 Ford Fusion.
Out: Unknown.
In: Valvoline Maxlife LV.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: post your latest transmission lubricant change. [Re: ledslinger] #4898903
10/17/18 06:16 PM
10/17/18 06:16 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Neighbor's 2010 Honda Accord @ 100,240 mi.
3 qt. OUT
3 qt. IN
Honda Genuine DW-1 both
Re: post your latest transmission lubricant change. [Re: ledslinger] #4898931
10/17/18 06:46 PM
10/17/18 06:46 PM
Alabama, United States
Red91 Online content
Red91  Online Content
Rear diff on 00 Econoline e150, 3.55 LSD
Out: Mobil 1 75/90, 75/140, Napa 80/90(bad axle seal and bearing)
In: Mobil 1 75/140
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest transmission lubricant change. [Re: ledslinger] #4902464
10/21/18 09:30 PM
10/21/18 09:30 PM
Missouri
ledslinger Offline OP
Missouri
1999 Honda Accord, 2.3 4 cyl, 5 speed manual transimission. Out-Honda MTF, in Elf/Total Racing HTX 735 75w-90. 2 quarts. 220K miles on unit.
Re: post your latest transmission lubricant change. [Re: ledslinger] #4903097
10/22/18 02:58 PM
10/22/18 02:58 PM
McGregor TX
mrdctaylor Offline
mrdctaylor  Offline
McGregor TX
2012 Toyota Highlander. 3rd ATF change. Almost 100K miles on vehicle.
Out: Toyota WS (~4.75 quarts)
In: Toyota WS (~4.75 quarts)
#boring
02 Tacoma 3.4L, 225K, Magnatec 10W30
12 Highlander 3.5L, 104K, Napa Syn 0W20
17 Escape 2.0L, 43K, PP 5W30
02 Trailblazer 4.2L, 186K, Edge HM 10W40
Re: post your latest transmission lubricant change. [Re: ledslinger] #4905204
10/24/18 07:10 PM
10/24/18 07:10 PM
01 grand Cherokee 2wd
3.55 Dana open diff
Out: unknown
In: Napa 80/90
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest transmission lubricant change. [Re: ledslinger] #4905528
10/25/18 09:32 AM
10/25/18 09:32 AM
Arizona
AzFireGuy79 Offline
AzFireGuy79  Offline
Arizona
2008 4runner Limited V8 @ 72,000 miles
Out: 11 quarts factory fill WS ATF
In: 12 quarts (cooler line exchange) WS ATF
Next change will be Ravenol Synthetic PAO T-WS
Re: post your latest transmission lubricant change. [Re: ledslinger] #4906034
10/25/18 07:52 PM
10/25/18 07:52 PM
Michigan
khittner Offline
khittner  Offline
Michigan
‘02 Camry w/273K miles. Pan drop and filter change at 30K OCI. Out 5qts. of Maxlife; in a 5qts. of same w/Beck Arnley filter. No crud in either the pan or on magnets. Smooth shifting before and after.
