TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
Pics - Top Piston Cleaning - Lexus CT200h
by KerryB - 11/14/19 12:14 AM
Valvoline Full Synthetic Maxlife 10w30
by KerryB - 11/13/19 11:38 PM
Toyota 1MZ-FE burning lots of oil
by Speedinsweede - 11/13/19 11:27 PM
Castrol Magnatec
by dosmom - 11/13/19 10:51 PM
How do you feel about buying tires with different DOT's?
by Speedinsweede - 11/13/19 10:23 PM
Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
Chrysler EcoDiesel Class Action Suit
by JeffKeryk - 11/13/19 07:45 PM
2015 Mazda 6 Auto-RX rinse Castrol EDGE 0W20
by bulwnkl - 11/13/19 07:45 PM
Where's Trav 2.0?
by user52165 - 11/13/19 07:20 PM
Siphoning Fuel
by Spetz - 11/13/19 06:34 PM
AGM vs Traditional Battery
by jayjr1105 - 11/13/19 06:07 PM
Mail in mailbox notification devices
by atikovi - 11/13/19 05:46 PM
Canned marinated artichoke hearts, good or bad?
by atikovi - 11/13/19 05:35 PM
Shattered glass
by bdcardinal - 11/13/19 05:11 PM
Oil filter Cutter, Pet Peeve
by 10ecfarmer - 11/13/19 05:05 PM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
39 registered members (caravanmike, Aerojoe, BillyE, CB900F2, berlyn, DaHen, 5 invisible), 974 guests, and 21 spiders.
Topics297,383
Posts5,114,414
Members69,856
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: MB GLE 350 engine oil weight [Re: Snagglefoot] #4893898 10/11/18 11:30 AM
W
Wolf359 Offline
W
Originally Posted by Snagglefoot
The OP wants to use a 5w30 oil. The Euro L, which is designed as a diesel motor oil, is also rated C3 which is fine for a gasoline engines He was also partial to Pennzoil products.
Is there a 5w30 229.5 product out there? I’ve seen 5w40 229.5 products but so far I haven’t see a 5w30 version. I certainly could be wrong about that. Please let me know. smile
You just look up the approved list to see if it's on there. There's a few on there:
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893934 10/11/18 12:15 PM
L
loneryder Offline
L
229.5 is for gas engine and should be used with a fleece filter for the service reminder system. 229.51/52 is for diesels and their exhaust treatment systems. You can run a 229.51/52 oil in a gasser but your service reminder will not be accurate. Also if you run longer oci's on the 229.51/52 in a gasser you will experience sludging. MB actually experienced this and stopped using .51/52 in gassers.
For years the 3.5 engines came with and used 5w-40 syn oil. They only recently went to 5w-30 for CAFE reasons.
Use whatever 229.5 oil you want but I would stay away from .51/52 oils in your car.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893994 10/11/18 01:06 PM
Snagglefoot Offline
Just to check. Who makes a 5w30 with a 229.5 certification?
If you want the job done right......do it yourself.
Re: MB GLE 350 engine oil weight [Re: Snagglefoot] #4894117 10/11/18 04:41 PM
M
MaximaGuy Offline OP
M
Nobody though Pennzoil has a 5w30 certified fluid on the MB approved list.
Today I headed to Walmart looking for European formula (idiots in Europe have some stupid certifications that most Americans wouldn't even know about it, incl. me) engine oil.
The idiot in the oil section looks up his catalog (Castrol catalog) and told me any 5w30 would work. I left humbled that this guy in the oil section wasn't aware of American vs Euro certifications.
I am lost with these stupid Euro certifications.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4894227 10/11/18 07:01 PM
G
Garak Offline
G
Even the Benz manuals can be a little cryptic about these specifications. My goddaughter has a Benz and it doesn't say much of anything useful in the manual. So yes, I do feel for the parts guys, not to mention guys just going to the parts store who aren't members of a place like this.
At least the Castrol website itself should give proper information. Personally, the European certification aren't too bad once you get used to them, particularly the base ACEA specs themselves.
Plain, simple Garak.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4894683 10/12/18 11:24 AM
L
loneryder Offline
L
Easiest thing to do is get some Mobil 1 or Valvoline Synpower 0-40 from Walmart. Both are certified and on the MB list. Easy to get at good prices.
Re: MB GLE 350 engine oil weight [Re: loneryder] #4894804 10/12/18 01:45 PM
W
Wolf359 Offline
W
Many prefer Castrol 0w40 just because it has the BMW LL-01 where Mobil 1 doesn't. But it shouldn't really matter, they both have 229.5 certification.
Re: MB GLE 350 engine oil weight [Re: Popsy] #4895304 10/13/18 06:11 AM
Z
zeng Offline
Z
Originally Posted by Popsy
Also I thought Petronas was the current OEM for Mercedes (at least in Europe) ?
It used to be and it still is in Malaysia.
Re: MB GLE 350 engine oil weight [Re: loneryder] #4895327 10/13/18 07:21 AM
Z
zeng Offline
Z
Not trying to argue with you, as I wasn't sure on why sludging being caused by use of 229.51 oils in MB gasoline engines calling for 229.5 when both the specs qualify under similar M 271 Sludge Test specifications ?
Would appreciate if you could provide links describing circumstances leading to stated sludging phenomenon.
There are MB gasoline engines allowing use of 229.5, 229.51 AND 229.52 (as opposed to OP's manuals ),in this regards would inaccuracy of service reminder arises and its mechanisms, other than differences in SaPS levels ?
Re: MB GLE 350 engine oil weight [Re: zeng] #4895425 10/13/18 10:13 AM
L
loneryder Offline
L
I don't have any technical links to provide. Basically a story from my Indy MB shop. The man's father spent a career with MB and was an investigator with them the last few yrs of his career, then started this shop 18 yrs ago. They follow MB's recommendations (except 10k oci) and use all MB parts. When the .51 low saps oils came out, dealers had a problem with putting the correct oil in the correct car. Since Mobil 1 said on the label that it could be used in gas engines, they started using the .51 oil in all cars. This Indy shop started seeing sludged engines coming in when the service reminder came on. They called Mobil oil who sent reps in to see them. They were very defensive of the oil. They told him they wanted him to come to HQ (in No. Va. at the time) and talk about it. Never happened. He felt that they were covering things up. After that visit, dealers were told to stop using .51 oil in the gassers. He knows that because the dealers told him. Some on here have said that it has something to do with the gasoline in N America. You can use .51 oil in gas engines. You just can't go 10k miles on it.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4895455 10/13/18 11:22 AM
M
M
In my thought process only an idiot would use 229.xxxx to represent oil for gasoline and diesel engines.
We have so many digits in the freaking world why reference 229.xxx - say call it 2xxx for gasoline and some 5xxx for diesels.
As an anecdotal reference, my dad worked in electrical power plants and he told me one Siemens electrical equipment were by far the most complicated finicky engineering marvels. Unnecessary complication for nothing. So goes with 229.xxx nonsense.
I went ahead and ordered 0w40 M1 from Costco online and moved ahead.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4895827 10/13/18 08:55 PM
Z
zeng Offline
Z
Originally Posted by MaximaGuy
The owners manual has either 229.5 or 229.6 for gasoline engines and 229.51 for diesel engines.
OP, what's the recommended/typical OCI with/without service indicators in manuals ?
Re: MB GLE 350 engine oil weight [Re: zeng] #4896059 10/14/18 07:18 AM
M
M
Unsure this is my first German vehicle and there has been a awful lot to learn. I believe it has an oil monitor and it should raise the flag for an oil change.
Though my preference would be 1 yr /10K OCI, rather I would run it for a full 10K without the year in consideration given it takes 7.4Q synthetic oil.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4896135 10/14/18 08:54 AM
P
pezzy669 Offline
P
If MB hasn't changed their intervals with the newer cars it should still be 1 year/10k miles non-flexible service (they ditched FSS back in the mid-2000's). Makes it quite easy to remember. Assyst will constantly remind you if you exceed the 1 year though. If you scroll to Assyst under service settings in your MFD it will tell you either how many miles or days you have left to your next service, if it shows days it is currently projecting you won't hit the 10k before the year is up.
My '09 C300 was dealer serviced so received the "Genuine" Mercedes 5W40 whose bottle looked strangely like a Mobil bottle with MB stickers on it.
My '11 E350 ill prob use whatever is cheapest that has the MB229.5 cert. I hit the year mark with maybe 4500-5000 miles on the oil and like you said with a 7+ quart capacity I'm not too terribly concerned about the oil.
One cautionary tale I have stumbled on a few times (if you are planning your own oil changes) is to make sure you have the right oil filter if you buy somewhere other than the dealership. There are some stories floating around of people getting filters for an M272 which apparently will fit in the M276 housing but then starve the engine of oil. The one you want for your M276 has a 3-4 leg cage thing that extends below the filter which closes the anti-drainback valve, M272 filter does not have this so drain back valve is left wide open causing massive if not complete pressure loss.
2012 Volkswagen Jetta Sportwagen TDI - 69k - Castrol Edge Professional LL03 5W30
2011 Volkswagen Jetta Sportwagen TDI - 49k - Castrol Edge Professional LL03 5W30
Re: MB GLE 350 engine oil weight [Re: pezzy669] #4896241 10/14/18 11:36 AM
M
M
I got from RMEuropean the Mahle OX814D (Made in Bulgaria, BTW worked with Bulgarians before they are very bright folks) which is a fleece material filter for $14 rather than $24 from the MB parts store. They look identical from height and look though the OEM one was crisscrossed media meaning more media than the OX814D.
If my Lexus tiny paper media can survive for 10K OCI, the OX has plenty of media for a 10K OCI.
Page 2 of 2 1 2
