Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
talk to me about security cameras
by 1978elcamino - 08/21/19 03:30 PM
Robto, Chaparro_trucker, KiwiBiker, Rixter, yote556
69025 Registered Users
48 registered members (bbhero, 4WD, Aero540T, ArrestMeRedZ, advocate, BlakeB, 6 invisible), 1,083 guests, and 25 spiders.
Topics293,634
Posts5,043,794
Members69,025
Most Online3,532
Jul 30th, 2019
Noisy brakes on '10 Frontier #4894628 10/12/18 11:18 AM
K
K20FA5 Offline OP
K
I've battled noisy brakes on my Frontier for ever! It sounds like it comes from the rear, and it's always under light brake pressure (like a drive through or a parking lot). The OEM pads did it, the first set of aftermarket pads (Power Stop) did it on OEM rotors, and the current pair does it (Wagner Thermoquiet) on Chinese rotors. If the brakes are really hot, it doesn't do it as bad, but usually when I'm doing light brake pressure, the brakes are cold, or have at least cooled down. You can also hear it when you first start to press the brakes as you start to slow down for a traffic light, there is a squeal until you press them more firmly.
I've tried various different brake lubes for all the hardware, I even tried the red/pink brake quiet rubber coating on the back of the Power Stop pads. It doesn't seem to make any difference. New hardware is installed each time the brakes are done, including the caliper pins. Nothing seems to help!
I wanted to ask here and see if anyone has any suggestions? I'm needing new brakes soon, and I'm almost wondering if it's not something wrong with the rear calipers? Might be worth a shot to change those?
Thanks in advance for any suggestions,
Brian
Mine-2018 Chevy Silverado LT Z71 5.3L-M1 AFE 0W-20 / PF63E
Wife-2016 Toyota 4Runner SR5 Premium 4.0L-M1 AFE 0W-20 / 04152-YZZA5
Kiddo-2012 Honda Civic LX 1.8L-PP 0W-20 / TG7317
Re: Noisy brakes on '10 Frontier [Re: K20FA5] #4894640 10/12/18 11:34 AM
A
ARCOgraphite Offline
A
I thought truck brakes are supposed to squeal? smile
Sound like you did almost everything you could.
Maybe use an organic compound (read CHEAPER) pads, chamfer the leading edges with a file, and I like to cut a couple slots at least 1/2 way through the pad material with a metal blade hacksaw to make 3 sections - and cut on the bias (diagonal).
Remotely, the Rubber main leaf u-bolt shoe rubber isolator pads may be missing or gone - which could transmit brake racket into the chassis
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Noisy brakes on '10 Frontier [Re: K20FA5] #4894658 10/12/18 12:01 PM
W
WyrTwister Offline
W
Are you lubing the appropriate parts .
I also live in Texas . I have never replaced brake hardware unless I damaged it or it is MIA . However , perhaps replacing the hardware is something else you could try ?
Best of luck to you . :-)
Wyr
God bless
Re: Noisy brakes on '10 Frontier [Re: K20FA5] #4894709 10/12/18 01:10 PM
K
Kibitoshin Offline
K
Does the rear calipers come with a damper on one of the caliper mounting bolts? It looks like this (off a Ford F150) and is factory in some cars to combat low frequency noise (moaning and squealing) when applying the brakes.
[Linked Image]
There is a aftermarket addon from Raybestos for your truck that takes one per side and if you tried everything so I'd give these a shot.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Noisy brakes on '10 Frontier [Re: K20FA5] #4894721 10/12/18 01:20 PM
H
HemiHawk Offline
H
I haven't dug into it at all yet but... My 2016 Frontier has a squeak/Squeal at low speeds with light brake pressure. Still on factory brakes, just hit 20k miles. So you're not alone haha.
2015 Mustang GT
2017 VW GTI sport
1995 Mustang GTS
Re: Noisy brakes on '10 Frontier [Re: K20FA5] #4894737 10/12/18 01:35 PM
MolaKule Offline
Global Moderator
Global Moderator
I have a similar situation on my 2012 4X4 Frontier (70,000 miles) and it seems to originate in the front.
The noise seems to only be present on light braking in very humid weather and after a period of dry dusty weather.
The pads have plenty of material so to-date I theorize this to be dust mixing with moisture at the surfaces.
Anxious to hear of other theories and or actual causes for this intermittent noise.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: Noisy brakes on '10 Frontier [Re: K20FA5] #4894765 10/12/18 02:05 PM
slacktide_bitog Offline
Do you use the parking brake? Non-use of the parking brake can cause rear caliper failure. Nissan usually incorporates the parking brake into the rear calipers, and also Nissan seems to have issues with rear calipers being a common problem on them.
Knowing that about Nissans, I would recommend replacing the rear calipers anyway. Napa Eclipse and Cardone Ultra are the best ones to get.
You may want to consider ceramic pads like Akebono (they also make their high performance ASP pads for your Frontier, if you like). I have also heard good things on here about Hawk LTS truck pads.
Do your pads have wear indicators on them? If your pads are low and you know you need brakes, the wear indicator could be triggered.
Re: Noisy brakes on '10 Frontier [Re: slacktide_bitog] #4894810 10/12/18 02:51 PM
FowVay Offline
The Frontier uses an internally expanding drum brake for the parking brake. It works independently of the caliper and rarely causes any issues.
Re: Noisy brakes on '10 Frontier [Re: K20FA5] #4894969 10/12/18 06:42 PM
B
benjy Offline
B
i guess i am fortunate as my 11 fronty SV brakes quietly! i removed the OE discs pads because the rears were wearing poorly + E- brake poor even after adjusting in the console, only 28 thou but a hard life in salty Mass as i found out on CarFax. i took it ALL apart + cleaned everything good + lubed per instructions with the EBC kit, plain fully coated higher carbon rotors + yellow pads. it brakes better than before + minimal dust. on the other hand my 2001 TT is a squealer @ lower speeds. the pads with the Wilwood front were pretty quiet, but liking hawk pads i got a set + they braked better but squealed a LOT, even cleaned + relubed + noticed when i put the Wilwood pads back on the hawk pads rear backer was about destroyed. squealing brakes are annoying for sure!!
