Last night while driving this truck, I noticed that the lights in the middle of my instrument panel seemed to be out since the lighting was dimmer in that area. My high beam indicator was also not working. A little while later, it appeared that the lights had come back on as the entire instrument panel lighting was the same but my high beam indicator was still out.
When I was almost home, I used my high beams and the indicator lit up like normal. I did check the battery cables when I got home and they were pretty tight but I was able to snug them a little. This morning I tested the lights again and the instrument panel lights all seem to be working but the high beam indicator is out again.
Does anyone have any other ideas on where I should look to correct this problem? Thanks.
Wayne
Wayne
