Motul VW 507.00 options
by Short_Bus. 07/22/19 10:14 PM
trailer brakes required over 4400 lbs gvwr?
by motor_oil_madman. 07/22/19 08:56 PM
Cool one off gun
by The_Eric. 07/22/19 08:44 PM
First timer here need some info
by VintageOilGuy. 07/22/19 08:14 PM
Tractor and Hydraulic Fluids Standards
by MolaKule. 07/22/19 08:04 PM
FL homeowners insurance jumped up
by gregk24. 07/22/19 08:03 PM
Swapping out PF48E for M1-113
by OZHSV. 07/22/19 06:30 PM
Vehicle Insurance Goes Down Again
by BlueOvalFitter. 07/22/19 05:20 PM
2003 Dodge Caravan front brakes
by Oldtom. 07/22/19 04:52 PM
TPMS Sensors for a 2012 Highlander
by Tundragod. 07/22/19 04:43 PM
No one has posted the C8 interior yet?
by wensteph. 07/22/19 04:42 PM
Discard veggies from homemade veggie broth? Really?
by Ed_Flecko. 07/22/19 04:37 PM
Water spot remover
by Redright9. 07/22/19 03:40 PM
Optimal oil temp?
by gfh77665. 07/22/19 03:08 PM
Performance, hodgkh57, Cb46, mhuds, Pongo23
68739 Registered Users
88 registered members (4WD, AC1DD, AdditiveOCD, alcyon, 9 invisible), 1,731 guests, and 28 spiders.
Topics292,257
Posts5,019,793
Members68,739
Most Online2,967
Mar 10th, 2019
Page 68 of 80 1 67 68 69 80
Re: post your latest transmission lubricant change. [Re: ledslinger] #4889513
10/06/18 07:55 PM
10/06/18 07:55 PM
Los Gatos, CA
JeffKeryk Online content
JeffKeryk  Online Content
Los Gatos, CA
2006 Acura TSX, 180K miles, 26K trans service OCI
Out: 3 qts Honda DW-1
In: 3 qts Idmitsu Type H
This is good stuff. Car has steady diet of Honda AT fluids.
This Idemitsu fluid pulls better.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: post your latest transmission lubricant change. [Re: ledslinger] #4890900
10/08/18 11:45 AM
10/08/18 11:45 AM
Ohio
hallstevenson Offline
Ohio
Replaced the rear differential fluid on my '08 G35X with 115k miles. My sister owned this car before me and I have all of the service records up to ~65k miles as they took it to the Infiniti dealer for all work up until then. After that, they took it to an independent shop for most work (some still done at Infiniti) but didn't keep all of the records. My BIL doesn't recall them having the differential fluid changed....
Anyway, when it came out, it looked dark but I later poured a couple hundred mL into a jar and it actually looks like ATF since it's read in color. It's thicker though, for sure, and smells more like heavy oil or grease. I put in Lucas Heavy Duty 80W-90 (GL5) which was amber color (much like motor oil).
Anyway, is that typical for gear oil to look red like ATF ?
Re: post your latest transmission lubricant change. [Re: ledslinger] #4891354
10/08/18 07:32 PM
10/08/18 07:32 PM
Sauk Valley, IL
EricBeau Offline
EricBeau  Offline
Sauk Valley, IL
2010 Honda Odyssey in signature
108,436 miles on vehicle
8,893 miles on fluid, in service since 10/06/2017.
Out: Approximately 3.3 qts Valvoline MaxLife ATF
In: Same
I like to do a simple drain and fill annually. Makes me feel warm and fuzzy and it’s cheap ($18.00) and easy (same amount of work as an oil change).
2001 Toyota Camry LE 4cyl.
Super Tech High Mileage 5W-30 and Super Tech ST4967
2010 Honda Odyssey LX
Mobil 1 High Mileage 5W-20 and FRAM TG7317
Ford Service Advisor
Re: post your latest transmission lubricant change. [Re: ledslinger] #4891940
10/09/18 01:49 PM
10/09/18 01:49 PM
g
lucky3 Offline
lucky3  Offline
g
Just changed the trans fluid and filter in my 2013 silverado. Just did a dump and fill. Used acdelco dexron 6. Had 104000miles. I bought it with 96000.
Re: post your latest transmission lubricant change. [Re: ledslinger] #4892053
10/09/18 04:55 PM
10/09/18 04:55 PM
Rochester Hills, MI
harbor Offline
harbor  Offline
Rochester Hills, MI
Changed out the Spider tranny & diff fluid with Motorcraft XT-M5-QS (the Miata guys rave about this) and M1 in the diff. Noticeable improvement!
2019 Dodge Challenger AWD GT
2018 Jeep Grand Cherokee
2018 Fiat 124 Spider
2017 Jeep Renegade
Re: post your latest transmission lubricant change. [Re: ledslinger] #4893483
10/10/18 11:07 PM
10/10/18 11:07 PM
Los Gatos, CA
Los Gatos, CA
2005 Honda Civic LX 55K miles
Out: less than 3 quarts factory fill.
In: 1 quart DW-1 plus almost 2 quarts MaxLife
Original fluid was a little low and brown; not too bad.
She shifts better; no clunk.
Will do it again soon with Idemitsu Type H Plus.
2018 Lexus RX450h
2006 Acura TSX
Re: post your latest transmission lubricant change. [Re: ledslinger] #4894641
10/12/18 11:36 AM
10/12/18 11:36 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Since M1 does not have an ATF with the Mercon LV rating I decided to do the next best thing and used Valvoline Max Life LV for my usual 30K ATF change.
Out: MC Mercon LV
In: 3.5 QTS. of Valvo Max Life LV.
2007 Ford Fusion 245,000 miles
M1 5-20HM
2017 Ford Fusion 73K
M1 0-20EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: post your latest transmission lubricant change. [Re: ledslinger] #4895065
10/12/18 08:14 PM
10/12/18 08:14 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Changed out the ATF in my grandsons 2012 Ford Fusion.
Out: Unknown.
In: Valvoline Maxlife LV.
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
Re: post your latest transmission lubricant change. [Re: ledslinger] #4898903
10/17/18 06:16 PM
10/17/18 06:16 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Neighbor's 2010 Honda Accord @ 100,240 mi.
3 qt. OUT
3 qt. IN
Honda Genuine DW-1 both
Re: post your latest transmission lubricant change. [Re: ledslinger] #4898931
10/17/18 06:46 PM
10/17/18 06:46 PM
Alabama, United States
Red91 Offline
Red91  Offline
Rear diff on 00 Econoline e150, 3.55 LSD
Out: Mobil 1 75/90, 75/140, Napa 80/90(bad axle seal and bearing)
In: Mobil 1 75/140
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest transmission lubricant change. [Re: ledslinger] #4902464
10/21/18 09:30 PM
10/21/18 09:30 PM
Missouri
ledslinger Offline OP
Missouri
1999 Honda Accord, 2.3 4 cyl, 5 speed manual transimission. Out-Honda MTF, in Elf/Total Racing HTX 735 75w-90. 2 quarts. 220K miles on unit.
Re: post your latest transmission lubricant change. [Re: ledslinger] #4903097
10/22/18 02:58 PM
10/22/18 02:58 PM
McGregor TX
mrdctaylor Offline
mrdctaylor  Offline
McGregor TX
2012 Toyota Highlander. 3rd ATF change. Almost 100K miles on vehicle.
Out: Toyota WS (~4.75 quarts)
In: Toyota WS (~4.75 quarts)
#boring
02 Tacoma 3.4L, 229K, Hav ProDS 10W30
12 Highlander 3.5L, 104K, Napa Syn 0W20
17 Escape 2.0L, 43K, PP 5W30
02 Trailblazer 4.2L, 186K, Edge HM 10W40
Re: post your latest transmission lubricant change. [Re: ledslinger] #4905204
10/24/18 07:10 PM
10/24/18 07:10 PM
Red91 Offline
Red91  Offline
01 grand Cherokee 2wd
3.55 Dana open diff
Out: unknown
In: Napa 80/90
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest transmission lubricant change. [Re: ledslinger] #4905528
10/25/18 09:32 AM
10/25/18 09:32 AM
Arizona
AzFireGuy79 Offline
AzFireGuy79  Offline
Arizona
2008 4runner Limited V8 @ 72,000 miles
Out: 11 quarts factory fill WS ATF
In: 12 quarts (cooler line exchange) WS ATF
Next change will be Ravenol Synthetic PAO T-WS
Re: post your latest transmission lubricant change. [Re: ledslinger] #4906034
10/25/18 07:52 PM
10/25/18 07:52 PM
Michigan
khittner Offline
khittner  Offline
Michigan
‘02 Camry w/273K miles. Pan drop and filter change at 30K OCI. Out 5qts. of Maxlife; in a 5qts. of same w/Beck Arnley filter. No crud in either the pan or on magnets. Smooth shifting before and after.
