Vehicle stored for 4 months
by palmerwmd. 02/17/19 09:57 AM
How often to drive a car that sits in the winter?
by Corollaman. 02/17/19 08:49 AM
Top Off or Change it Early
by 99Saturn. 02/17/19 08:22 AM
Do your vehicles have a nickname?
by ZZman. 02/17/19 08:19 AM
Another work project thread
by mattd. 02/17/19 08:18 AM
Buzzing sound behind dash
by Spetz. 02/17/19 05:09 AM
Ain't stupid, but can't find Cummin Hist
by BrocLuno. 02/16/19 11:41 PM
Rethinking oil choices
by JLTD. 02/16/19 11:29 PM
coolster 150 cc atv 2019 new
by hyperscion. 02/16/19 10:37 PM
older gps - week counter rollover Apr 6 '19
by spackard. 02/16/19 10:32 PM
Thoughts on an old Lexus?
by JustN89. 02/16/19 09:50 PM
Understanding Fuel Trims for diagnostics.
by StevieC. 02/16/19 07:59 PM
book of matches for tune up?
by marine65. 02/16/19 07:53 PM
New Penrite 0w-30
by toyota62. 02/16/19 07:45 PM
New HID bulbs for the Cadillac
by 14Accent. 02/16/19 07:17 PM
2008 Prius - Water in oil
by cjolson140. 02/16/19 07:00 PM
Kitchen Faucet question
by reemoe2. 02/16/19 06:56 PM
Time for brakes again
by SilverFusion2010. 02/16/19 05:23 PM
jpdeal, Snipeuout, DeltaWing, JRS3, krzyq
67252 Registered Users
105 registered members (AZjeff, 2015_PSD, 2004tdigls, 14Accent, 11 invisible), 1,870 guests, and 56 spiders.
Topics298,307
Posts4,989,254
Members67,252
Most Online2,548
Feb 16th, 2019
Battery Charger Pulsing? #4892229
10/09/18 07:11 PM
10/09/18 07:11 PM
AL
Auae85 Offline OP
Auae85  Offline OP
AL
Drove my truck last Saturday night with no problems. Didn't drive the truck at all on Sunday or Monday. Went to crank it this morning and the battery was dead. I recently installed an AFM delete module on it, but I've let it sit for 3 or 4 days and had no issues, even with the AFM module plugged in the whole time.
Okay, so I unplugged the AFM module and put the truck on my battery charger, 2 Amp charge rate setting. Went out about 2 hours later, and the ammeter gauge was pulsing between 4 Amps and 6 Amps, and the battery wasn't accepting charging. I checked the connections to be sure they were good, even repositioning them, and the battery charger still pulsates. The battery is a Carquest Gold with a manufacturing date of 07/18.
Thoughts?
Re: Battery Charger Pulsing? [Re: Auae85] #4892234
10/09/18 07:16 PM
10/09/18 07:16 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
take the battery to get tested? just because it's new doesn't mean it's good.
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30
2008 Ford Crown Vic P71 4.6 ~166K Miles: AMSOIL SS 0W-30
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30
Re: Battery Charger Pulsing? [Re: Auae85] #4892247
10/09/18 07:22 PM
10/09/18 07:22 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Is it a smart charger ? Maybe the voltage of the battery is to low for the charger to detect.
Re: Battery Charger Pulsing? [Re: Auae85] #4892273
10/09/18 07:38 PM
10/09/18 07:38 PM
AL
Auae85 Offline OP
Auae85  Offline OP
AL
Battery charger is an old Schumacher SE-82-6 12V dual rate charger. I inherited it from from my step-granddad over 20 years ago, and no telling how long he had it. I have charged a lot of batteries with it, and never seen this behavior before.
Re: Battery Charger Pulsing? [Re: Auae85] #4892286
10/09/18 07:49 PM
10/09/18 07:49 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Mine does that when the battery is bad.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Battery Charger Pulsing? [Re: Auae85] #4892307
10/09/18 08:01 PM
10/09/18 08:01 PM
ME
eljefino Offline
eljefino  Offline
ME
It could be a car computer/ relay trying to boot up now that the battery shows some voltage.
If your battery is flat it would take a 10 amp charge, easily. They're around 80 amp-hours so if you want to drive it this week, use the faster mode.
Next time you have your charger on a full battery, turn on your headlights. You'll see the current draw on the charger's ammeter.
The mode switch on buzz-box style chargers is pretty crude, as they like to say, YMMV.
The bad battery is certainly a possibility as well.
Re: Battery Charger Pulsing? [Re: Auae85] #4892310
10/09/18 08:02 PM
10/09/18 08:02 PM
USA
mk378 Online content
mk378  Online Content
USA
Disconnect the battery from the truck electrical system. Charge for a couple of hours then measure the battery voltage. If it is stuck at less than 12 while charging, the battery has an internal short and needs to be replaced.
Re: Battery Charger Pulsing? [Re: Auae85] #4892364
10/09/18 08:57 PM
10/09/18 08:57 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Try charger on a known good battery. I say charger is shot. Get a smart charger.
2015 Ford F250 w/Powerstroke
Re: Battery Charger Pulsing? [Re: Auae85] #4892587
10/10/18 06:52 AM
10/10/18 06:52 AM
USA
USA
On a basic manual charger, the amp meter going up is good proof that it is working. The amp meter going higher than the nominal rated current means that something connected to the output is holding down the output voltage-- totally run down battery (which should resolve with charging for a time), defective battery, or load from the vehicle system.
The amp meter will normally fluctuate slightly with changes in the input line voltage, since there is no voltage or current regulator in the charger.
Re: Battery Charger Pulsing? [Re: Auae85] #4892636
10/10/18 07:53 AM
10/10/18 07:53 AM
AL
Auae85 Offline OP
Auae85  Offline OP
AL
Thanks for the replies. I will check the battery charger on a known good battery to observe the ammeter, and I will try to charge the battery when it is disconnected from the truck. May have to wait a day or two due to work commitments and since we're starting to get some outer rain bands from the hurricane.
Re: Battery Charger Pulsing? [Re: Auae85] #4893439
10/10/18 09:00 PM
10/10/18 09:00 PM
MI
HorseThief Offline
HorseThief  Offline
MI
The vehicle is trying to wake up and the charger can't supply enough current - this is very bad for electronics. Disconnect the battery before connecting the charger.
I saw a brown dog
Re: Battery Charger Pulsing? [Re: Auae85] #4894620
10/12/18 10:06 AM
10/12/18 10:06 AM
AL
Auae85 Offline OP
Auae85  Offline OP
AL
Well, thankfully all we got was slight winds and about 1-1/2 inches of rain from the hurricane since we were northwest of the main force. Anyway, yesterday afternoon I removed the battery from the truck and put in on the battery charger. No pulsing of the ammeter. I checked the voltage just prior to this, and it was approximately 4.61 volts. I left it on the charger for several hours and took it off last night before bed. Battery was now at 12.22 volts. Before leaving for work this morning, I checked it again, and it had dropped to 11.88 volts. I will check it when i get home to see if it has dropped any further.
Re: Battery Charger Pulsing? [Re: Auae85] #4894621
10/12/18 10:06 AM
10/12/18 10:06 AM
AL
Auae85 Offline OP
Auae85  Offline OP
AL
BW, battery chager seemd to be working fine with no noises or odd smells.
Re: Battery Charger Pulsing? [Re: Auae85] #4895125
10/12/18 08:24 PM
10/12/18 08:24 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
What the voltage at now??? Seems a bit odd it dropped down after going up to 12.22.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Battery Charger Pulsing? [Re: Auae85] #4895162
10/12/18 09:23 PM
10/12/18 09:23 PM
AL
Auae85 Offline OP
Auae85  Offline OP
AL
Checked when I got home and it was approximately 11.5 volts. Had it on the charger since then; I'll disconnect the charger and check the voltage before going to bed, and then check it again in the morning.
Moderated by  ekpolk
