Fram Europe and Purflux or other?
by Kyrgyz_Nomad - 09/23/19 04:19 AM
Discount Tire Direct flash sale
by c502cid - 09/23/19 01:49 AM
Discount Tire Direct Instant $100 Savings One Day ONLY
by 71Chevyguy - 09/23/19 01:48 AM
Hankook Fall Rebate
by FordBroncoVWJeta - 09/22/19 11:23 PM
Axle and exhaust fixes this weekend
by Colt45ws - 09/22/19 11:07 PM
Maxlife v dex/merc
by HyundaiAbuser - 09/22/19 09:24 PM
15,119 Mile Supertech UOA
by Stumpy - 09/22/19 08:54 PM
Rust-Oleum Factor 4
by CatCam2 - 09/22/19 08:20 PM
Local Walmart Magnatec Closeout- Maybe Others?
by SSerian - 09/22/19 07:32 PM
Anti theft measures for new truck
by Oldtom - 09/22/19 07:28 PM
What would you do?
by Rexinaus - 09/22/19 06:26 PM
What size wire for 5 HP motor?
by dlundblad - 09/22/19 06:12 PM
Studless V/S studded winter tires
by cecil56 - 09/22/19 06:10 PM
200K more to Go!
by Gebo - 09/22/19 06:07 PM
Toyota license plate bolts/screws
by edwardh1 - 09/22/19 05:38 PM
How Do You Clean Your Grill ?
by Warstud - 09/22/19 04:05 PM
Curious question?
by Bill_W - 09/22/19 03:06 PM
dburch, Hueiyeh, Texguy, jm1, Dunkaroo
69364 Registered Users
22 registered members (bbhero, dlundblad, Char Baby, Debe, billt460, 1 invisible), 772 guests, and 21 spiders.
Topics294,933
Posts5,069,503
Members69,364
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: 2018 Subie Crosstrek 1st oil change [Re: goodtimes] #4893788 10/11/18 10:37 AM
M
Miller88 Offline
M
Originally Posted by goodtimes
Originally Posted by Miller88
DO NOT use a 12 point socket on the 14mm drain plug. For some reason they put the small drain plug in and then painted it. You can't fit a 13mm on it (or 1/2), but 14mm and 9/16 are lose on it. If you use a 12 point, you will strip it.
they make 17/32 wrenches,.sockets, how about that?
It might actually be the right size. Though, it doesn't use the American system, so I think 13.5 or "13,5mm" is more appropriate!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 2018 Subie Crosstrek 1st oil change [Re: dave123] #4893789 10/11/18 10:38 AM
M
Miller88 Offline
M
Originally Posted by dave123
1st change on my 18 WOW that drain bolt is Tiiiiight!!!! Mine OEM filters only all cut yea it’s a decent filter no problems almost 30k I like the engine never a drop burns. Zepro high moly 0W20.
I couldn't get mine off without some work. I was afraid of rounding it even with a 6 point. I ended up taking a sledge hammer to a 1/2'' drive 6 inch ratchet in order to get it off. I didn't want to yarn on it with a breaker bar and have more risk of rounding it.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 2018 Subie Crosstrek 1st oil change [Re: aba4430] #4893926 10/11/18 01:04 PM
N
nthach Offline
N
Originally Posted by aba4430
Before anyone goes bonkers, the Purolator Boss PBL 14615 is a good filter for the CrossTrek. My son used it on his 18 CrossTrek (@2400 miles now) and I have used it on our 17 OB 2.5 with no issues. The start up rattle is subdued with the PBL14615 on the OB...…., vs. the original blue Subie filter. I am presently running the Fram Ultra 7317 on the OB and will go back to the PBL14615 next time.
Motorking told me the 7317 filters are OK for Subaru applications in Ultra or Tough Guard flavors or he might have mentioned that publically.
The specs on that Purolator look good, maybe I should try one and send it into '53 Stude for a teardown.
I use the Toyota 90915-YZZS1 filter for the FR-S/FT-86, made by Denso in Thailand and it's a fat and short filter that just clears the lip on the oil filter mount. I prefer the OEM Fram-made filter myself but I hate Subaru parts departments.
Re: 2018 Subie Crosstrek 1st oil change [Re: Miller88] #4894201 10/11/18 07:30 PM
F
fdcg27 Online Content
Online Content
F
Other people have mentioned this challenge with this engine, so I approached the first drain with some trepidation.
This proved to be misplaced since the plug on our '17 came out with no special effort.
Part of the problem that people may be having with the drain plug and rounding may be a result of the awkward angle of the plug on the sump as well as the small hatch that Subaru gives you to get to it.
You do have to be careful to properly seat the socket. After that, a clean change is really easy with these as is the case with every Subaru we've owned.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 30K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 95K M1HM 10W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: 2018 Subie Crosstrek 1st oil change [Re: nthach] #4894572 10/12/18 10:04 AM
1
1bioguy Offline OP
1
AGREED! I called the parts dept and they sounded like I was bothering them...NAPA here i come...
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4894576 10/12/18 10:05 AM
1
1bioguy Offline OP
1
"Other people have mentioned this challenge with this engine, so I approached the first drain with some trepidation.
You do have to be careful to properly seat the socket. After that, a clean change is really easy with these as is the case with every Subaru we've owned."
This was helpful , been afraid to try...
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4894626 10/12/18 11:15 AM
PimTac Offline
On a brand new vehicle it’s usually the paint that hinders the first loosening of the drain plug. I use a small sharp knife to score around the plug. The rest is brute strength.
I would rather use a longer ratchet like a 12-14” than hitting it with a sledge hammer. Then again, I was t there.
The filters are usually the hardest part to loosen in a new car.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2018 Subie Crosstrek 1st oil change [Re: PimTac] #4894778 10/12/18 02:12 PM
sw99 Offline
The Subaru bypass setting on factory filters is 23 psi. The Premium Guard PG4615 filter has this exact setting and sell for $1.68 at Rock Auto. I have been running these to 7500 miles and they look fantastic upon the end of life inspection.
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4897248 10/15/18 04:50 PM
1
1bioguy Offline OP
1
Anybody use the Fram Racing HP17??
Re: 2018 Subie Crosstrek 1st oil change [Re: Miller88] #4897281 10/15/18 06:06 PM
G
goodtimes Offline
G
17/32 is 13.5 essentially.
http://mdmetric.com/tech/cvtchtfdm.htm
Page 2 of 2 1 2
