Old skool carburetor rebuilding.
by Chris142 - 09/19/19 07:50 AM
Construction - Vintage Warning
by MasterSolenoid - 09/19/19 06:55 AM
Toro 12-38
by supton - 09/19/19 06:36 AM
EV tuktuk batteries
by Superflan - 09/19/19 02:09 AM
Car engine issues
by Espada - 09/19/19 01:12 AM
2002 chevy tahoe 5.3 oil selection
by Zahndkile - 09/19/19 12:20 AM
Considering Solar
by mbacfp - 09/18/19 11:16 PM
2008 Duramax
by Firemedic15 - 09/18/19 11:02 PM
Fleetguard LF777 performance
by Pyrotechnic - 09/18/19 10:54 PM
Any Vacuum experts? :)
by maverickfhs - 09/18/19 09:50 PM
15 F150 Gear & Transfer Case Question
by BISCUT - 09/18/19 09:24 PM
Anyone buy/run used tires?
by addyguy - 09/18/19 08:15 PM
2019 Mazda CX-5 Diesel
by miden851 - 09/18/19 07:58 PM
Toyota 90915-YZZD1 Cut Open (Sludge?)
by ThirdeYe - 09/18/19 07:45 PM
Fram Core COR3614ACC Cut Open
by ThirdeYe - 09/18/19 07:35 PM
Never the cheap part that goes bad...
by Elkins45 - 09/18/19 07:34 PM
Denso First Time Fit 150-1009 Cut Open (2 filters)
by ThirdeYe - 09/18/19 07:31 PM
2008 CRV A/C compressor replacement
by nwjones18 - 09/18/19 07:27 PM
Fram Ultra XG4967 Cut Open
by ThirdeYe - 09/18/19 07:25 PM
Ford Motorcraft FL-820S Cut Open
by ThirdeYe - 09/18/19 07:12 PM
JDubyah, 05SentraRed, TSpinner, bbrown, Firemedic15
69326 Registered Users
79 registered members (4WD, 2015_PSD, 05SentraRed, 2004tdigls, 97prizm, 9 invisible), 1,460 guests, and 22 spiders.
Topics294,764
Posts5,066,135
Members69,326
Most Online3,532
Jul 30th, 2019
Centric C-TEK 121 Economy Rotors #4893331 10/10/18 07:38 PM
The Critic Offline OP
I posted about this in the humor section for a different reason, but the Centric 121 C-TEK economy rotors are Centric's equivalent to the infamous "whitebox" economy rotors that are sold by many parts stores.
Normally I do not use whitebox economy rotors, however, this brake job was for a lease return and the driver wanted to minimize their costs. The driver did not mind the rusty appearance from unpainted rotors.
This was the first set of economy rotors that I had used in over two years. After properly cleaning the hub flanges, washing the rotors and installing them with conical washers, I measured the lateral runout values and found the following:
L/F = .001"
R/F = .0015" (after indexing, first try yielded .0025")
L/R = .0005"
R/R = .002"
This particular vehicle (2016 Outback 3.6R) allows a max of .002" so all of the values were within spec. From my past experience, economy rotors typically have .003"-.004" of runout and this was simply too much for most modern vehicles. Resurfacing rotors on a bench lathe usually results in .004"-.007" of runout.
Either I got lucky, or I guess economy rotors have gotten a lot better in the last few years. I was a bit blown away. If economy rotors are consistently this good and the driver is on a budget (can't afford or does not want to pay for premium rotors), then economy rotors have truly become a viable low-cost alternative to resurfacing your old brake rotors. The finish felt reasonably smooth as well, and the pads bedded in fairly quickly. I paired these rotors with Akebono ProACT pads on the front axle and Centric 105 PosiQuiet Ceramic pads on the rear axle.
Also, nthach came by and watched me do this brake job. He's cool.
2011 Toyota Prius 1.8L - 197K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4 - 138K - Mobil 1 EP HM 5W-30
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893345 10/10/18 08:02 PM
A
anndel Offline
A
Good enough!
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil XL 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893365 10/10/18 08:27 PM
Propflux01 Offline
And I think you will like those Akebono pads. I am impressed withe 40K I have on mine so far.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893375 10/10/18 08:33 PM
F
FlyNavyP3 Offline
F
On a lease return I would've been tempted to put the cheapest pads known to man on that Subaru. You're a better man than me. Nice work and excellent run out numbers for budget parts!
Luke
Re: Centric C-TEK 121 Economy Rotors [Re: FlyNavyP3] #4893396 10/10/18 09:02 PM
The car is getting returned in Dec.
Thanks.
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893405 10/10/18 09:15 PM
daves87rs Offline
Very nice!!!
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4893561 10/11/18 04:00 AM
Char Baby Offline
I have used C-TEK rotors(and pads) with good success. I have also use DURAGO rotors as well with the same success. But, this success is also based on the vehicle that they're being installed on. In other words, I had good success with them on a lower end MAZDA and mid level NISSAN. However, I've had even better success with them on a LEXUS. So, it depends on the car & rotor manufacturers spec of the rotors, is how well you'll do with them.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Centric C-TEK 121 Economy Rotors [Re: FlyNavyP3] #4893666 10/11/18 08:15 AM
H
hallstevenson Offline
H
I was thinking the same thing. It's not to be cheap or a sh***y person either, it's just not necessary for someone returning a leased vehicle to do at the end of a lease.
Re: Centric C-TEK 121 Economy Rotors [Re: hallstevenson] #4894377 10/12/18 01:35 AM
Sure, I understand where you are coming from. But I also will not put my name on a substandard brake job. The owner would have preferred to not do the brakes at all, but the rears were grinding and the fronts were at 1mm.
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4894507 10/12/18 08:55 AM
H
H
How did you get involved ? Was this a friend's car that you did in your garage or driveway or do you have a repair shop ? If you use parts specified by the customer and do a proper, quality brake job, I wouldn't consider it "substandard" in any way.
Re: Centric C-TEK 121 Economy Rotors [Re: Char Baby] #4896654 10/14/18 10:40 PM
spasm3 Offline
Originally Posted by Char Baby
I I have also use DURAGO rotors as well with the same success.
Glad to hear that! I just ordered some DURAGO coated rotors from RA for the hyundai. Going with the centric stoptech street pads 308.15430.
Will see how they do.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4896659 10/14/18 10:59 PM
slacktide_bitog Offline
Basically the same as Centric Premium but without the coating.
The C-Tek will probably be ok for awhile since you're lucky enough to not have rust (on the east coast, non-coated rotors rust overnight), but they are NOT usable anywhere up north where you get rust.
Re: Centric C-TEK 121 Economy Rotors [Re: slacktide_bitog] #4901208 10/20/18 02:30 PM
H
HangFire Offline
H
Ouch. There is a local race-oriented machine shop that does much better than that. But your average brake and muffler shop, yeah, I can believe that.
I'm sure I've opined on here before, that if new rotors pass parallelism (usually) and runout (sometimes) tests, then good enough is good enough. Rust is another issue. C-Tek is usually within the spec that you can find on the RockAuto site. I have a set of Centric C-Tek's on my Corolla, that are at 4 years 2 months and 76K miles and doing fine. The pads are about done, though, I just bought their replacements, and plan to put them on this coming week.
Surface rust on the friction surfaces happens on coated rotors overnight as well, because the coating is toast on break-in, and it's just as harmless on coated as it is on uncoated rotors.
It's the rust from the edges and ventilated back side eating its way through that is the hazard. My experience in heavily salted Maryland (we may not have all of the snow, but due to Winter-long freeze/thaw cycles, we have all of the salt) is that coated rotors give you one more year before this happens, but it still takes 4-6 years. If you are putting 20K+ a year (as we do) on your vehicle, you'll get your money's worth out of an uncoated rotor (60-80K miles). If you drive 10K or less a year, or just prefer a nicer appearance, a coated rotor is a worthy upgrade.
Various musings: http://hangfire.net
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4902106 10/21/18 03:22 PM
Apparently, the owner decided to return the car early and the car is now being marketed as a CPO unit on the dealer’s lot.
I am curious if the dealer had to re-do the brakes before sale since they were not OEM Subaru.
Re: Centric C-TEK 121 Economy Rotors [Re: The Critic] #4902151 10/21/18 04:09 PM
SatinSilver Offline
If the dealer links a Carfax report to the car it may show whether they did a new brake job to it or not. My guess would be they left it as-is.
