Mag1 gear oil at PepBoys
by kstanf150 - 10/13/19 02:33 PM
1000Bulbs.com 500 at Talladega
by bdcardinal - 10/13/19 12:35 PM
HF small flasher
by Donald - 10/13/19 12:19 PM
Amsoil SVG 75W-140-Ford PTU
by Whimsey - 10/13/19 11:37 AM
How Much Does ATF Expand With Heat?
by Whalstib - 10/13/19 10:42 AM
Pro-Gold gun lube
by The_Eric - 10/13/19 10:41 AM
Strange lighting issue in house...
by dja4260 - 10/13/19 10:27 AM
Filtech made?
by Bettez88 - 10/13/19 10:15 AM
Costco Fuel mix-up
by RhondaHonda - 10/13/19 08:57 AM
Xfinity removed TCM from HD preferred!
by ARCOgraphite - 10/13/19 08:49 AM
Porsche 911 997 UOA
by Porscheman - 10/13/19 08:43 AM
Harvest King still Citgo???
by csandste - 10/13/19 08:06 AM
Annoying compressor oil requirements
by dlundblad - 10/13/19 06:46 AM
Pro Mechanic's tire prices from the wholesaler
by MoneyJohn - 10/13/19 06:44 AM
Dake Arbor Press
by clinebarger - 10/13/19 02:59 AM
Animals annoying other animals
by Shannow - 10/13/19 01:39 AM
Conventional to synthetic
by CruiserRX - 10/13/19 01:36 AM
How are these filters?
by domer10 - 10/12/19 11:18 PM
Oil changes - Cat and Volvo
by Toy4x4 - 10/12/19 11:03 PM
Covington, pktrkt, Wyoclean, rrretiree7, SkipNJump
69545 Registered Users
93 registered members (2015_PSD, 928, AlienBug, 4WD, ammolab, ArrestMeRedZ, 20 invisible), 2,369 guests, and 21 spiders.
Topics295,918
Posts5,087,267
Members69,545
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
2012 Mercedes - wheel bolts instead of studs #4894137 10/11/18 06:18 PM
N
Number_35 Offline OP
N
Earlier today I installed the winter tires (mounted on alloys) on a friend's 2012 Mercedes C300. It was interesting to see that this car uses bolts into threaded holes in the hubs to hold the wheels on, rather than the much more common studs and lug nuts. I saw this on a few Mazdas back in the '70s, but had not seen it since. It makes installing the wheels a bit of a challenge.
Is this standard for Mercedes? Any other manufacturers? What are the advantages?
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894140 10/11/18 06:24 PM
J
JeffKeryk Offline
J
VW's used wheel bolts instead of studs.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894141 10/11/18 06:26 PM
Q
Quattro Pete Offline
Q
It's standard for most of the German makes, AFAIK.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894163 10/11/18 06:46 PM
H
hallstevenson Offline
H
A co-worker has a '17 VW Tiguan and it uses bolts too. It sucks compared to studs. At least with studs you can kinda hook/hang the wheel while lining things up.
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894165 10/11/18 06:50 PM
skyactiv Offline
Yes on it being a German thing. Both cars in my signature use wheel bolts. Mercedes Sprinter vans also use wheel bolts.
Using lug bolts also gives you more variation in terms of the wheels and offsets you can use. You can use longer bolts and spacers for different wheel offsets.
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894166 10/11/18 06:51 PM
A
Audios Offline
A
BMW has had it since the 80s, All european cars have had it since I started working on cars in 2001.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894168 10/11/18 06:54 PM
F
fcjeep Offline
F
My wife's 2014 Jeep Cherokee had the same set up. Yes it's a little bit of a PITA to put the wheel back on.
I don't know yet about her 2016 Grand Cherokee as I haven't pulled a wheel yet.
2006 Jeep GC 4.7L, Died @ 153059 mi frown
2008 Xterra 4.0L, 104500 mi
2016 Jeep GC 3.6L, 19100 mi
2017 Benz C300 14000 mi
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894180 10/11/18 07:12 PM
DB_Cooper Offline
In the tool kit on most German cars is supposed to the a threaded "Wheel Hanger", check you owners manual. Some are plastic and others steel. If you know the metric thread size you can order one from Amazon for about $10. Available in 12x1.5 14x1.25 etc. Makes the job much easier.
Steel wheel hanger $10
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Quattro Pete] #4894184 10/11/18 07:15 PM
F
fdcg27 Offline
F
Like QP said. Every German car I've owned had lug bolts rather than studs and nuts.
Every car also had some sort of helper included in the original tool kit from which you could hang the wheel while threading in a couple of the bolts.
Not sure why this particular design was used, but I'm sure that Trav will be along to give us the reason.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 30K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894191 10/11/18 07:20 PM
T
Trav Offline
T
Just use a hanging stud, you can but one or just cut a bolt, its a non issue. One advantage is you don't need to remove the caliper bracket to swap the rotor just remove one caliper pin bolt and flip it up.
Another reason is in Europe most drivers have aluminum wheels for the summer and steel for the winter, they use different length bolts.
https://www.amazon.com/Steel-Wheel-Hanger-Automotive-Volkswagen/dp/B00MWAQGSQ
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894192 10/11/18 07:21 PM
dbias Offline
My VW and Audi have them and it just takes a little getting used to. There is a dowel type thing in my tire change kit that you can stick in a hole to help line up but I've never used it. Being hub centric the wheels fit snug to the hub so I just jam it up there and spin to line up the holes. On the audi wheels there is a slight indentation on the backside that makes a slight rust mark where water gets into the indentation and makes a distinctive mark on the rotor surface where the wheel snugs up to so once I have the wheel on the hub I just spin the wheel until the rust mark lines up with the indentation and presto bolts drop right in.
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894212 10/11/18 07:43 PM
4
440Magnum Offline
4
The last car I had with lug bolts was my 1949 Plymouth. I've seen it more recently on light-duty trailer axles.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: 2012 Mercedes - wheel bolts instead of studs [Re: DB_Cooper] #4894230 10/11/18 08:02 PM
N
N
Thanks all for the feedback. I bet there was something there, but I didn't think to look for it. (If you don't know a thing exists, you don't look for it.)
Another interesting thing was that the car came with one anti-theft bolt per wheel (plus four normal hex-head bolts per wheel). Each anti-theft bolt had a very complex pattern (which was the same for all four anti-theft bolts), and there was a matching male key. I was worried that I wouldn't get the anti-theft bolts off, but they weren't too bad. Some of the other bolts were on way too tight; I guess having to use a key prevented the last shop from torquing the anti-theft bolt down as hard as the others.
Re: 2012 Mercedes - wheel bolts instead of studs [Re: hallstevenson] #4894250 10/11/18 08:34 PM
Q
Q
When they corrode and rust away, what's cheaper and easier to replace: studs or bolts?
Re: 2012 Mercedes - wheel bolts instead of studs [Re: Number_35] #4894255 10/11/18 08:37 PM
T
Trav Offline
T
I wonder how many people remember left hand thread studs and lug nuts on one side of Chrysler and GM vehicles.
Page 1 of 3 1 2 3
