delete
by beanoil. 02/16/19 10:37 AM
105 registered members (advocate, 4WD, 2009Edge, 69Torino, 240_Ed, 13 invisible),
2,283
guests, and 59
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,274
Posts4,988,501
Members67,248
Most Online2,474 Feb 10th, 2019
Re: 2012 Mercedes - wheel bolts instead of studs
[Re: Number_35]
#4894140
10/11/18 05:24 PM
10/11/18 05:24 PM
Posts: 1,032 Los Gatos, CA
JeffKeryk
Los Gatos, CA
VW's used wheel bolts instead of studs.
2018 Tesla Model 3, Medium Range Battery 2018 Lexus RX450h 2013 Lexus GS350 F Sport 2006 Acura TSX 2001 Tundra Access Cab, 1998 Accord LX, 1968 Corvette L36 Roadster, 1965 Olds 4-4-2
[Re: Number_35]
#4894141
10/11/18 05:26 PM
10/11/18 05:26 PM
Posts: 36,899 Great Lakes
Quattro Pete
Great Lakes
It's standard for most of the German makes, AFAIK.
'02 530i (Edge 0W-40) '15 Q5 3.0T (Edge 5W-40) '18 Charger SRT (PUP 0W-40 SRT)
[Re: Number_35]
#4894165
10/11/18 05:50 PM
10/11/18 05:50 PM
Posts: 5,203 The Midwest
skyactiv
The Midwest
Yes on it being a German thing. Both cars in my signature use wheel bolts. Mercedes Sprinter vans also use wheel bolts.
Using lug bolts also gives you more variation in terms of the wheels and offsets you can use. You can use longer bolts and spacers for different wheel offsets.
Wife: 15' Audi A4 quattro 6 speed manual Me: 13' VW GTI 3 door 6 speed manual Wanted: 2019 Ford Ranger
[Re: Number_35]
#4894166
10/11/18 05:51 PM
10/11/18 05:51 PM
Posts: 1,398 Lyndhurst NJ
Audios
Lyndhurst NJ
BMW has had it since the 80s, All european cars have had it since I started working on cars in 2001.
2002 VW Golf TDI-Mobil 1 5/40 TDT 2007 Mercedes GL320 CDI- M1 0/30 ESP 2005 BMW M3 BMW Twin Power 10/60 2003 BMW M5-Fuchs 5/40 1998 BMW M3/4/5 Fuchs 5/40
[Re: Number_35]
#4894168
10/11/18 05:54 PM
10/11/18 05:54 PM
Posts: 186 NY
fcjeep
NY
My wife's 2014 Jeep Cherokee had the same set up. Yes it's a little bit of a PITA to put the wheel back on. I don't know yet about her 2016 Grand Cherokee as I haven't pulled a wheel yet.
2006 Jeep GC 4.7L, Died @ 153059 mi 2008 Xterra 4.0L, 104500 mi 2016 Jeep GC 3.6L, 19100 mi 2017 Benz C300 14000 mi
[Re: Number_35]
#4894180
10/11/18 06:12 PM
10/11/18 06:12 PM
Posts: 410 Ga
DB_Cooper
Ga
In the tool kit on most German cars is supposed to the a threaded "Wheel Hanger", check you owners manual. Some are plastic and others steel. If you know the metric thread size you can order one from Amazon for about $10. Available in 12x1.5 14x1.25 etc. Makes the job much easier. Steel wheel hanger $10
[Re: Quattro Pete]
#4894184
10/11/18 06:15 PM
10/11/18 06:15 PM
Posts: 16,436 OH
fdcg27
OH
It's standard for most of the German makes, AFAIK. Like QP said. Every German car I've owned had lug bolts rather than studs and nuts. Every car also had some sort of helper included in the original tool kit from which you could hang the wheel while threading in a couple of the bolts. Not sure why this particular design was used, but I'm sure that Trav will be along to give us the reason.
18 Accord Hybrid FF 17 Forester 18K VME 0W-20 12 Accord LX 96K SSO 0W-20 09 Forester 95K M1HM 10W-30 01 Focus ZX3 118K PP 5W-20 96 Accord LX 104K T5 10W-30 95 318i
[Re: Number_35]
#4894191
10/11/18 06:20 PM
10/11/18 06:20 PM
Posts: 20,958 MA, Mittelfranken.de
Trav
Earlier today I installed the winter tires (mounted on alloys) on a friend's 2012 Mercedes C300. It was interesting to see that this car uses bolts into threaded holes in the hubs to hold the wheels on, rather than the much more common studs and lug nuts. I saw this on a few Mazdas back in the '70s, but had not seen it since. It makes installing the wheels a bit of a challenge.
Is this standard for Mercedes? Any other manufacturers? What are the advantages? Just use a hanging stud, you can but one or just cut a bolt, its a non issue. One advantage is you don't need to remove the caliper bracket to swap the rotor just remove one caliper pin bolt and flip it up. Another reason is in Europe most drivers have aluminum wheels for the summer and steel for the winter, they use different length bolts. https://www.amazon.com/Steel-Wheel-Hanger-Automotive-Volkswagen/dp/B00MWAQGSQ
[Re: Number_35]
#4894192
10/11/18 06:21 PM
10/11/18 06:21 PM
Posts: 319 Huntington WV
dbias
Huntington WV
My VW and Audi have them and it just takes a little getting used to. There is a dowel type thing in my tire change kit that you can stick in a hole to help line up but I've never used it. Being hub centric the wheels fit snug to the hub so I just jam it up there and spin to line up the holes. On the audi wheels there is a slight indentation on the backside that makes a slight rust mark where water gets into the indentation and makes a distinctive mark on the rotor surface where the wheel snugs up to so once I have the wheel on the hub I just spin the wheel until the rust mark lines up with the indentation and presto bolts drop right in.
2011 VW JETTA Castrol Edge 0W-40 2012 FORD TRANSIT CONNECT Castrol Edge 5W-20 2016 HONDA CIVIC COUPE Frankenbrew 0W-20 to 5w-40 2017 AUDI A4 Castrol Edge 0W-40
[Re: Number_35]
#4894212
10/11/18 06:43 PM
10/11/18 06:43 PM
Posts: 8,807 Texas
440Magnum
Texas
The last car I had with lug bolts was my 1949 Plymouth. I've seen it more recently on light-duty trailer axles.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727 '08 Ram 1500 4.7/545RFE '12 Challenger SRT8 392/6-speed '99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
[Re: DB_Cooper]
#4894230
10/11/18 07:02 PM
10/11/18 07:02 PM
Posts: 1,097 Winnipeg MB CA
Number_35
OP
OP
Winnipeg MB CA
In the tool kit on most German cars is supposed to the a threaded "Wheel Hanger", check you owners manual. Some are plastic and others steel. If you know the metric thread size you can order one from Amazon for about $10. Available in 12x1.5 14x1.25 etc. Makes the job much easier. Steel wheel hanger $10Thanks all for the feedback. I bet there was something there, but I didn't think to look for it. (If you don't know a thing exists, you don't look for it.) Another interesting thing was that the car came with one anti-theft bolt per wheel (plus four normal hex-head bolts per wheel). Each anti-theft bolt had a very complex pattern (which was the same for all four anti-theft bolts), and there was a matching male key. I was worried that I wouldn't get the anti-theft bolts off, but they weren't too bad. Some of the other bolts were on way too tight; I guess having to use a key prevented the last shop from torquing the anti-theft bolt down as hard as the others.
[Re: hallstevenson]
#4894250
10/11/18 07:34 PM
10/11/18 07:34 PM
Quattro Pete
Great Lakes
A co-worker has a '17 VW Tiguan and it uses bolts too. It sucks compared to studs. When they corrode and rust away, what's cheaper and easier to replace: studs or bolts?
[Re: Number_35]
#4894255
10/11/18 07:37 PM
10/11/18 07:37 PM
Trav
I wonder how many people remember left hand thread studs and lug nuts on one side of Chrysler and GM vehicles.
