Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
2004 Cavalier 2.2L Oil Change Interval?
by Bob5150 - 02/26/20 08:44 AM
Amazon Redline 5w30 $41.99/gal
by SubieRubyRoo - 02/26/20 08:00 AM
Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
103 registered members (Amenhotep, 2013ecof150, 762fermeandyou, 1978elcamino, 55hambone, 2010Civic, 10 invisible), 2,193 guests, and 17 spiders.
Topics301,953
Posts5,206,284
Members70,808
Page 3 of 3 1 2 3
Re: Wired Routers [Re: Vikas] #4886843 10/03/18 07:48 PM
StevieC Offline
Originally Posted by Vikas
Delhi is a HUGE city; you are the first person to call Delhi as "rural"
(Ya, I know about the snow storms in Miami too :-)
Delhi, Ontario is a farming town and it's not huge at all. Maybe in area but it's not like a city like Toronto. grin2
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Wired Routers [Re: Vikas] #4886849 10/03/18 08:01 PM
Quattro Pete Offline
Not that Delhi. smile
Delhi, Ontario
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Wired Routers [Re: fraso] #4887071 10/04/18 08:43 AM
V
Vikas Offline
V
I wonder how many kids join Miami University before realizing that it is NOT in *that* Miami!
Re: Wired Routers [Re: Subdued] #4893692 10/11/18 07:46 AM
F
fraso Offline OP
F
Originally Posted by Subdued
Since the cheapies are only 100mb they only use 4 conductors. It's not an issue that they only have 4 pins. Number of pins has nothing to do with duplex or no duplex.
You run into duplex issues when one end is configured for auto/auto and the other end is set to 100/full. the auto side doesn't get the negotiation information it needs from the hard coded end, so it falls back to half duplex.
both ends need to be auto/auto or 100/full. Don't mix speed/dulex.
My TL-WR841N is spec'd for 10/100Mbps Ethernet ports. The router does in fact have 4-pin ports. My old EBR-2310 is also spec'd for 10/100Mbps (IEEE 802.3u 100Base-TX Fast Ethernet & IEEE 802.3 NWay Auto-Negotiation) but has 8-pin ports. My two 10/100 switches also have 8-pin ports.
I thought that that full-duplex requires 8-pins and 4-pin only permits half-duplex communication.
Re: Wired Routers [Re: fraso] #4893921 10/11/18 11:58 AM
O
OVERKILL Online Content
Online Content
O
No, you need all of them for Gig-E, 100 will work fine at full duplex.
Re: Wired Routers [Re: fraso] #4893985 10/11/18 12:58 PM
V
Vikas Offline
V
I had never come across 4-pin ethernet cable. the only 4-pin cable was the 2-line telephone one. half of the responders here never even seen a telephone cable :-)
Couple of weekend ago I was at friends house and a 2 year toddler of guest was asking his dad what was the thingy with corded cable hanging from the wall!
Re: Wired Routers [Re: fraso] #4893996 10/11/18 01:09 PM
P
PandaBear Offline
P
So the Ethernet connection between the 2 routers goes through a wiring panel? Did you make sure the wiring are connected to the right "pair" as they were?
The reason I ask is, about 18 years ago, I bought a cable from ebay and the seller crimp the wiring pair wrong, so instead of the 1-2, 3-6, 4-5, 7-8 pairs end up being 1-2, 3-4, 5-6, 7-8, and one pair is not twisted as expected. My network would go 10Mbps but not 100Mbps. I research online and found that, and then re-crimp it myself and the problem went away.
If you can borrow an ethernet switch to test, you can use that to rule out the router or the cable. Narrow it down to which component and go from there.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Wired Routers [Re: fraso] #4894533 10/12/18 08:20 AM
F
fraso Offline OP
F
My Ethernet distribution panel is a a ChannelPlus H236 enclosure with ChannelPlus H628 data termination hubs. This panel is in my basement and I've run Cat 5 cable to Leviton RJ45 wall jacks in conduit throughout my house. The hubs and wall jacks are color-coded so it's hard to connect them incorrectly. Having checked my connections in Windows previously, I've regularly connected to the network at 100 Mbps.
I only have one router in operation. I have Cat5 (has foil, might be 5e) cable from the tower switch to my router and that same cable from the router to one of my switches. The cable from the router to the switch is terminated with a modular plug at both ends. When running the Cat5 cable, I used a punchdown tool to connect all 8 wires in the hubs and wall jacks.
What I would like to know is clarification about Subdued's comment about cheap routers having 4 pins rather than 8. My old D-Link EBR-2310 and DIR-601 both have 8-pin Ethernet ports but my new TP-Link TL-WR841N only has 4-pin ports.
Do good 10/100 routers have 8-pin ports?
What implications does having a 4-pin Ethernet port have compared with an 8-pin port?
Would my old D-Link 10/100 routers have had better Ethernet performance than my new TL-WR841N?
Re: Wired Routers [Re: fraso] #4900613 10/19/18 06:56 PM
F
fraso Offline OP
F
From what I've able to find so far, the number of pins in the port doesn't matter for a 10/100 router or switch because the connection only uses 4 wires.
Since one of my old switches has a bad port, I thought I would upgrade to a 16 port gigabit switch (TP-Link TL-SG1016D). I've ordered a wired gigabit router (TP-Link TL-R600VPN) to match the gigabit switch. I'm happy with my TP-Link TL-WR841N router and I'm going to repurpose it as a WAP in a better location than where it's mounted now as a router.
Thanks for the great advice. After getting my connection speed sorted out, I did a write-up about my experience in case others were in a similar situation: Home Networks
Page 3 of 3 1 2 3
