33 registered members (bbhero, Amkeer, AurionX2, Bookmaker, Bighorn2500, Bailes1992, 3 invisible),
757
guests, and 16
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,787
Posts5,141,067
Members70,121
Most Online3,589 Nov 2nd, 2019
What seals do HM oils condition?
#4893301
10/10/18 06:02 PM
buster
OP
OP
Posts: 32,601 |
The most common engine seals that eventually seems to leak are the rear main and valve cover gasket. What other seals would a HM oil help prevent leaks in?
Rear main, Crank Seal Front/Rear CAM seals OCV?
It won't have an impact on valve cover.
2019 Frontier Pro 4X - RGT 5w30 2019 Impreza Sport - OE fill
Re: What seals do HM oils condition?
[Re: buster]
#4893311
10/10/18 06:08 PM
The Critic
Posts: 21,372 |
HM oil is unlikely to have any impact on surfaces that were sealed using RTV.
I would expect it to have an impact on all other seals/gaskets though.
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30 2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
[Re: The Critic]
#4893326
10/10/18 06:33 PM
buster
OP
OP
Posts: 32,601 |
[Re: buster]
#4893342
10/10/18 06:57 PM
anndel
Posts: 892 |
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter 2005 Toyota Avalon XL, 3.5L V6, Amsoil XL 5W-30, Amsoil Filter 2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
[Re: buster]
#4893382
10/10/18 07:46 PM
Warstud
Posts: 6,825 |
[Re: Warstud]
#4893385
10/10/18 07:49 PM
Snagglefoot
Posts: 5,314 |
I imagine the front seal and rear main seal are most important and the rear main seal is the hardest to replace.
If you want the job done right......do it yourself.
[Re: buster]
#4893484
10/10/18 10:08 PM
dwendt44
Posts: 4,156 |
Hopefully the valve seals would benefit from HM oils as well and the front and rear crank seals.
My 2¢
There's no such thing as: Too big of a battery, Too large of a gas tank, or too loud of a horn, or too bright headlights.
[Re: dwendt44]
#4893492
10/10/18 10:29 PM
VeryNoisyPoet
Posts: 427 |
Hopefully the valve seals would benefit from HM oils as well and the front and rear crank seals. My 2¢ I've used high mileage oils from Pennzoil, Castrol, Mobil 1, and Valvoline for the past 30k miles. In that time, the puff of blue smoke on startup from weak valve seals has gone from significant down to almost non-existent. When I had the intake manifold off this spring I could see a tiny bit of oil seeping down the valve stems, but apparently that's not enough to make any visible smoke when it fires up. I did have a rear cam seal start to weep this winter, but that may have been previously weakened when the pcv system failed and pressurized the crankcase a few years back. I know it puked oil from the top end when that happened. Don't have good data on overall oil consumption with HM vs non-HM since the car had slow leaks of various nature from hoses and places other than seals up until this year when I fixed the last of the problems. This oci it's using about 1 quart in 5k miles.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
[Re: buster]
#4893504
10/10/18 11:10 PM
SavagePatch
Posts: 790 |
What about Spark Plug Tube Seals?
[Re: SavagePatch]
#4893576
10/11/18 04:07 AM
LEADED
Posts: 140 |
This is 2018 , most Seals nowadays are VITON , not your 1970 rubber different Materials are used in sealing aModern engine . I use Hi Milage oil in lawn Tractor .
[Re: LEADED]
#4893589
10/11/18 04:54 AM
RyanY
Posts: 486 |
This is 2018 , most Seals nowadays are VITON , not your 1970 rubber different Materials are used in sealing aModern engine . I use Hi Milage oil in lawn Tractor . Good point, but when did this start? HM oil cut down consumption in my 2007 from 1qt/1k to about half a qt/5k. I don't know what it is doing but it is doing it well.
2007 Cadillac CTS 3.6L >127k miles (Castrol Magnatec 5W-30 + ACDelco PF2129G)
2012 Honda Odyssey EX-L >103k miles (Pennzoil Platinum 0W-20 + Fram XG7317)
[Re: buster]
#4893633
10/11/18 06:19 AM
MolaKule
Global Moderator
Global Moderator
Posts: 20,638 |
When discussing seals such as in engines, transmissions, and other driveline components, the context is that of using flexible, elastomeric materials to keep fluids contained within the mechanical system that have rotating components exiting the system, such as protruding rotating shafts.
For a gasket, the context is that of using a material (such as silicone or cork or composite), or some other material to keep fluids contained in and around stationary objects, such as the valve cover gasket on an engine or the pan gasket on an automatic transmission.
Both seals and gaskets "prevent" loss of fluids...
Conditioning seals refers to the following actions:
Seal swell due to Seal elastomer molecular replacement Seal cleaning, .
"Dr. Larry Fleinhardt: You know that it's considered unsolvable? Charlie Eppes: Well, certainly people who have failed to solve it might think that." From NUMB3RS
[Re: buster]
#4893967
10/11/18 12:44 PM
jongies3
Posts: 1,393 |
I personally don't think they do anything different than non high mileage oils. I personally think HM is just a marketing term. I've never noticed a difference in stopping oil leaks or reducing burn off with HM and standard conventional oil. Never tried HM synthetics but I imagine the results would be similar. Another thing to consider is if HM oils are such a great thing, why are there no diesel HM oils? Diesel engines typically outlast gas engines by almost double the mileage so why don't we see things like Rotella, Delo or Delvac HM brews? Food for thought.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter 2003 Buick Park Avenue Ultra S/C 3.8 V6: PYB 5W-30, FRAM PH3387 filter 2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
[Re: buster]
#4894194
10/11/18 06:25 PM
DONWATERS
Posts: 162 |
I think HM oils are all on the thicker side of the stated viscosity which may cut down on leaks also. I also believe that conventional oil is always better at slowing leaks than synthetic given the same weights.
