First generator
by daves87rs - 05/31/20 01:50 AM
New junk tool
by P10crew - 05/31/20 01:07 AM
tetraethyl lead additive
by painfx - 05/31/20 12:40 AM
Best handheld cordless vacuum?
by montero1 - 05/31/20 12:15 AM
2005ToyotaSolara3MZ-
FE coolant leak
by juca - 05/30/20 11:22 PM
I made a dually today. Carftsman LT1000
by ls1mike - 05/30/20 10:39 PM
New Prestone Products
by Snagglefoot - 05/30/20 09:17 PM
BEST OBD2 scanner for UNDER $100
by flinter - 05/30/20 08:44 PM
Oil Drain vs Extraction
by js1956 - 05/30/20 08:08 PM
Toro SR Won't Stop Running
by jkasch - 05/30/20 08:05 PM
Lexus RX350 Oil Filter Housing Question (with pic)
by CrackyWainwright - 05/30/20 07:57 PM
Oil Filter and Coolant Question
by maverickfhs - 05/30/20 07:33 PM
Second change on rebuilt LS
by KirklanC - 05/30/20 07:05 PM
Certified Used Toyota; 8 miles.
by simple_gifts - 05/30/20 05:47 PM
Motul Specific LL01-FE 5w-30 for BMW S55
by sharpmoney - 05/30/20 04:36 PM
Thinking of Buying Compressor
by Mr_Luke - 05/30/20 04:16 PM
juca, jrow96, Kotsos, sharpmoney, Dermented
71581 Registered Users
23 registered members (Anduril, ArrestMeRedZ, bachman, Ctopher, blufeb95, carlprop), 1,221 guests, and 21 spiders.
Topics306,071
Posts5,285,875
Members71,581
MB GLE 350 engine oil weight #4893158 10/10/18 04:21 PM
M
MaximaGuy Offline OP
M
Folks:
For the vehicle in my signature, I am about to change oil and it calls for 229.5 speced MB fluids
Pennzoil Platinum has been my favorite for years and its comes in 5W30, though most MB owners I have spoken to use 0w40/5w40 M1
Let me know your thought
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893167 10/10/18 04:29 PM
N
nthach Offline
N
As long as it meets that particular Mercedes spec, I don't see a problem using it. There is Euro-spec PP but that's hard to find. If you're buying oil at Walmart, M1 0W-40 or Castrol Edge 5W-40/0W-40 are your best bets.
Mercedes is kinda weird - they recommend M1 for service fill, but they work with Shell for OEM-fill fluids.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893215 10/10/18 05:06 PM
K
kschachn Offline
K
Grade and brand fade into irrelevance as long as it carries the approval.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893317 10/10/18 07:15 PM
The Critic Online Crying
Online Crying
Originally Posted by MaximaGuy
Folks:
Pennzoil Platinum 5W30 does not meet the required specs for your vehicle - you will need to use the Platinum Euro 5W-40.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893343 10/10/18 07:59 PM
M
M
2018 MB GLE350
2011 Lexus ES350
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893361 10/10/18 08:20 PM
Z
zeng Offline
Z
This Euro L carries C3 and 229.51.
Go for it.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893370 10/10/18 08:32 PM
M
M
My intention is to stick with 30 weight since the engine is new - it may be a good idea when it goes into the 100K+ range to switch to 40 weight.
2018 MB GLE350
2011 Lexus ES350
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893389 10/10/18 08:54 PM
Snagglefoot Offline
Here is the Euro L:
If you want the job done right......do it yourself.
Re: MB GLE 350 engine oil weight [Re: zeng] #4893493 10/10/18 11:30 PM
W
Wolf359 Online Content
Online Content
W
Go for it.
This is a common mistake. MB 229.5 and 229.51 are TWO different specs. They spec 229.5 for gas engines and 229.51 and 229.52 for diesel engines. Because they have a 10k oil change interval, you're better off with a 229.5 oil than a 229.51 oil although you can use a 229.51 oil in a car that calls for 229.5. It's been covered multiple times in past threads.
I believe Mobil is actually the OEM maker of oil for Mercedes. Shell makes a bunch of transmission fluids you can use such as 236.14 and 236.15.
Check out the list of approved MB 229.5 fluids. You will not find the 229.51 fluids on there.
https://bevo.mercedes-benz.com/bevolisten/bevo-sheets-sort1.html
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893550 10/11/18 03:28 AM
Snagglefoot Offline
The OP wants to use a 5w30 oil. The Euro L, which is designed as a diesel motor oil, is also rated C3 which is fine for a gasoline engines He was also partial to Pennzoil products.
Is there a 5w30 229.5 product out there? I’ve seen 5w40 229.5 products but so far I haven’t see a 5w30 version. I certainly could be wrong about that. Please let me know. smile
Re: MB GLE 350 engine oil weight [Re: Wolf359] #4893556 10/11/18 03:41 AM
Z
zeng Offline
Z
Here is another common myth/mistake on this board.
A 229.5 is meant for a MB gasoline engines ONLY , and it's NOT for (light duty ) diesel engines (with modern emission systems) .
However, a 229.51 mid saps oils is always meant for a diesel engines, AND gasoline engines.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893583 10/11/18 05:27 AM
P
Popsy Offline
P
I always thought the MB 229.5 was originally based on the ACEA A3/B4 specs, but actually it's only mandatory to pass the ACEA tests when the specs are claimed on the package, if I understand correctly.
I am yet to see a 229.5 that does not carry A3/B4, I guess when you reach 229.5 perfs, the ACEA comes for "free" !
There are some OM 646 and VW TDI tests for MB 229.5 though.
Ok, that is to say, to me pretty much all MB229.5 oils are also ok for light diesel use, and that's precisely what I use in my old old old diesel...simply because the Total 5W40 I use is cheap and carries it.
(but yes, contrary to the .51/52, if you have emission aftertratement devices, avoid 229.5 in your engine)
Also I thought Petronas was the current OEM for Mercedes (at least in Europe) ?
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893600 10/11/18 06:19 AM
Snagglefoot Offline
Here is the back panel of a bottle of Pennzoil Platinum Euro 5w40. One of the specs it meets is MB 229.5. In the white box it says “For diesel and gasoline engines”. It also says AECA A3/B4. Enjoy.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893743 10/11/18 09:42 AM
M
M
The owners manual has either 229.5 or 229.6 for gasoline engines and 229.51 for diesel engines.
2018 MB GLE350
2011 Lexus ES350
Re: MB GLE 350 engine oil weight [Re: zeng] #4893896 10/11/18 12:27 PM
W
Online Content
W
While that's somewhat true, if you take your car to an MB dealer, they will only put MB 229.5 oil into a gasser and MB 229.51 or 229.52 into a diesel. Yes, you can use 229.51 or 229.52 in a gasser, but it's not ideal. That's why MB specs 229.5 still for gassers. MB 229.51 or 229.52 doesn't supersede 229.5. Whereas you can use 229.52 where 229.51 is called for. If you have a choice of oils, just use 299.5 oils in a gasser, it's not making it better by using 229.51.
