Hey BusyLittleShop
by Shannow - 10/21/19 04:47 AM
TT Equalizer: MORryde CRE3000 VS Lippert Equa-Flex
by SavagePatch - 10/21/19 12:53 AM
Milwaukee 2485-20 M12 1/4” Right Angle Die Grinder
by The Critic - 10/21/19 12:41 AM
Group 78 Battery Connector Issues
by Falcon_LS - 10/21/19 12:37 AM
Factors that can affect warming up time
by SlavaB - 10/20/19 11:59 PM
A nokian lineup review
by UG_Passat - 10/20/19 11:19 PM
Dealer Oil Change
by HowAboutThis - 10/20/19 10:35 PM
small qty of automitive paint
by danez_yoda - 10/20/19 09:36 PM
2017 Chevy Cruze recommended oil filter
by Electromotive - 10/20/19 09:13 PM
4L80E to Allison filter conversion
by P10crew - 10/20/19 09:03 PM
Pickles and gardenia
by 53' Stude - 10/20/19 09:00 PM
Weird Electrical Problems Due To Bad Ground.
by RayCJ - 10/20/19 08:59 PM
ECOGARD X 4610 CUT OPEN
by 53' Stude - 10/20/19 08:23 PM
FRAM ULTRA 7317 CUT OPEN
by 53' Stude - 10/20/19 08:17 PM
Easy to use free video editor
by Rat407 - 10/20/19 08:11 PM
Best budget tire for 2006 Nissan Pathfinder SE
by Dogred08 - 10/20/19 07:51 PM
Latest on SSD, HDD and USB Drives?
by JHZR2 - 10/20/19 07:43 PM
Oxy Clean On Leather Seats...WoW
by Warstud - 10/20/19 07:22 PM
Winter street biking
by CourierDriver - 10/20/19 06:47 PM
AltairJr, PMSARATOGA, bobmay460, RoddyCGA, whizznbyu
69628 Registered Users
40 registered members (77GrandPrix, 4WD, billt460, 1960Elco, 87sammy, bbhero, 3 invisible), 879 guests, and 23 spiders.
Topics296,251
Posts5,094,231
Members69,624
Most Online3,532
Jul 30th, 2019
Infiniti oxygen sensors. #4893475 10/10/18 10:56 PM
B
bowlofturtle Offline OP
B
Looking at the graphs for my g35x. I'm a little odd by the data.
-Bank 1 is around .2v +/- .4v
-Bank 2 is around .5v +/- .7v
They both still mirror each other on its ups and downs per the graphing. I'm so used to seeing a flatline on a bad sensor or a lazy sensor for that matter. I figured Bank 1 is just getting worn down, fault code was for Bank1's low voltage. Kinda debating on replacing both sensors at 133k
Who normally would be the OE source for the sensors. Rockauto has these sensors all very closely priced. $80-101 each.
Denso, NTK, Bosch.... all solid ones. Bosch's description actually says "ACTUAL OE sensor" but can that be true? If this was a toyota denso would be highly considered to me as OE.
My toys
-05 Infiniti G35x 140k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 20k
-98 Nissan Maxima 160k
-09 Toyota Camry V6 96k
Re: Infiniti oxygen sensors. [Re: bowlofturtle] #4893477 10/10/18 10:59 PM
StevieC Offline
I would go with the Denso on that vehicle or NTK as the second choice. I wouldn't go with Bosch unless it was a German vehicle. Never had any luck using Bosch on anything but German OE's for 02's and Spark Plugs.
'18 Caravan - 42k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Infiniti oxygen sensors. [Re: bowlofturtle] #4893552 10/11/18 03:31 AM
T
Trav Offline
T
It is very likely Bosch did make the OE part as they have a huge OE program. Ford USA and many others use them OE.
Bosch invented these things and their sensors are excellent, Unlike spark plugs where people claim this one and that one work better in this and that engine the O2/AFM doesn't care what make of exhaust its sniffing.
At that mileage I would do both, you are under there getting dirty anyway.
Re: Infiniti oxygen sensors. [Re: bowlofturtle] #4893566 10/11/18 04:35 AM
Char Baby Online Content
Online Content
On RA, I looked up a NISSAN model that I previously owned('04 Altima) and it too mention BOSCH as the OE. I also looked up an '05 Maxima and it DOES in fact mention BOSCH as OE. In addition, I looked up a couple of other Asian models that I've had in the past as well(Mazda, Lexus) and they DO NOT mention this.
So, BOSCH was probably the OE sensor for Nissan/Infinity during that time, I looked up my current '15 Altima and it DOES NOT say that BOSCH is the OE provider.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Infiniti oxygen sensors. [Re: bowlofturtle] #4893635 10/11/18 07:21 AM
J
Jimzz Offline
J
People forget Nissan has an alliance with Renault S.A. of France. They even use Mercedes engines, the turbo 4cyl, in some of their vehicles now. So using Bosch as a supplier sounds right.
yup
Re: Infiniti oxygen sensors. [Re: bowlofturtle] #4893703 10/11/18 09:04 AM
L
LeakySeals Offline
L
How is the LTFT on bank 1? Infiniti and Nissan are very picky when it comes to sensors. Hitachi for most like the coil, cam, crank, Maf. Bosch for O2. I think it may be some variation of a 22690. Put your options in here to verify and diagram. https://www.infinitipartsdeal.com/
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k ST HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
Re: Infiniti oxygen sensors. [Re: bowlofturtle] #4893770 10/11/18 10:18 AM
J
JMJNet Offline
J
I replaced the O2 sensor for my brother's Nissan a long time ago.
What comes out was a Bosch O2 Sensor.
We bought the replacement from AZ which was a Bosch and never had issue.
It was the easiest O2 sensor though with only 1 wire.
  • 2017 Toyota Sienna
Re: Infiniti oxygen sensors. [Re: bowlofturtle] #4893796 10/11/18 10:48 AM
M
mclasser Offline
M
Bosch O2 sensors were used as OEM on many Nissan/Infiniti cars of that era.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Infiniti oxygen sensors. [Re: bowlofturtle] #4893988 10/11/18 01:59 PM
N
nthach Offline
N
Nissan uses Bosch as OE - seen them on two Frontiers I've touched. I'd trust a Bosch sensor over a Walker or off brand any day of the week.
Re: Infiniti oxygen sensors. [Re: nthach] #4894477 10/12/18 07:47 AM
T
Trav Offline
T
I have used Walker, they are a Denso element with a connector Walker installs, they fit well and I have never had any trouble with them. When they were first introduced they were priced right but now they are almost the same as the big names so I don't bother using them.
I am running AC Delco O2's in a VW going on 4 years not with no problems whatsoever, I used them because they had the best harness fit (long).
Re: Infiniti oxygen sensors. [Re: LeakySeals] #4896657 10/14/18 10:53 PM
B
B
LTFT -1.6 Bank1
LTFT -5.5 Bank2.
But it was just reset about 5 days prior, I had a evap valve go bad and replaced it. I was just doing a confirmation scan and saw this.
Looks like Bosch could be the OE, since so many people reported so. I'm debating doing both or just a single one now. Amazon has the sensors for a little cheaper.
My toys
Maintaining
-16 Jetta 1.4T 20k
