Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
New Fave way to remove snow from vehicles
by JC1 - 11/12/19 08:19 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
Mobil 1 FS 0w40 vs Castrol 0w40
by Ndx - 11/12/19 04:14 PM
Hombre909, DeLong, Scuder, Jasonrmcc, Capacc
69840 Registered Users
25 registered members (Bailes1992, carlprop, berniedd, BillyE, billt460, AndyB, 3 invisible), 978 guests, and 17 spiders.
Topics297,340
Posts5,113,454
Members69,840
Most Online3,589
Nov 2nd, 2019
Maintenance Additive for Poor/Non-Top Tier Fuel? #4892462 10/10/18 01:51 AM
M
MichaelCT Offline OP
M
Hi all,
New to the forum here, learned a lot of good info for my BMW E90 325i here, but after some searching I could not find an answer for this particular question that's not "just buy top tier fuel".
Well I wish I could but it's not available in my country, I used to live in the states and Chevron/Shell gas worked great for my B5 Passat, so I am now looking for a way to make my own "top-tier fuel" with maintenance dose fuel additives, can that be done?
A little more info on the fuel here, they did introduce a new fuel standard relatively recently which is now 10ppm sulfur content (same as euro 5 I believe), I did service my fuel tank due to some unrelated issue and the tank looked clean, no deposits, gunk, etc. So my guess is the fuel here is of good quality but has little to none detergents added.
Right now I am just using Techron every 5,000km/3,000mi , it works but I just fear that's not enough. My parents' F11 530i which receives less care and sees mostly in town slow driving needed new spark plugs in only 30k km / 18k mi covered in carbon, I try to pour a bottle of Techron in it every 10,000km as I go back home.
Also a side note on intake deposits, when I removed my intake manifold to replace my starter, the intake valves looked clean just after one tank of Techron, but after spraying some carb cleaner into the intake manifold, what came out was dark brown colored and looks gross, should I use Amsoil Power Foam like many recommends on the forum?
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4892473 10/10/18 02:46 AM
demarpaint Offline
You could buy something like Red Line's FI cleaner which can be added in smaller quantities as a maintenance dose. In fact they recommend doing so.
I've had good results with Power Foam.
God Bless Our Troops
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4892507 10/10/18 04:30 AM
danez_yoda Offline
Techron is one of the recommended PEA fuel treatments. You should be good with that. If you find the carbon building up on sparkplugs, increase the dosage.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4892619 10/10/18 07:30 AM
StevieC Offline
welcome to BITOG!
I'm a big fan of the Amsoil P.I. not because I'm an Amsoil user but because it unclogged and injector in my beater Neon that no other additive could do and it did it in just 400km. That made me a believer in their fuel treatment. I have also looked into the cylinders and at valves using my boroscope before/after treatment with P.I. and it seems to do the most out of all the fuel additives I have tried.
Redline SI-1 is also excellent at what it does but in my opinion it does better as a maintenance dose ongoing to keep fuel systems clean versus doing a full system clean-up of a fuel system like the Amsoil P.I. which is used occasionally to restore the system cleanliness and not ongoing. (Just my experiences with both)
So maybe do an Amsoil P.I. treatment and then maintain it with a low dose of SI-1 thereafter. The SI-1 is also good at lubricating the upper cylinder and as a fuel system components lubricant as well. It quiets noisy injector clicking from my experiences and helps to restore lubrication to gasoline with ethanol in it which has a drying effect. There is lubricants in gasoline but in my opinion there isn't enough and SI-1 seems to fill that gap.
In my Santa Fe (See signature) I ran the cheapest non top-tier gas available and had no issues doing what I described above so it should work for you as well if you can get these products in Asia.
'18 Caravan - 45k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4892697 10/10/18 08:45 AM
J
JustN89 Offline
J
I've used Chevron Techron and Redline SI-1 and have no complaints. Recently, I've started adding a 1:500 mix of TC-W3 to my fuel in lieu of other additives in hopes to achieve similar effects at a cheaper price. So far, so good with the TC-W3.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4892868 10/10/18 11:21 AM
G
Gimpy1 Offline
G
I have the same issue. Until very recently ALL the gas was supplied and sold by PEMEX which is the state owend oil company. Fuel quality was/is horrible. The detergent package was minimal at best. I sent a note to Redline requesting their advice on what dose to use assuming 0% PEA in Mexican gas (1-1.5 oz per 10 gallons). I have not had any fuel related issues and my 05 GTO passes sniffer pipe emission tests at 6600 feet ASL with flying colors.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4893354 10/10/18 07:11 PM
scott30si Offline
Why don't you try Renewable Lubricants Bio-Plus Injector Cleaner Gas Conditioner on Amazon. It is BMW approved. I just got through using one gallon and it made my cars run smoother. I used about 1.5 oz. per 15 gallons. I am now trying Schaeffer's SoyUltra Gasoline Additive #131C. No complaints with either one.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4893443 10/10/18 09:05 PM
G
Gixxer46 Offline
G
Amsoil PI or redline si-1 for fuel treatments and use crc turbo and intake valve cleaner and spray that into the intake.
2013 Ram 1500 with a 4.7.
I use 0W-20 year round. I alternate between RP and Amsoil Signature series.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: demarpaint] #4893528 10/11/18 12:32 AM
M
M
I think you are right, Techron is working well for my E90 at recommended interval, I might increase dosage in the F11 next time around since I am unable to add it frequently enough.
That's what I am thinking about actually, funny thing Red Line SI-1 is slightly cheaper in my location than Techron and it has a clear bottle which is convenient for adding small doses, and since they are both PEA based I'm going to start using it for maintenance dose.
Will try Power Foam on next oil change too.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: StevieC] #4893531 10/11/18 12:44 AM
M
M
Originally Posted by StevieC
welcome to BITOG!
thank you Stevie,
I was quite surprised to see my fuel tank being clean, I actually did a little more research on the gas here and it still has higher Olefins and Aromatics content (24%, 40% respectively) than euro 5 gasoline (18%, 35% respectively), everything else is pretty similar and it's not ethanol fuel although I don't care about that (my Passat ran just fine on E10 back in the U.S., even when it was parked for over 6 months).
The new standard is an improvement over the last revision and given what I saw in the fuel tank, I am not too worried about fuel system problems, but I will definitely start using Redline for maintenance dose from now on.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: JustN89] #4893533 10/11/18 12:55 AM
M
M
isn't that two stroke oil? I am not familiar with that, can you elaborate?
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: scott30si] #4893534 10/11/18 01:00 AM
M
M
Good to know, and if my math is right that's about 1:1000 ratio, local Redline retailer suggests the same dosage as well.
Those aren't available in my location but Techron is actually sold through BMW (re-labelled as BMW additive, in the same bottle). Since Redline and Techron are both PEA based I consider them the same and will be using Redline for maintenance doses for it's slightly cheaper price and clear bottle.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: Gixxer46] #4893535 10/11/18 01:02 AM
M
M
Wouldn't that be a little redundant? My valves are pretty clean with Techron, it's the intake manifold I am concerned about (planning on using Amsoil Power Foam).
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4893909 10/11/18 11:37 AM
J
JustN89 Offline
J
Yes, it's an ash-less two cycle engine oil. Mixed 1 ounce to 5 gallons it will clean you fuel system with the oil's detergents and the ash-less TC-W3 will burn clean and not leave any deposits. Here is a thread on another site that is very detailed on the advantages of using a mixture of TC-W3 in your fuel. At the very least, it's much cheaper than other fuel additives as you can usually pick up 16 ounces of Walmart brand TC-W3 for just a couple of bucks.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4894345 10/11/18 10:05 PM
G
Gixxer46 Offline
G
You spray it through the throttle body so it will clean manifold along the way.
I compared it to Seafoam and found Seafoam didn’t do much in my manifold.
We don’t get amsoil power foam in Canada.
