What would make BITOG better?
by Hastrup. 06/17/19 01:44 PM
Adhesive sealant FTW!
by mclasser. 06/17/19 01:29 PM
1985 Toyota Camry.. Any tips?
by spavel6. 06/17/19 01:20 PM
AAP 25% off
by rollinpete. 06/17/19 12:52 PM
TCW3 and direct injection
by ARB1977. 06/17/19 12:45 PM
Brake bleeding procedure
by painfx. 06/17/19 11:28 AM
5W20 walmart Full Syn bad smell
by ragtoplvr. 06/17/19 11:18 AM
Leaving Amsoil Ea15k filter for 2 oil changes?
by metroplex. 06/17/19 11:15 AM
Just did my 1st CVT fluid change
by Char Baby. 06/17/19 10:24 AM
Saab 9-3 Carrier Bolts - 155 ft lbs
by ET16. 06/17/19 09:15 AM
Fran CA11480
by jcartwright99. 06/17/19 08:43 AM
Recommend oil for 2020 Kia Soul 2.0L
by Hoot_r. 06/17/19 08:40 AM
Why does Amsoil market the way it does?
by Redright9. 06/17/19 08:36 AM
'11 CTSV - M1EP 10w30 - 8K Built LSA - ~2k sample
by oilnoob32. 06/17/19 08:34 AM
Blue smoke and Mobil 1 Syn High Milage!!
by Kestor. 06/17/19 08:03 AM
crank and water pump pulleys stuck
by slybunda. 06/17/19 07:50 AM
2018 Mazda6 oil choice?
by gabriel9766. 06/17/19 07:33 AM
The Real Scoop
by RayCJ. 06/17/19 06:08 AM
time based timing belt change question
by berniedd. 06/17/19 03:18 AM
Skraeling, Metalmanx48, Cannedcreamcorn, Kestor, Slipcase
68418 Registered Users
112 registered members (69Torino, 53' Stude, 2011335d, 2012AccentSE, 1978elcamino, 13 invisible), 2,387 guests, and 28 spiders.
Topics290,577
Posts4,988,735
Members68,418
Most Online2,967
Mar 10th, 2019
[cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax #4889368
10/06/18 04:05 PM
10/06/18 04:05 PM
Naperville, IL
wwillson Online content OP
Administrator
wwillson  Online Content OP
Administrator
Naperville, IL
This filter is from my 2018 Duramax. This is the original spin-on filter with a total of 8,000 miles. There is a small amount of metal flakes in the filter and only enough clutch friction material to discolor the media. I see no reason to change this filter more often than 25,000 miles. The magnet that mounts between the filter and trans body had a small amount of dark material stuck to it - probably a couple grams.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889384
10/06/18 04:25 PM
10/06/18 04:25 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Yeah looks like a long term filter.
"If I walked on water, they'd say I couldn't swim."
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889462
10/06/18 06:49 PM
10/06/18 06:49 PM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
My understanding is that most transmission spin-on filters by the OEM are still rock catchers. Better rock catchers than the pan filters, but still around 60-80 microns. That's why I replaced mine with an XG7317.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889558
10/06/18 09:10 PM
10/06/18 09:10 PM
Cloquet Mn.
bobbobtar Offline
bobbobtar  Offline
Cloquet Mn.
When I had a 2009 Chevy Duramax with the Allison 1000 transmission I would change the trans. filer every oil change about 10,000 miles cheap insurance.
2017 Toyota Highlander
2018 John Deere 2032R
2014 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889632
10/06/18 11:34 PM
10/06/18 11:34 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted by wwillson
I see no reason to change this filter more often than 25,000 50,000-75,000 miles. The magnet that mounts between the filter and trans body had a small amount of dark material stuck to it - probably a couple milligrams grams
There, I fixed all of that for you.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893078
10/10/18 03:22 PM
10/10/18 03:22 PM
Southeast
BlakeB Offline
BlakeB  Offline
Southeast
I changed the spin-on trans filter on my Dads 2016 LML at 31k with 2073 hours. The magnet had some fuzz on it, but nothing excessive. I haven’t cut the filter open yet, but if I do I’ll post pics.
I checked on Allison’s site and this is what the fluid and filter calculator gave me:
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893366
10/10/18 08:28 PM
10/10/18 08:28 PM
Naperville, IL
Administrator
Administrator
Naperville, IL
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893373
10/10/18 08:33 PM
10/10/18 08:33 PM
Southeast
BlakeB Offline
BlakeB  Offline
Southeast
How many hours on your L5P?
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893378
10/10/18 08:35 PM
10/10/18 08:35 PM
Naperville, IL
Administrator
Administrator
Naperville, IL
190 hrs
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: DoubleWasp] #4900743
10/19/18 10:33 PM
10/19/18 10:33 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
And yet what is percentage of failed transmissions? Not very high.
don't use.
