Bruce Crower Passes
by 02SE. 07/20/19 12:30 AM
Toyota YZZA1 Filter, 9,958mls
by edyvw. 07/20/19 12:06 AM
Chevron Supreme 5w30 Noack?
by Whammo. 07/19/19 11:56 PM
Injector sleeves in 7.3 Powerstroke w/ 6 sp MT
by Earls1st. 07/19/19 11:32 PM
Which 0W20 to slow use
by lukejo. 07/19/19 11:09 PM
2012 Camry suspension question
by lukejo. 07/19/19 11:03 PM
Opinions on manufactured homes
by ram_man. 07/19/19 10:50 PM
NGK Ruthenium HX
by David1. 07/19/19 10:21 PM
Royal Purple Filter Mileage Rating
by JerryBob. 07/19/19 09:53 PM
what brand of filter is this?
by ctwhitechin. 07/19/19 09:45 PM
VW Amorak truck
by AZjeff. 07/19/19 09:25 PM
New Honda Super Cub - leaking oil
by Lawn_Care. 07/19/19 08:55 PM
Loc-n-lube
by rideon. 07/19/19 07:54 PM
Humidity thread follow-up... phew!
by 14Accent. 07/19/19 06:55 PM
NEW FEDERATED LF651F FILTER CUT OPEN
by 53' Stude. 07/19/19 06:39 PM
Brake Job @ 26K On My GLC43
by 2015_PSD. 07/19/19 06:25 PM
New Scanner Autel MK808BT
by another Todd. 07/19/19 06:20 PM
Stonehunter, ctwhitechin, gwandless, Philippe1988, ChiefDaBooty
68712 Registered Users
31 registered members (CleverUserName, chrismo, c1vic, DrDave, csandste, 5 invisible), 710 guests, and 27 spiders.
Topics292,124
Posts5,017,194
Members68,712
Most Online2,967
Mar 10th, 2019
MB GLE 350 engine oil weight #4893158
10/10/18 04:21 PM
10/10/18 04:21 PM
Austin, TX
MaximaGuy Offline OP
Austin, TX
Folks:
For the vehicle in my signature, I am about to change oil and it calls for 229.5 speced MB fluids
Pennzoil Platinum has been my favorite for years and its comes in 5W30, though most MB owners I have spoken to use 0w40/5w40 M1
Let me know your thought
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893167
10/10/18 04:29 PM
10/10/18 04:29 PM
California
nthach Offline
nthach  Offline
California
As long as it meets that particular Mercedes spec, I don't see a problem using it. There is Euro-spec PP but that's hard to find. If you're buying oil at Walmart, M1 0W-40 or Castrol Edge 5W-40/0W-40 are your best bets.
Mercedes is kinda weird - they recommend M1 for service fill, but they work with Shell for OEM-fill fluids.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893215
10/10/18 05:06 PM
10/10/18 05:06 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Grade and brand fade into irrelevance as long as it carries the approval.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893317
10/10/18 07:15 PM
10/10/18 07:15 PM
CA
The Critic Offline
The Critic  Offline
CA
Originally Posted by MaximaGuy
Folks:
Pennzoil Platinum 5W30 does not meet the required specs for your vehicle - you will need to use the Platinum Euro 5W-40.
2011 Toyota Prius 1.8L - 193K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893343
10/10/18 07:59 PM
10/10/18 07:59 PM
Austin, TX
Austin, TX
2018 MB GLE350
2011 Lexus ES350
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893361
10/10/18 08:20 PM
10/10/18 08:20 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
This Euro L carries C3 and 229.51.
Go for it.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893370
10/10/18 08:32 PM
10/10/18 08:32 PM
Austin, TX
Austin, TX
My intention is to stick with 30 weight since the engine is new - it may be a good idea when it goes into the 100K+ range to switch to 40 weight.
2018 MB GLE350
2011 Lexus ES350
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893389
10/10/18 08:54 PM
10/10/18 08:54 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Here is the Euro L:
If you want the job done right......do it yourself.
Re: MB GLE 350 engine oil weight [Re: zeng] #4893493
10/10/18 11:30 PM
10/10/18 11:30 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Go for it.
This is a common mistake. MB 229.5 and 229.51 are TWO different specs. They spec 229.5 for gas engines and 229.51 and 229.52 for diesel engines. Because they have a 10k oil change interval, you're better off with a 229.5 oil than a 229.51 oil although you can use a 229.51 oil in a car that calls for 229.5. It's been covered multiple times in past threads.
I believe Mobil is actually the OEM maker of oil for Mercedes. Shell makes a bunch of transmission fluids you can use such as 236.14 and 236.15.
Check out the list of approved MB 229.5 fluids. You will not find the 229.51 fluids on there.
https://bevo.mercedes-benz.com/bevolisten/bevo-sheets-sort1.html
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893550
10/11/18 03:28 AM
10/11/18 03:28 AM
Snagglefoot Offline
Snagglefoot  Offline
The OP wants to use a 5w30 oil. The Euro L, which is designed as a diesel motor oil, is also rated C3 which is fine for a gasoline engines He was also partial to Pennzoil products.
Is there a 5w30 229.5 product out there? I’ve seen 5w40 229.5 products but so far I haven’t see a 5w30 version. I certainly could be wrong about that. Please let me know. smile
Re: MB GLE 350 engine oil weight [Re: Wolf359] #4893556
10/11/18 03:41 AM
10/11/18 03:41 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Here is another common myth/mistake on this board.
A 229.5 is meant for a MB gasoline engines ONLY , and it's NOT for (light duty ) diesel engines (with modern emission systems) .
However, a 229.51 mid saps oils is always meant for a diesel engines, AND gasoline engines.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893583
10/11/18 05:27 AM
10/11/18 05:27 AM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
I always thought the MB 229.5 was originally based on the ACEA A3/B4 specs, but actually it's only mandatory to pass the ACEA tests when the specs are claimed on the package, if I understand correctly.
I am yet to see a 229.5 that does not carry A3/B4, I guess when you reach 229.5 perfs, the ACEA comes for "free" !
There are some OM 646 and VW TDI tests for MB 229.5 though.
Ok, that is to say, to me pretty much all MB229.5 oils are also ok for light diesel use, and that's precisely what I use in my old old old diesel...simply because the Total 5W40 I use is cheap and carries it.
(but yes, contrary to the .51/52, if you have emission aftertratement devices, avoid 229.5 in your engine)
Also I thought Petronas was the current OEM for Mercedes (at least in Europe) ?
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 AFE 0W20 | Colt Ralliart, 300V 0W40
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893600
10/11/18 06:19 AM
10/11/18 06:19 AM
Snagglefoot Offline
Snagglefoot  Offline
Here is the back panel of a bottle of Pennzoil Platinum Euro 5w40. One of the specs it meets is MB 229.5. In the white box it says “For diesel and gasoline engines”. It also says AECA A3/B4. Enjoy.
Re: MB GLE 350 engine oil weight [Re: MaximaGuy] #4893743
10/11/18 09:42 AM
10/11/18 09:42 AM
Austin, TX
Austin, TX
The owners manual has either 229.5 or 229.6 for gasoline engines and 229.51 for diesel engines.
2018 MB GLE350
2011 Lexus ES350
Re: MB GLE 350 engine oil weight [Re: zeng] #4893896
10/11/18 12:27 PM
10/11/18 12:27 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
While that's somewhat true, if you take your car to an MB dealer, they will only put MB 229.5 oil into a gasser and MB 229.51 or 229.52 into a diesel. Yes, you can use 229.51 or 229.52 in a gasser, but it's not ideal. That's why MB specs 229.5 still for gassers. MB 229.51 or 229.52 doesn't supersede 229.5. Whereas you can use 229.52 where 229.51 is called for. If you have a choice of oils, just use 299.5 oils in a gasser, it's not making it better by using 229.51.
