2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
madjid, michWB, Brianhefty, JimBremer, Katdaddy
70471 Registered Users
101 registered members (aircooled, AlienBug, 4WD, Alfred_B, alchargo, 2015_PSD, 8 invisible), 2,634 guests, and 22 spiders.
Topics300,313
Posts5,173,046
Members70,471
Most Online3,728
Jan 11th, 2020
2018 Subie Crosstrek 1st oil change #4892879 10/10/18 11:37 AM
1
1bioguy Offline OP
1
OK, I just cant pay the stealership $80.00 for 1st or any oil change when NAPA 0w20 on sale at $18.99 and Gold filter on sale.
Question is, most subbiefiles swear by Subbie filter (Framish) for warranty etc. My research shows me WIX/NAPA have same 27 psi bypass as oem so shouldnt be an issue. Any other recommendations for me?
OEM seems safe, but I believe there are better alternatives. I'd like to use K&N but U think by pass is too low...
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4892898 10/10/18 11:53 AM
V
Virtus_Probi Offline
V
I bought a whole bunch of black Tokyo Roki filters for pretty cheap on Amazon a while back...shipping for a single would have been prohibitively high, but when I ordered ten or more the total per filter price dropped under $4.
That particular deal has gone with the wind, though.
These are the filters that are on the cars when they are shipped from Japan, so I felt like they were good choices.
Don't like the blue cans in the US because I can feel the case flexing when I tighten them, but I did buy a bunch of them for my daughter's Impreza as the black ones for my car won't fit into the "cup" around the filter mount in her car.
She has a WIX on her car right now, was in a hurry to do her last change and didn't make it to the Subaru dealer in time so I stopped at O'Reilly...the one time I used one of these on my car the gasket wouldn't seal right no matter what I did, but the one in her car has been A-OK. I think I just got one with a slightly wonky gasket, bad luck for me but not indicative of a bad product overall.
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4892921 10/10/18 12:15 PM
ccs368 Offline
I like the OEM Subaru filters and purchased multipacks w/ OEM crush washers through eBay that are verified Subaru dealers so overall cost was not that much more or even the same as aftermarket filters. If you choose to replace crush washers with OEM, I believe the washer seam goes torwards the drain hole and not facing towards the drain plug but I've read many posters saying that it doesn't matter with no leaks either way. You just got to get the torque correct when tightening.
The only concern is for the first time, there could be overspray from the black paint causing a very tight drain plug so don't get too anxious if you're exerting a lot of force to crack it loose.
Napa Oil and grade seems good for a clean engine at recommended 6k but I usually go earlier for the first one and then follow factory change intervals there after.
2015 Toyota Sienna LE FWD 0w20
2003 Toyota Corolla LE 5w30
2006 Suzuki Vinson LT-F500F 10w40
2004 Harley-Davidson Fatboy FLSTF 20w50
2001 Ducati 996S 20w50
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4893042 10/10/18 01:58 PM
Danno Offline
Sarah has some nice tips on a Subaru oil change
https://www.youtube.com/watch?v=JKkclopgQeQ
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4893081 10/10/18 02:24 PM
M
Miller88 Offline
M
DO NOT use a 12 point socket on the 14mm drain plug. For some reason they put the small drain plug in and then painted it. You can't fit a 13mm on it (or 1/2), but 14mm and 9/16 are lose on it. If you use a 12 point, you will strip it.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4893112 10/10/18 02:45 PM
1
1bioguy Offline OP
1
Is it important to observe torque rating?
Re: 2018 Subie Crosstrek 1st oil change [Re: Miller88] #4893117 10/10/18 02:49 PM
SHOZ Offline
Hyundai and Kia have a similar problem on their manual trans drain plugs. Very thin head and a 24mm nominally. But a 15/16" six point fits perfect. If you use a 24 mm socket it slips and the thin head takes a beating.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4893127 10/10/18 02:55 PM
A
aba4430 Offline
A
Before anyone goes bonkers, the Purolator Boss PBL 14615 is a good filter for the CrossTrek. My son used it on his 18 CrossTrek (@2400 miles now) and I have used it on our 17 OB 2.5 with no issues. The start up rattle is subdued with the PBL14615 on the OB...…., vs. the original blue Subie filter. I am presently running the Fram Ultra 7317 on the OB and will go back to the PBL14615 next time.
2018 Nissan Titan CC Pro4X
2017 Subaru Outback 2.5
Subaru RGV12100
2013 Suzuki SX4 Sportback
2000 BMW 328Ci
1998 BMW Z3 2.8
1995 JD LX178
1987 Subaru Brat
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4893140 10/10/18 03:04 PM
SVTCobra Offline
Girlfriend has a '16 model - I've used Wix filters since new and UOAs at every oil change, no issues.
Think twice, speak once.
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4893141 10/10/18 03:05 PM
PimTac Offline
I’ve never used a torque wrench in 45 years of oil changes. Then again that’s just me. Never had a leak or any other issues.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4893143 10/10/18 03:06 PM
dave123 Offline
1st change on my 18 WOW that drain bolt is Tiiiiight!!!! Mine OEM filters only all cut yea it’s a decent filter no problems almost 30k I like the engine never a drop burns. Zepro high moly 0W20.
Re: 2018 Subie Crosstrek 1st oil change [Re: aba4430] #4893183 10/10/18 03:41 PM
1
1bioguy Offline OP
1
It looks like the PSI rating on that is 20-30, which looks good for us Crosstrek folks.
Re: 2018 Subie Crosstrek 1st oil change [Re: PimTac] #4893198 10/10/18 03:53 PM
Bud Offline
I agree.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: 2018 Subie Crosstrek 1st oil change [Re: 1bioguy] #4893245 10/10/18 04:43 PM
F
fdcg27 Offline
F
I'd feel comfortable using any filter for which the application is listed by the filter manufacturer.
I've used an Ultra, a TG and the current Ultra on our '17 2.5 so far with no concerns.
Our '09 saw its last OEM filter when it left Japan with no problems.
WRT oil, I'd take advantage of either the M1 or Valvoline MIR and use one of their 0W-20s, saving some coin in the process.
I'd favor M1 AFE unless you can stack a killer deal on VME, as I did.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 30K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: 2018 Subie Crosstrek 1st oil change [Re: Miller88] #4893249 10/10/18 04:48 PM
G
goodtimes Offline
G
they make 17/32 wrenches,.sockets, how about that?
