What is more important in an oil?
by Rglossip - 10/17/19 08:03 PM
Chevy 2.4 Oil Burner Oil/Filter Change?
by GaryPoe - 10/17/19 07:57 PM
2016 F150 2.7 UOA 4k
by tomcruise - 10/17/19 07:13 PM
Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB
by Whimsey - 10/17/19 07:01 PM
How To Avoid Deer?
by Passport1 - 10/17/19 06:41 PM
Mazda6 P0401 code
by miden851 - 10/17/19 06:15 PM
2004 Crown Vic shock/ struts recommendation
by umungus1122 - 10/17/19 06:12 PM
Undercarriage pics of my 2003 E46 330Ci ZSP
by SLO_Town - 10/17/19 06:11 PM
Porter Cable air compressor not shutting off
by JLawrence08648 - 10/17/19 06:06 PM
OCI older car, modern oil
by VQLT - 10/17/19 05:24 PM
ZAINO Products
by BlueOvalFitter - 10/17/19 05:17 PM
BMW N63 engines... Valve seals
by Ndx - 10/17/19 04:53 PM
Heating oil prices ???
by BAJA_05 - 10/17/19 02:33 PM
Magnatec 5W-20/30 $16.35/jug @AAP
by wemay - 10/17/19 02:05 PM
Water pump
by dawgn86 - 10/17/19 01:55 PM
Wheel bearing
by toad - 10/17/19 01:54 PM
Google photos no longer syncs to Google drive?
by LeakySeals - 10/17/19 01:51 PM
Paul_Millner, kelsdawnj, Emtp1990, rodramble, kebabaluba
69589 Registered Users
121 registered members (10WSmuckers, 2010Civic, 2003f7, 330indy, 92saturnsl2, 16 invisible), 1,971 guests, and 18 spiders.
Topics296,115
Posts5,091,417
Members69,589
Most Online3,532
Jul 30th, 2019
Mahindra service fluids #4892508 10/10/18 05:30 AM
dnewton3 Offline OP
Global Moderator
Global Moderator
My friend has a Mahindra 8560 and we need to service it this fall. As good as the tractor is overall, the owner's manual is a bit lacking, TBH. The manual often refers to brand specific stuff (example: the power steering fluid recommends Mobil AW46 type fluid; we used the RK AW46 equivilant).
Looking to choose between a few THF fluids from RK; a very close supply of farm stuff.
Choices for THF:
https://www.ruralking.com/harvest-king-case-ih-trans-hydraulic-fluid-2-gallon-jug
or this ...
https://www.ruralking.com/transdraulic-fluid-h-k-univ-2-gal
I realize staying away from "yellow pale" stuff is a priority, but either of these seems OK. What's the main difference between them, and would it make a difference in his Mahindra?
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Mahindra service fluids [Re: dnewton3] #4892597 10/10/18 08:10 AM
dlundblad Offline
As I tractor shop, it's stuff like this that makes me want to stay away from their brand. I know Im not answering your question, but this post just confirms my decision.
I will say the Roxor thing is pretty neat though. Test drove one about a month ago. 2 litre turbo diesel, 5 speed, front and rear D44's, rear leafs and BFG KO2's.
A company makes an orange tractor that has awesome parts support.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980 (Ecore)
Re: Mahindra service fluids [Re: dnewton3] #4892639 10/10/18 08:55 AM
J
JayhawkRoy Online Content
Online Content
J
I have owned two Kioti ag tractors, and have had similar issues with identifying correct fluids. The universal fluid with the J20C spec equivalent is the one I have used with success in my tractors. I know nothing about the differences in the Case/IH fluids vs the universal fluid with the J20C spec.
Re: Mahindra service fluids [Re: dnewton3] #4892702 10/10/18 09:48 AM
I
IndyIan Offline
I
IMO if he really works it as a field tractor, I'd just get name brand stuff. Shell, Chevron, etc. If he's stuck on RK he'll have to do the research on what odd spec Case had to warrant a separate THF. I think some Case's in the 70's had a weird automatic power shifting which may have needed a special fluid to hold together for the warranty period.
My Kioit dealer uses Chevron THF 1000 since Kioti doesn't sell a THF. I chose Petro Canada Duratran for its slightly better cold flow but still thick enough for summer use running near max hp for hours doing hay, also they publish a good set of specs, so its no mystery what you are getting. https://lubricants.petro-canada.com...M-7821E&type=TechData&lang=en-CA
07 Focus ZXW, 5spd manual, 245km M1 5W30
18 Outback 2.5 CVT 35km 0W20
Re: Mahindra service fluids [Re: dnewton3] #4937240 11/27/18 10:50 PM
dhellman12 Offline
DNewton,
My dad has a 2538 HST from Mahindra, same challenge. The owners manual is very lacking.
We're about to change the THF and will be going with the Universal line from TSC. Note it does say it's compatible with Mahindra on the back of the label. I'm sure the universal stuff from RK probably does too and both likely have similar specs (pricing seems identical too).
Good luck!
05 Kawasaki BF750 - 284hrs
12 Jeep 3.8L - Amsoil ASL 5w30 74K
04 DMax 6.6L - Amsoil AME 15w40 238K
00 WS6 5.7L - Amsoil ASL 5w30 256K
Re: Mahindra service fluids [Re: dnewton3] #4937372 11/28/18 05:45 AM
dnewton3 Offline OP
Global Moderator
Global Moderator
We (the owner and I) like the big Mahindra, but you've hit the nail on the head when you say the manual is lacking; very sparse info other than some pictures, torque values and some vague fluid specs (if stated at all).
These tractors are used world wide, and most of them don't get the love that we heap on stuff here in the States. I have a friend that did missionary work for several years and he often noted that the main fluid used in most ag equipment is "oil". What kind of oil? Whatever was handy! Engine oil in the UTF. UTF in the diffs. Gear oil in the crank case. Didn't matter; oil was oil to those folks. If it's anything but black colored (used) they will dump it in the fill hole, apparently. And yet most of those tractors continued to run; maybe not 100% as well as they should, but run none the less.
I have to think that a good UTF from TSC or RK will suffice.
Re: Mahindra service fluids [Re: dnewton3] #4937965 11/28/18 04:27 PM
MolaKule Offline
Global Moderator
Global Moderator
These HK/Mystic fluids are made/blended by CITGO and I can see no differences between the two as they appear to contain the same mixtures as part of the CITGO "Transgard/Trans-Hydraulic Fluid/Universal" series.
These universal trans-hydraulic fluids are designed to lubricate transmissions, differentials, final-drive planetary gears, wet-brakes and hydraulic systems of such equipment only.
Texaco 1000 THF is similar.
I would probably go with the HK Trans-Hydraulic Fluid/Universal.
Please note none of these fluids seem to carry any Mahindra references as to coverage.
It is unfortunate that the FF wasn't sampled upon delivery for a VOA.
"You ... sadist," said Mr Cummings, "you try to make people think." Ezra Pound (1885-1972)
Re: Mahindra service fluids [Re: dnewton3] #4937993 11/28/18 05:08 PM
MolaKule Offline
Global Moderator
Global Moderator
I almost forgot to mention the Shell series of Universal THFs:
http://tdc.ge/wp-content/uploads/2014/03/5_SPIRAX_S4_TXM.pdf
Re: Mahindra service fluids [Re: dnewton3] #4938215 11/28/18 09:27 PM
MolaKule Offline
Global Moderator
Global Moderator
Also, and I am not sure why salesrep didn't respond, but Scheaffer Oil's #315 Simplex can be used in the Mahindra.
https://www.schaefferoil.com/documents/202-315-td.pdf
Moderated by  Lubrizol
