Mitsubishi Mirage for Basic Transportation
by parimento1 - 04/02/20 12:54 AM
Amsoil EaOM103
by Lufty - 04/02/20 12:46 AM
Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
36 registered members (blufeb95, avi1777, Cdn17Sport6MT, carlprop, bbhero, 2 invisible), 814 guests, and 22 spiders.
Topics303,468
Posts5,235,676
Members71,074
Shell Rotella T6 0W-40 CJ4 VOA #4892139 10/09/18 06:42 PM
SubaJew Offline OP
I couldn't find a VOA for this so I had one done.
I'm going to be using this in my Carrier APU (Kubota engine) on my truck and wanted a baseline.
I'll be switching between this for winters and T6 5W-40 CK4 for summers.
2005 SUBARU Forester XT 4EAT - COBB Stage 1
Rotella T6 0W-40 CJ-4/SN - WIX 51365
2018 WESTERN STAR 5700 - Detroit DD15 - Eaton Fuller Super 13
Rotella T5 10W-30 CK-4 - Donaldson P551005
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4892147 10/09/18 06:49 PM
SubieRubyRoo Offline
Looks stout! Gonna use it in the Forester as well?
Where did you find the 0W40? AAP?
De omnibus dubitandum.
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4892149 10/09/18 06:51 PM
Snagglefoot Offline
Thanks for the VOA. This is also rated SN. Very high Zinc. Excellent.
If you want the job done right......do it yourself.
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubieRubyRoo] #4892153 10/09/18 06:54 PM
SubaJew Offline OP
Nope. Forester never leaves south Florida. Sticking with the M1. It's been working well for me. Local supplier is Advance Auto.
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4892215 10/09/18 07:55 PM
skyactiv Offline
Looks like it would be a good oil for the my wifes Audi and my VW.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubieRubyRoo] #4892253 10/09/18 08:26 PM
L
Linctex Offline
L
Looks stout!
But it has almost no Moly ;'-(
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4892272 10/09/18 08:38 PM
You know moly isn't the end-all-be-all of a motor oil. Stop feeding the trolls LOL
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4892438 10/10/18 12:17 AM
U
userfriendly Offline
U
Am I reading it correctly? 11.99 @ 100C
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: userfriendly] #4893157 10/10/18 04:19 PM
SubaJew Offline OP
Yes. It appears that way. I'm a bit suspect of it though. It seems a bit low compared to the specs released by Shell.
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4893244 10/10/18 05:43 PM
SubaJew Offline OP
I will also note that other posted UOAs show ~12.5 @ 100C. Considering that those samples were taken from degraded end of service life oil, I'm inclined to think that the 11.99 number on my VOA is an unexplained anomaly? FWIW Shell says it should be ~13.2 @ 100C, which would jive better with the posted UOA vs my VOA. YMMV....
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4895072 10/12/18 08:20 PM
dave1251 Offline
Looks like I may use this in the Focus.
don't use.
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4897806 10/16/18 11:51 AM
U
U
The 0W40 VOA is almost identical to the 5W30 RT posted. 11.99 @ 100C falls short of the SAE 40 grade, and the minimum HTHS for 0W40 - 10W40 is suspect.
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: userfriendly] #4898861 10/17/18 05:39 PM
O
oil_film_movies Offline
O
Only in KV100 is it similar. Additive package between Rotella T6 0w-40 & Rotella T6 Multi-vehicle 5w-30 is a lot different. Also, a 0w40 is usally formulated with thinner base oils than 5w30 here.
Re: Shell Rotella T6 0W-40 CJ4 VOA [Re: SubaJew] #4915948 11/05/18 08:14 PM
CT8 Offline
Do you have to mail order the 0w?
