Originally Posted by CR94
Originally Posted by spasm3
Interesting that the 0w-20 has a tbn of 8.35, but the 5w 20 has a tbn of 6.68.
Note that they tested conventional 5W-20, while the 0W-20 was synthetic. That should help explain the difference in volatility, too.
Exactly.
Sure, a blender can formulate a conventional oil to have a higher base number that what they currently have however, the starting base number is only one factor in contributing to a longer drain interval for a synthetic. I have noticed that synthetics usually start out with higher base numbers compared to a conventional oil, which start out closer to neutral.
