I meant to put this in the automotive electrical forum but accidentally posted it here as i was looking at other posts in this section. My bad.
So i have a 2000 lexus es300 with the p0330 knock sensor code. This vehicle has the 1mzfe engine and the knock sensors are very hard to get to and they are expensive $180 a piece. Usually when this code shows up it is either the knock sensor or the wiring harness going to the knock sensor that is bad. It can also be the ecm but i dont believe it is in this case. The toyota knock sensors are a little different than most other knock sensors and its best to use an oscilloscope to diagnose the sensors. Anyway i have a very rudimentary oscilloscope i made via an old headphone cable that plugs into my phone. I followed the factory service manuals oscilloscope section. It said to test the oscilloscope with the engine at 4000 rpm. This car has two knock sensors one for bank one and one for bank two. I cant get to either knock sensors but i can get to the end of the wiring harness that is connected to both sensors. I hooked my oscilloscope up to the end of the harness and tested the waveform at 4000 rpm. It looked good for the one knock sensor. I hooked the oscilloscope up to the other knock sensor and it looked ok at lower rpm idle to around 2000 but when i brought it up to 4000 rpm and held it there the waveform looked ok but it would periodically drop out to a 0v flat line and then come back to normal and then drop out again. I switched back to the other sensor it it was fine. I switched back to this sensor and it was doing the same thing again periodically dropping voltage. Seeing as i cannot get to the knock sensor i can only get to the end of the harness that could also be the problem does this sound like a knock sensor issue or a wire harness issue. The wiring harness lives under the intake manifold and it can get brittle with age so i have heard. I thought a knock sensor either works or it does not? I have not heard of them working intermittent. If it is the wiring harness that would would make sense. I tried tugging on the harness and moving it all round but i could not get it to loose signal unless i ran the engine up to 4000 rpm. Here is a video explaining toyota knock sensors. https://www.youtube.com/watch?v=L8xRJIWkHuo
