Motorkote?
by lawnguy. 02/17/19 10:25 AM
Vehicle stored for 4 months
by palmerwmd. 02/17/19 09:57 AM
How often to drive a car that sits in the winter?
by Corollaman. 02/17/19 08:49 AM
Top Off or Change it Early
by 99Saturn. 02/17/19 08:22 AM
Do your vehicles have a nickname?
by ZZman. 02/17/19 08:19 AM
Another work project thread
by mattd. 02/17/19 08:18 AM
Buzzing sound behind dash
by Spetz. 02/17/19 05:09 AM
Ain't stupid, but can't find Cummin Hist
by BrocLuno. 02/16/19 11:41 PM
Rethinking oil choices
by JLTD. 02/16/19 11:29 PM
coolster 150 cc atv 2019 new
by hyperscion. 02/16/19 10:37 PM
older gps - week counter rollover Apr 6 '19
by spackard. 02/16/19 10:32 PM
Thoughts on an old Lexus?
by JustN89. 02/16/19 09:50 PM
Understanding Fuel Trims for diagnostics.
by StevieC. 02/16/19 07:59 PM
book of matches for tune up?
by marine65. 02/16/19 07:53 PM
New Penrite 0w-30
by toyota62. 02/16/19 07:45 PM
New HID bulbs for the Cadillac
by 14Accent. 02/16/19 07:17 PM
2008 Prius - Water in oil
by cjolson140. 02/16/19 07:00 PM
Kitchen Faucet question
by reemoe2. 02/16/19 06:56 PM
jpdeal, Snipeuout, DeltaWing, JRS3, krzyq
67252 Registered Users
100 registered members (2dogs, ABerns, 2015_PSD, 2004tdigls, 9 invisible), 1,903 guests, and 59 spiders.
Topics298,307
Posts4,989,264
Members67,252
Most Online2,548
Feb 16th, 2019
Engine friction reduction trends #4830433
08/03/18 05:05 PM
08/03/18 05:05 PM
Fredericksburg, VA
JAG Offline OP
JAG  Offline OP
Fredericksburg, VA
The main points should be familiar to those of us who read oil papers, but Iím posting it because itís a good paper. Itís from 2016.
The statements below are not all in the paper. Some come from other sources.
Thinner oils push the lubricant regimes to the left on the Stribeck curve. Yep, itís still true...darn physics.
Friction modifiers help reduce mechanical friction when asperity contact occurs. Fuel economy benefits of thin oils are especially realized (compared to thicker oils) when friction modifiers are added because of the increased asperity contact caused by thin oils.
Near the top and bottom dead center piston positions are the problematic regions due to the low relative speeds there causing oil film thickness collapse. The piston rocking back and forth there makes it even worse for the film separating the piston skirts from cylinder walls. There, the shear rates are very low, so low-shear rate kinematic viscosity is the driver rather than the high shear rate like is used in the HTHS test.
The paper: https://link.springer.com/content/pdf/10.1007%2Fs40544-016-0107-9.pdf
Re: Engine friction reduction trends [Re: JAG] #4830466
08/03/18 06:10 PM
08/03/18 06:10 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
Interesting... Very interesting. So.. Keep using redline 0w20 in my car, right??
15' Civic 1.8 i-vtec 213,000 mi 0w20 Redline/Redline CVT/Archoil9100/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/87 E0 fuel/Yokohama
Son of a Navy Corpsman. Support vets!
Re: Engine friction reduction trends [Re: JAG] #4830506
08/03/18 06:58 PM
08/03/18 06:58 PM
US
JLTD Online shocked
JLTD  Online Shocked
US
popcorn
(and also don't have time for the whole article right now)
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL‚ĄĘ
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: Engine friction reduction trends [Re: Marco620] #4830515
08/03/18 07:03 PM
08/03/18 07:03 PM
Arizona
bulwnkl Offline
bulwnkl  Offline
Arizona
Maybe, maybe not...
If this is an overriding or controlling issue:
then you'd want a fluid with a higher kinematic viscosity, but not really a higher dynamic (HTHS) viscosity. Or, in other words, kind of the opposite of what you get from Redline's fluids: A reasonably '[censored]' 10W30 rather than a Redline-type 0W20.
...but that's only _if_ that one quoted principle is overriding or controlling in terms of overall wear that leads to engine failure or replacement.
Re: Engine friction reduction trends [Re: JAG] #4830599
08/03/18 08:34 PM
08/03/18 08:34 PM
N.A.
Onetor Offline
Onetor  Offline
N.A.
What a paper to digest. I think I need to read it twice. I'm a newbie,,,,
Re: Engine friction reduction trends [Re: Onetor] #4830623
08/03/18 09:15 PM
08/03/18 09:15 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Yeah. They throw in a little of everything---plus more than a few typos. Yes, I made it all the way through.
2011 Toyota Prius now at 96K
Re: Engine friction reduction trends [Re: JAG] #4837695
08/11/18 09:18 PM
08/11/18 09:18 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
These graphs were posted in another thread awhile ago - don't recall which thread or by who. Shows that ring wear is a function of oil temp, oil HTHS rating and engine RPM. Still shows that higher HTSH will reduce ring wear in certain operating conditions. Also, it's pretty typical that higher viscosity oils will also have higher HTHS ratings.
Another reason to use thicker oil IMO is to reduce ring wear based on these graphs ... especially if you're pushing the engine hard (load and RPM), and elevating the oil temperatures above what you'd see in normal street driving.
Re: Engine friction reduction trends [Re: ZeeOSix] #4888783
10/05/18 10:28 PM
10/05/18 10:28 PM
Tucson
neo3 Offline
neo3  Offline
Tucson
[Linked Image]
[Linked Image]
I'm not seeing the same conclusion from those graphs, especially the 2nd one that seems to show that an HTHS of 2.6 has the minimum average wear over the entire rpm range. That HTHS would be typical for a "thinner" oil (XW20) wouldn't it? (Also, they really need another data point in there around 2.9.) Maybe I should change my preference for using "thicker" oil (picked up from reading too much stuff on this site LOL). It would be useful to have a link or citation for the graphs.
Re: Engine friction reduction trends [Re: JAG] #4891367
10/08/18 06:50 PM
10/08/18 06:50 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
^^ Agree with neo3. There are also odd inconsistencies in speed vs. wear in those plots. What is "h·piece" in the vertical axis? (I assume something related to run time or number of revolutions.)
Re: Engine friction reduction trends [Re: neo3] #4891462
10/08/18 08:36 PM
10/08/18 08:36 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The 2nd graph is showing that increased wear can occur for oils that are less than 2.6 HTHS when oil temperature gets elevated some. But it also says if you are using a 20 wt you really have no headroom, but are right at the verge of having more engine wear is the oil temps start to rise above "normal". Look how the wear rates all increase when you go a hair below 2.6. Personally, I don't want to always be operating on the edge of the wear cliff when pushing the engine hard. HTHS of 2.6 is probably fine for tootling around like grandma on the streets. grin2 Notice the wear is basically flat lined for the 2000 RPM case, regardless of the HTHS.
Re: Engine friction reduction trends [Re: JAG] #4891777
10/09/18 09:37 AM
10/09/18 09:37 AM
Arizona
bulwnkl Offline
bulwnkl  Offline
Arizona
Yes, those generalities do seem to be in there, but there also appears to be a very large amount of variation (scatter, really) such that those graphs are not adequate to give me a visual representation I can have confidence in.
Re: Engine friction reduction trends [Re: JAG] #4891993
10/09/18 02:16 PM
10/09/18 02:16 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
^^ Yes. It's interesting that 2.6 mPa·s appears to protect better than 3.1 at most speeds---unless that's merely an artifact of the scatter.
Moderated by  ekpolk
