Originally Posted by OVERKILL
Originally Posted by Dfeeds
I've read some guys complaining about thermal castration on the pp2 when they had an aftermarket oil cooler and such installed. I hope your right and the gauge is accurate, however Ford decided to get the temperature. Actual numbers would be nice, though. I got that picture through 10 minutes of googling for it and the only way I can get actual numbers is to pay for the gt350 oil temp gauge which is plug and play.
Is it accessible through an OBD adapter maybe? Like a ScanGuage? I'm lucky, mine is available right in my cluster but also available on the screen of the entertainment system.
Even if it's available via OBD, it's probably still algorithm data since there is no actual oil temperature sensor anywhere on the engine.
I'd bet the "algorithmed" oil temp is pretty accurate because I'd think the Ford engineers verified by testing that the algorithm works.
One way to verify would be to stick a long thermocouple down the dipstick tube into the oil right after shutting down the engine, and compare that reading to what the colored temp zone gage showed at shutdown.
